Question about Garden
We are adding a light and need to know how to put in this wire into the transformer box? We do not have the box or instructions for our Hadco Landscape Transformer 30600. A diagram and instructions would be very helpful.
  • 377 Answers
Could not find that exact transformer number, but if you go to this URL you will see transformers that are most likely similar to yours or you can contact Hadco/Phillips.
http://www.hadco.com/Hadco/Public/SearchVisual.aspx?FamId=24
As long as you are using the proper voltage bulb, you should not have a lot of difficulty hooking it up.
Feel free to contact me in the event you run into problems.
Posted on Sep 15, 2010
Can I wire 3 Utilitech 3000K recessed gimbal LED lights in series without any power or heat problems?
Short answer: yes but if you wire them in series when the one closest to the power source burns out the others will not work. Electricians wire all light fixtures in parallel. I think you really want to know if you can wire 3 led lights on the same circuit without any issues. Two things to look at 1. box the gimbals came in will tell you how they are rated for installation. Some can be put against insulation, some cant. 2. As far a power is concerned...I am assuming this is a residential install so you need to check what if anything is on the circuit with the LEDs. Hooked up by themselves will not cause any power issues. But adding them to an existing circuit may. If they are going to be added to an existing circuit you need to find out what else is on the circuit so that adding the LEDs will not overload the circuit.
Oct 08, 2017 | Hardware & Accessories
I want to use this Transformer to power my 12 volt lights in my trailer using a 7 blade connector that is already installed on my trailer. How do I connect the wiring n the ac nle
The two wires are meant to be connected to the 120 volt source. The box or the papers with the transformer should tell you which two of the three wires provides the 12 volt output. If not connect the two wires to the 120V source - Be CAREFUL! - 120V is dangerous. Then try, one at a time, touching each of the three combinations of wires (1&2, 1&3, 2&3) to the contacts on a 12 V incandescent lamp (very bottom and threaded side) the 12V pair will give you the brightest light. The other two are 6v.
I can't address the 7 blade connector without more information. I suggest that you go to a place that sells trailer parts.
Not knowing anything about your trailer I don't know if a 2 amp (2000 ma) transformer will supply enough current to do the job.
Nov 19, 2013 | Philmore TR212 12 Volt AC Power...
Landscape lighting transformer hums only when controlled thru photo-cell, and not when powered directly.
1) Copy following link for Intermatic/Malibu power pack photo-eye instructions, general troubleshoot, manuals, replacement trippers, and tips to prolong life of power pack:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
2) Brand and model of transformer and photo eye are unknown.
Wiring changes are unknown.
Volt rating of photo eye is unknown.
Wiring of photo eye is unknown.
3) Add a comment including details, and attach photo, after reading information on link above, for live response Jan 2013
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jan 01, 2013 | Home
Using Lowes mechanical timer in Hadco TC654-15 landscape lighting transformer. Have tried 3 timers now and timer clock does not work when plugged into the transformer. if I bypass the timer, low voltage...
Always a good idea to check outlet with cheap circuit analyzer.
And move timer to different outlet to see if difficulties are outlet-specific.
Try timer at neighbor's house.
Having 3 defects in a row is unusual.
There are no repairs for defective timers.
Timer clock motors stop working for many reasons, bad manufacturing of plastic gears and power surge and dirt and reversed polarity among the causes.
Using household plug-in timer is typical solution since clock modules are not sold separately.
Following link gives tips for having low-voltage power pack last longer, in case you decide to buy Intermatic-Malibu from Home Depot:
Aug 31, 2011 | Hadco TC151-12TP Accessory Transformer
I have a hadco timer that needs to be reset....where can I learn how to do this?
Hadco T6 looks like Kitchler 15558WH
http://waterheatertimer.org/pdf/Kitchler-15558WH-timer.pdf
There are several brands of timer that look same-similar:
Open following link for images and manuals:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59377
Add a comment and say which manual matches Hadco timer.
Jun 15, 2011 | Hadco Digital Timer Model T6
I hooked up a coleman electric furnace to a janitrol condenser heat pump . The t-stat wires on electric furnace are red white green and yellow. I added a blue for common off of transformer for digital...
