Question about Garden
Lawn mower runs when I use jumper cables at the starter. Brake does not work but needs to be pressed in to start. When you turn the key with out jumper cables it makes a click noise under the rear end but does not start, only at the starter with cables..What do you think it is. When it starts it runs great.
    Problem Solver:
  • 16 Answers
I would check the starter solenoid if it is bad it wont make an electrical connection to make the starter work.
Posted on Sep 15, 2010
Motor will not turn over on xmark riding lawn mower
use a pair of jumper cables and go direct from the battery to the starter if it starts start checking your safety switches starting with the clutch/brake pedal
Sep 23, 2012 | Garden
My briggs and stratton 13.5 HP engine will not start
try and use jumper cables and jump the battery cables a bad one will draw to much amprage
Jun 01, 2012 | Parks Optical 13.5hp Briggs And Stratton...
Removing starter on vangraud 14hp b&s
take a pair of car jumper cable and jump from the battery to the starter if it cranks over take a look at your safety switches start with the one on the clutch/brake pedal
May 26, 2012 | Mtd Garden
I replaced the starter on my scotts lawn mower but wont start
can you turn the engine by hand? if you can use a pair of jumper cables like you would a car and connect from the battery and the block and starter sometimes the cables go bad a draw a lot of amps threw the cables
May 03, 2012 | Garden
Motor will not turn over by the key switch on my cub cadet lt 1045 but it will if i run a jumper from the battery to the starter post
When you jump the starter, you are bypassing the safeties.
Check the neutral/brake safety and the blade disengagement safety.
Gary
Jul 18, 2011 | Cub Cadet Garden
Mower was running for 15 minutes and I did a couple passes in the lawn, needed to get off for a minute so turned mower off...it will not restart. All I hear is a click when I turn the key.
I would check and clean battery connections and cable from positive terminal to solenoid and from solenoid to starter.If after every connection is clean check voltage from battery. It should be around 12.5 -13 volts d.c.. You can try to jump start it by hooking up jumper cables and make sure that it is in neutral,set break or hold down on brake pedal to close safty switch.You can manually engage seat safty switch and try to start. If it still does nothing but click I would replace battery and/or solenoid. I hope this helps you. Thanks.
Jun 25, 2011 | Garden
My mower wont start...i replaced the battery and it just clicks
Have a friend jump start the mower while you a seated on it. Turn the key to the "on" position. Connect the black jumper cable from a known good battery to a good ground on the mower and the red cable directly to the electrical connection of the starter. If the starter does not engage, it is faulty.
Apr 18, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Nothing happens when you turn on the lawn mower key for craftsman mower model 917 272072. I put a new battery in the mower, and new switch and a new solenoid switch but the mower don't make any noise when...
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
Apr 16, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Troybilt riding lawnmower - won't start
i have a troy built riding mower, just replaced battery, when i turn key sounds like battery is dead. what could be the problem?
Aug 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Snapper riding lawn mower won't start
my snapper riding mower will spin but will not start. It was o.k. when I parked it a week ago. Now it won't start 28115BV
May 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
162 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
