Payne furnace installation manual - Heating & Cooling
Hey there. first timer hook in up a payne furnace (no ac) to a analog thermostat (no c receptacle) using a standard 14-3 wire. 3 amp fuse blows every time before fan even kicks on. furnace control panel...
hook up r to r, w to w, leave the rest alone for now until someone can see what you have done. If the furnace has a sparker or hot surface ignitor, set the heat anticipator for .8 amps. not .4 or less.
Nov 15, 2014 | Heating & Cooling
New Payne Furnace PG95SAS How to hook up wires for powering
MOST UNITS HAVE KNOCK OUT WHERE THE POWER GETS HOOKED UP, HANDY BOX WITH A SWITCH NEED TO BE ATTACHED, MAKE SURE YOU ARE USING A GOOD GROUND, AND HARD WIRED NOT AN EXTENSION RUNNING TO AN OUTLET.
Dec 08, 2013 | GE 1/3 Hp Furnace Blower Motor...
FURNACE LITES UP RUNS FOR 2 MIN. SHUTS OFF GAS.PAYNE
Carrier had a recall years ago on the HK42fz004 & I believe the 008 models because of intermittent problems like yours. Sounds like you need a new board
Jan 02, 2013 | Carrier Furnace Control Circuit Board...
Payne air handler with possible GE X13 Failure
Check your dip switch settings on tonnage and your CFM per ton settings. Also make sure they wired the the low voltage for cooling to Y and not YLO if its a single stage compressor system.
Sep 23, 2012 | GE Carrier Bryant Payne 1/2 Hp 115 230v...
My Payne furnace is NOT producing the desired heat anymore. Any ideas?
Hello, it could be shutting down on it's high limit switch due to a dirty air filter, dirty blower wheel, weak blower motor. Usually this would cause the furnace to shut down before it reaches the desired temp.
Dec 30, 2011 | Heating & Cooling
I have a weatherking model number waka-037jaz just bought this with a payne furnace from a gentelman who said they worked together when he removed them but furnace doesn't have an A coil in it how do u...
The furnace can handle three tons of AC but you will need a coil and a line set to connect the two. Get a match coil for your furnace and a line set. 7/8 and 3/8 plus tstat wire and tstat. Sometimes you get stuck buying used equipment and it cost you more in the long run. I have owned a company for 44 years and I never never sell used equipment.... If you need help write back I will be glad to help you. RUSS
Jul 18, 2009 | Heating & Cooling
Heating & Cooling Logo
493 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
