Question about Kenmore Sewing Machines
The motor makes a whirring noise but the needle isn't going up and down as fast as it should. It does a few stitches slowly, then pauses, then I have to get it going again, etc. But all the time the motor is making a noise as if it's trying to get the needle moving, but can't.
  • hkgingrich Sep 14, 2010
    Is there anything I can do about this myself at home, or will it take a repairman to do it? About how much will it cost?
    President:
  • 1,932 Answers
This is because the belt connecting the motor and the sewing machine might go lose which makes it to slip.So please change the belt and it will be fine.
Thank You
Posted on Sep 15, 2010
  • 2,299 Answers
It sounds like the drive belt is slipping.
Posted on Sep 14, 2010
Tl2000 and it is skipping stitches while quilting. I have changed the needle. I used needles 14 16 & 18 I have cleaned the machine. When I sew seams I have no problems.
Have you changed the type of needle--top stitch, embroidery, microtex? Sometimes that will help. Also, my skipped stitches occur in FMQ because the fabric is moving too fast for the machine speed or I have a jerky movement. It helps me to try slowing down the fabric movement or speed up the machine and practice making smooth, consistent movement. I've never done FMQ with a needle larger than an 80/12, so you might try a smaller needle to reduce the fabric grabbing the thread.
Skipping the Skipped Stitches in Your Free Motion Quilting
Skipping Stitches
FMQ Troubleshooting Tips Tricks
Oct 31, 2017 | Sewing Machines
Can you use twin needles on bernina 1080
I have a Bernina 930 Record that will take twin (even triple) needles, so I don't know why your 1080 wouldn't. Just be sure your machine does not have the straight stitch plate on it, that your presser foot can accommodate zig-zag stitch, and that you carefully adjust any zig-zag stitch width so the needles do not hit the presser foot or stitch plate. I'd suggest installing the double needle and then carefully hand rotate the handwheel to see if the needles will hit anything. If you can make a full rotation of the handwheel without anything hitting, then slowly try it with the motor engaged.
Feb 23, 2015 | Bernina Sewing Machines
My Juki MO-655 serger will sew a few inches then the needle thread becomes disengaged in the stitch process. The machine will sew a few inches more then stops making stitches. I have cleaned the thre
Make sure you are threading the machine correctly. Make sure you are using serger thread that isn't old. Make sure you are undoing all the threads when it breaks and thread it from the beginning.
Make sure you have the right needles in their respective places. My Juki MO has two different size needles.
Sep 02, 2012 | Juki MO-655 Mechanical Sewing Machine
The machine isn't making stitches. It's threaded correctly. I have been sewing leather recently and it's been acting up since then. I have cleaned the bobbin area. And have adjusted the tension...
Hello
Adjust the Stitch Length;
To make longer stitches, set the stitch length to a higher number. On many sewing machines, four is the longest possible stitch length and two is average.
To make shorter stitches, set the stitch length to a lower number. At a zero, the sewing machine may not actually make stitches, since the needle will go up and down in one place.
Cut a small scrap of fabric, preferably the same type you want to sew with.
Sew a few test stitches on the scrap. Examine the stitches to make sure they're the length you want.
Adjust the stitch length again as needed.
Jul 12, 2011 | Singer Sewing Machines
I change the presser, for a walking foot, and the nedlee started to stucked, and then I change for the presser again and now doesn't sew at all, now only sew a few stitches and then the tread loses both...
This sounds like you have one of two things going on:
1. the tension, probably upper, is too tight or the thread is looping or catching along the way somewhere...ie threading isn't right
and
2. the needle is bent.
Try rethreading and check the tensions and then also make sure and try a different new needle. Make sure the stitch type is set right for the presser foot too! :)
May 04, 2011 | Brother Sewing Machines
I have a Singer 7462 and when I try to load a bobin, the machine makes a nasty grinding noise and the needle slowly moves up and down and ultimately all of the lights on the stitch selection panel flash...
Ok, this is pretty common. Disengage the machine (as if you were winding a bobbin) run the machine at high speed for 5 minutes.
The motor is dirty and this will clean it out. You should hear the pitch of the motor change as the minutes go by.
Aug 24, 2010 | Singer 7462 Mechanical Sewing Machine
Pfaff grand quilter 18.8 with Q-Bot, and having problems with the stitch regulator. Anyone else have this problem? Any solutions?
the up and down buttons are not working properly. When pressing the needle down button, the needle does go down and then comes right back up. pressing the needle up button makes the needle shoot up and down 2 times very fast. HELP
Oct 07, 2009 | PfaFF Sewing Machines
Designer 1 stops sewing in the middle of long run of decorative stitch
sounds like the motor belt came off the machine, your description makes that sound exactly like what the problem is.
Aug 12, 2008 | Husqvarna Viking 1
Sewing Machines Logo
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
