Question about Jet 3 Ultra Power Chair
WHEN I TURN THE POWER ON, THE SPEED SELECTOR IS THE ONLY THING THAT COMES ON. IT HAS 5 DOTS THAT SELECTS HOW FAST THE CHAIR WILL GO. ONE DOT BEING THE SLOWEST AND 5 DOTS BEING THE FASTEST. WHEN I TURN THE POWER ON IT WILL LIGHT UP ONE THEN TWO THEN THREE THEN FOUR THEN FIVE DOTS AND THEN IT WILL SHUT DOWN ALL POWER. WHAT SHOULD I DO???
  • 692 Answers
Abrams I would start with the batteries. If you have a digital voltmeter set it to 200 volts dc and plug the meter into the 2 outter holes on the charger port located under the front of the joystick. Fully charged the voltage should read 24-27 volts. If you are not getting this voltage then replace the batteries It requires 2 U1 batteries. Hope this helps
Posted on Sep 15, 2010
Where is the bold key
The 8014S does not have a BOLD key. However, you can do two things to make your print darker:
(1) Set the Impression Control Switch (three dots located above the 10/12/15 selector) to the largest dot.
(2) Turn on double-strike mode by simultaneously pressing the ESC and O keys. (To turn off double-strike mode, simultaneously press the ESC and & keys.)
To find out more about your typewriter, purchase a manual for $10.00 at:
Swintec Typewriter PDF Operations Manuals 10 emailed
May 09, 2014 | Swintec Office Equipment & Supplies
Anyone know what dots on the platter should be still at 33 or 45 rpm, never been told or shown, tried adjusting them manually one day, now i have dips on both pitch controls and its not helping my cause
The large dots tend to be for 33. Records will not maintain constant speeds as they play so you have to get it the nearest you can. You can keep adjusting it, but it's only needs to be done if you notice the loss of speed or increase.
There are 4 sets of dots due to the variation in power. 50 or 60 HZ. You select the dots for your national grid output.
Mar 09, 2013 | Audio Players & Recorders
I can't unlock my Nextbook Premium 7.
pls hw can i unlock my arnova 7b 9 dot pattern
Sep 20, 2012 | Nextbook Tablets & eReaders
Will dot 3 brake fluid create an ABS error code?
if your car uses dot 4 brake fluid it is compatable with dot 3 fluid.if it requires dot 5 then the fluid will have to be changed and possibly flushed as dot 5 is not compatable with dot 3 or4 fluid.at any rate it will not cause the abs light to come on if its not dot 5,as the wrong fluid mix can cause seal swell in the system which could cause the abs light to come on.
Dec 03, 2011 | 2001 Volvo V70
White "press dot" screen
The actual answer is to press the dots, but use a dull plastic tool that fits "within" the dot. Otherwise the width of your finger is too imprecise to calibrate the dots and screen.
Hope you, and others, get this and try it. It works. I just discovered it and did it, successfully after only about 10 presses.
Jul 21, 2010 | Garmin Nuvi 660 GPS Receiver
One red dot,no flusing but the chair doesn't move
You need to replace the batteries. Have the batteries load tested just to be sure.
Dec 09, 2009 | Jet 3 Ultra Power Chair
How to set alarm and how to turn it off so that it is not used.
To turn on alarm, switch the selector lever to "Wake" and adjust the time shown. Then, switch the lever back to "Lock" and push the "Wake Mode" button until you see the selector dot (located on the bottom right of the time display) change to either the music or bell symbol; depending on how you'd like to be awaken.
To cancel the alarm, simply hit the "Cancel" button once, then press the "Wake Mode" button until the selector dot disappears.
Mar 10, 2009 | GE 7-4837 Clock Radio
Jet 3 Ultra Power Chair Logo
42 people viewed this question
Top Jet Health & Beauty Experts
Colin Taylor
wcdoc1953
wcdoc1953
MobilityRepairSpecia...
Level 1 Expert
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