Hi, first of all you need to get a hand full of 5 amp auto type fuses and install one on the hot leg of the 24 volt secondary side of the transformer. Just use 2 female crimp on connectors and put the fuse in the middle of the hot wire. Saves $$$$ on replacing transformers when you have a dead short on the low or high voltage side of any transformer, just a trick of the trade, food for thought. Fuses are much cheaper. On your electric unit, you may not need the common on this to operate the digital stat if it has batteries. This may be your dead short. On the Janitrol condenser, the red is your 24v as you no. They are using blue in place of yellow for cooling. Red is hot, W is heat, G for fan, and blue is cooling on this Janitrol. Keep in mind you are connecting to a heat-pump also, so make sure the wiring is correct. Are you installing this for secondary Heat?? More then likely, the blue common you have added is the dead short as the janitrol uses the blue for a cooling relay in place of yellow. Anyway, use the 5 amp fuse, trick of the trade to save on the transformers. Please keep me posted, as I know know you have this under control.
Shastalaker7
A/C, Heating, & Refrigeration Contractor. Good Luck!
Feb 09, 2011 | Coleman Heating & Cooling
How do I get a manual for the use of a Hadco T5 analog timer?
Follow the below link to the Philips HADCO website where you can download the instruction sheet. I would have attached but was unable to do so.
Thanks !
http://hadco.com/Hadco/Public/ProductDetail.aspx?pid=280&s=t6
Nov 20, 2010 | Garden
I have a black red yellow and green wire on a combination fan controller and light dimmer,which wires do i hook up to my switch line and feed line in my wall box....thks in advance
You have new wiring device.
Device controls fan and light.
To control fan and light separately from wall box, requires a separate wire to each Load.
So box requires one wire going to fan, and a separate wire going to light.
If previous switch has just two wires that controlled both fan and light, and then fan is controlled with pull-chain, it sounds like new device requires another wire be added to circuit.
Add a comment and say how many cables enter wall box, and say color of each wire in each cable.
Without knowing exact wires in your box, or exact device ... I can suggest answer based on typical wiring.
Compare this answer with instructions that came with device.
How to wire fan-light device:
-Device-green wire always connects to bare copper wire
-Device-black always connects to black Hot wire from breaker
-Device-red usually connects to wire going to light
-Device-yellow usually connects to wire going to fan
Nov 18, 2010 | Cooper Lighting Lighted Switch
I removed my nutone door chime transformer a while ago to work on an electrical problem. Now i want to reinstall it but don't have the instructions. The transformer reads nutone class 2 LR2982 10va 16v
I couldn't find a manual for the LR2982, so I'll give a general description of how to wire a door chime. Most chimes have 3 contacts. F (Front), R (Rear) and C (Common). Some have just two contacts. If your chime has more than 3 contacts do _not_ follow these instructions.
Inside the junction box on the wall where the chime will be mounted, you should have at least 2 cables (usually brown) each, with at least two wires (usually red and white) each. One of those cables goes to the transformer and the other cable goes to the door button.
The beauty of it is that since it's only 24 volts or less and _polarity_ doesn't matter, you don't need to know which cable goes where for a _single_ door button scenario.
For _single_ door button wiring, pick a wire (say the red) from one cable (doesn't matter which cable) and connect it to the "C" contact on the chime. Pick a wire (say the red) from the _other_ cable and connect it to the "F" contact on the chime (if the chime has 3 contacts). If the chime only has 2 contacts connect it to the only contact that is left.
Then all one needs to do is twist the 2 remaining wires together (both white) and cap them off with a wire nut.
If your junction box for the chime has 3 cables in it, the extra cable goes to a rear door button. In that case you _do_ need to know which cable goes to the _transformer_. You can pick up a cheapo voltmeter for about $10 just about anywhere. The cable that reads anywhere from 16 to 24 volts AC between the red and the white wires is the cable that goes to the transformer.
Make sure one of those wires from the transformer goes to the "C" contact (pick one, say the red). Now you know the 2 remaining cables go to the front and rear door buttons. For now, just connect a red from one of the remaining cables to the "F" and one red from the other remaining cable to the "R". Then just twist the 3 remaining white wires (including the white wire from the transformer) together and cap them with a wire nut.
If the rear chime sounds when the front door button is pushed, just swap the wires on "F" with the "R"contacts..
May 13, 2010 | Broan-NuTone Door Chime Kit by NuTone
I added a light kit to my ceiling fan using the enclosed instructions however the bulbs burn very dim. The wiring seems solid (grey to white(light kit) and red to black(light kit).
Soundes like you might have a loose or broken nutral wire(white) in the box where the fan is wired in. check that. If that is all wired right then look at the conections where you pluged in the fan. may be bad conoctors. Let me know. Happy to help.
Apr 06, 2009 | Hampton Bay 24002 Ceiling Fan
Garden Logo
111 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
