Question about Reliance & 40 Gal Mobile Home Water Heater
My water heater is leaking from the bottom is there still a way to fix it or do i need to buy one?
  • 455 Answers
Hello It is new tank time.There is no repair for that.Don't wait for it to let go!They only last so long.
Posted on Sep 15, 2010
My bradford white 50 gallon hot water heater Model # M250S6DDs NCWW Serial # E610822231 D/N
Depends on source of leak: If gas water heater is leaking from bottom, then heater must be replaced.
http://waterheatertimer.org/Leaking-water-heater.html
http://waterheatertimer.org/How-to-install-water-heater.html
Add a comment and describe type of water heater, and what you discover about source of leak.
May 25, 2013 | Water Heaters
Owners manual citroen c8
Depending on location and cause of leak:
Copy following link for troubleshoot resources and steps for each:
Add a comment and describe product in detail, including location of leak, and if this is new product or older product.
Otherwise fixya truncates free questions so full question is usually unseen.
May 12, 2013 | Water Heaters
Water heater leaks
You have to replace water heater.
But you can buy-time if leak is small by turning heater off except when you need hot water. This will give you 30-60 days to shop and find best heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
To prevent tank from rusting in this manner, inspect and replace anode rod each 2-4 years, and keep water pressure below 80psi.
http://waterheatertimer.org/How-to-maintain-water-heater.html
Aug 24, 2012 | Water Heaters
Leeking water from bottom
I wrote a page on leaking water heaters with resources and information:
Page lists things to check.
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Also run hand over tank to find warm spot that says where leak is coming from
A rusted tank cannot be repaired.
If your tank is rusted out, it might burst open and flood the area.
Hot water inside tank is under pressure.
Turn off heat source to water heater.
Turn off water valve located above tank.
Open tub faucet on hot side and relieve pressure from tank.
You can limp along with a leaking water heater by turning it on when hot water is needed.
For example a shower uses 5-9 gallons hot water.
Turn gas water heater on for 15-20 minutes.
Turn electric on for 20-30 minutes.
To conserve resources with next heater:
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Nov 15, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
After connecting a drain line to the pressure relief valve of my MR85245 water heater, I now have water leaking badly out of the heating element door.
Turn off the electricity.
Turn off the water valve going into tank.
Open a bathtub spout to let hot water pressure off the tank.
Check top of tank for any leaks.
Open the top access panel and see if element is leaking.
Open bottom access panel and see if lower element is leaking.
The reduced pressure on the tank will slow the leak.
If element is the problem, you can squeak by for a while by turning on the hot water heater only when you need hot water.
Order the 'Marathon MR85245 replacement element' online
http://www.gpconservation.com/rheem/marathon-sp213670-titanium-4500w-lower-element
These elements may be available locally, but they are not the same as 'ordinary' tank-type electric heater elements that you buy at the hardware store.
Buy more than 1 element because the Marathon elements have problems.
One of the reported problems with marathon elements is the high price of stainless steel replacement elements.
Drain tank.
Replace element.
Another resource for water heater information is:
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Nov 04, 2010 | Water Heater Innovations MR85245 High...
Help! We bought out home 3 years ago and have a Nortiz tankless water heater. Recently we heard a dripping sound coming from the water heater and found that the bottom of the unit is leaking. We had a...
you will need to explain more of where the leak is on the bottom. You have two plastic valves on the bottom and if the clips are not on exactly it will leak and if the person who replaced valves did not use vasoline when they put it back together the could have cut the gasket ring on the inside putting in back together and again it will leak. You have to determine where the leak is coming from to begin with using a flash light to get the exact location. .
Oct 05, 2010 | Noritz 6.9 Gallon Residential Direct Vent...
I have a leak in my water heater coming from around one of the legs. If I shut off the water, the leak seems to change to one of the other legs. Is there some sort of new pan that I can buy or a part that...
Sorry, Sam it sounds like the water heater is defective, unless you can find a leaking connection. It sounds like you have a leak in the heater proper. The reason the leak moves is that, when you isolated the water, it cooled and a slight vacuum is pulled, and the water picked a different course (probably). Before you change the heater out, look at the threaded connections for leakage. Check the inlet and outlet lines, boiler drain valve, pressure relief, and any other threaded connections that you may have. If you find any leakers, you can repair them with wrenches and teflon tape. If no leaks are found at any of the threaded connections, the assumption is that the tank has developed a pinhole leak. They generally are at the bottom 1/3 of the tank. What you can do in the future is to either buy the kind of hetaer that is designed to stir up and remove the scale and sediment in the bottom of your heater, or to manually flush your heater from time to time.
Best regards, --W/D--
Aug 12, 2009 | Water Heaters
Reliance & 40 Gal Mobile Home Water Heater  Logo
42 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
