Question about Whirlpool LEW0050P Electric Dryer
Dryer will not start. When Power is turned on and Power, then Start buttons are pressed- the red lite blinks and there is a high pitched ring, but no movement in dryer drum, no heating and no blower action. The door appears to be closing properly. What can be wrong?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Also, often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 15, 2010
Drum is having trouble turning
unplug the dryer before you start ,check roller & pulley or install dryer kit
Oct 18, 2017 | Kenmore 72972 Gas Dryer
Pitch light pulsates when i press start
the pitch adjuster is supposed to blink that is how you adjust the pitch. hope i understood your question right.
Jun 15, 2012 | Panasonic Technics SL-1200MK2 Turntable
The power light stays red and if pushed to go on, only blinks red. There is a high pitched sound when it is plugged into the wall. I've tried unhooking the box from the antennae, the tv, and the wall...
Sounds like you have a high voltage issue with the power supply. The blinking light is actually a trouble code and some of these can be found in your manual, others can be looked up on the web if you type the make and model of the set and the number of blinks you should be able to track down the issue. If your not comfortable about working on the set then you will ned a repair person to check out the power supply and other boards on the set.
Jun 25, 2011 | Televison & Video
My dryer(LEW0050PQ2) power button appears to operate and red button comes on when power button is pressed. But when the start button is pressed-there is a high pitched tone and the red light starts to...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 15, 2010 | Whirlpool LEW0050P Electric Dryer
Hitachi Ultravision won't turn on
it is the power board in the tv hase some bad capasators in it but can cost some money to fix if unsher how to do it on your own if you live in central new york i do have my own shop and im cheep but i can not warenty any thing but i can help 315-280-0508 storm electronics ask for corey
Aug 04, 2009 | Hitachi UltraVision 42HDS52 42 in....
DS lite's wierd noise.
when it rings is it your birthday? if so then thts the case cuz when its your birth day the opening ring sound high pitched
Jul 10, 2009 | Nintendo DS Lite Console
High pitched noise red light blinking
A high pitch noise comes normally from blown capacitors from the motherboard or the power supply. But mostly high pitch noise comes from power supplies.
You could have to open up the power supply to see them.
Verify if it is the case and replace the faulty part.
May 26, 2009 | Dell PowerEdge 1800 Server
Whirlpool LEW0050P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
