Question about Maytag Kitchen Ranges
On a Maytag range, what does F3 mean? When I try to preheat the oven, F-3 appears, it beeps, and then shuts off.
  • 1,711 Answers
F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Posted on Oct 04, 2010
What does error code F3 mean?
not sure but here is the tech service manual GE JB960 Technical Service Manual
Feb 19, 2015 | GE Kitchen Ranges
JSP26GP code f3 then f2
What is the complete model number of the unit?
Dec 08, 2012 | GE Kitchen Ranges
F3
F3
or
F4Shorted or open oven temperature sensor (RTD)Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Read more:http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Maytag Range / Stove / Oven Fault Codes#ixzz1kNxJMSok
Hope this helps you :)
Jan 24, 2012 | Maytag Ovens
F3 appears and it beeps when I try to preheat the oven
The F3 error code means that the oven temp. sensor is shorted out....this tip i wrote explains in more detail what the F3 means and what to check. http://www.fixya.com/support/r10343697-error_codes_f3_f4_mean_oven
GENE
Sep 13, 2011 | Maytag Ovens
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
I put the oven on to preheat and it started beeping. I'm getting an error message of F 3 then the oven shuts off The range is 17 years old and I don't have the manual.
Hi
F3 error means the issue is with the oven temp. sensor that is bad and you need to replace it. You can test the oven temp. sensor for 1100 ohms and if the reading is more then 1100 then it should be replaced, else it is the ERC (range control) that should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jan 19, 2011 | Kitchen Ranges
How do I activate the Shabbos (Sabbath) Mode.
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Oct 22, 2010 | Maytag MER6772 Gemini Electric Kitchen...
What does F3 mean when the oven is on. After preheating it starts beeping and then F3 pops up
F3
or
F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Sep 06, 2010 | GE Spectra JBP78 Electric Kitchen Range
How do i get rid of a 5a6 6ath maytag stove on screen. I have unplugged and replugged after several minutes - still oven does not function at all...help!!!
To
ARROW pad.
"3".
shut-off.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Aug 18, 2010 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
512 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
