Error-checking problems for vista 64 bit on windows partition
Im scheduleing to check for hard disk errors when i restart my comp and after is starting to check it just not going enywere from 34% of freeing cluster i left it for 2 days to run my hard drives are good second new pc same problem with thw first one is an hp m9250f
    Master:
    Sergeant:
  • 461 Answers
This might be some problem with your registry.. There are plenty of software can check this.. I suggest you try to look into below link to further understand the registry issue.
http://etech.maiila.com/?p=24
before checking for registry you may need to first clear some temp. file using disk clean up facilities....
all the best.
P/s : please don't forget to rate me.. :)
Posted on May 16, 2008
Cyclic redundancy check
A cyclic redundancy check error on a hard disk means that part of a file read from the hard disk doesn't match the expected value.
A cyclic redundancy check error, in other words, means that files on your hard drive are corrupted.
Repair a cyclic redundancy check error on a hard disk using the Check Disk tool in Windows.
Click "Start" and click "Computer."
Right-click the hard disk with the cyclic redundancy check error under "Hard Disk Drives" and click "Properties."
Click the "Tools" tab at the top of the hard disk "Properties" window.
Click "Check Now" under "Error Checking."
Select "Automatically Fix File System Errors" and "Scan for and Attempt Recovery of Bad Sectors" in the "Check Disk" window by clicking each option if it isn't already selected.
Start a disk check and repair by clicking "Start" in the "Check Disk" window.
Click "Yes" if the "Do you want to schedule the disk check to occur the next time you restart the computer?" prompt appears.
A disk can't be checked if it's in use, so you'll need to restart Windows to check it.
Restart your computer by clicking "Start," clicking the arrow icon to the right of "Shut Down" and clicking "Restart."
(External drives will not schedule to happen on restart it will happen straight away.)
Sep 09, 2013 | Verbatim 500GB USB Desktop 500 GB Hard...
Cyclic redundancy error
How can I fix Cyclic Redundancy Check on external drive?
This problem is caused by bad sectors on HDD. refer to http://www.goodlucksoft.com for more information
Feb 20, 2013 | Computers & Internet
Hard disk cyclic redundancy check
Fix a Cycle Redundancy Check Error
The "Cyclic Redundancy Check" error is a Windows error message telling you there's a problem reading data you're trying to access.
The root of this problem could either be a damaged storage device or a corrupt file.
Windows has built-in tools to attempt to fix to this problem, and avoid further errors.
Click on the "Start" menu in the bottom left-hand corner and click "Run."
Type in "cmd" and press "Enter" on your keyboard.
This will open a black command prompt box.
Type in "chkdsk /f" and press "Enter."
If you receive a message saying the disk will be checked the next time the system starts, press "Y" and then "Enter."
Restart your computer by closing the command prompt box and selecting "Shut Down" from the Start menu.
Wait for the disk scan to reach 100 per cent.
This may take awhile.
When it completes, your drive errors may be fixed.
Avoid future problems with this type of error by replacing the file that caused the problem.
For example, if you got the error when using a text document, open the document and copy all the text (press "Ctrl" and "A" at the same time and then "Ctrl" and "C" at the same time).
Create a new text document and paste the text in by pressing "Ctrl" and "V" simultaneously. Save the new file, and delete the old document.
Hope this heps
Nov 02, 2012 | Ultra 0471 Seagate St3500418as 500gb Sata...
What is the solution to "Exception EOleSysError module at 00058E75."
Try this:
Run a CheckDisk:
How to run Chkdsk at the command prompt
(Windows XP)
  1. Click Start, and then click Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
      Windows Vista & Windows 7
      You can launch CHKDSK using two methods (the former being the easiest):
      Graphical Interface:
      Open the Computer option from the start menu, which will display all of the drives available to scan on your PC:
      Then, right click on the drive you wish to scan for errors and select Properties:
      Now click the Tools menu, then Check Now under the error-checking section:
      You have several options within the check disk tool. It is always recommended you leave the "automatically fix file system errors" box checked, as this repairs and problems found. If you want to perform a deeper scan, tick "scan for and attempt recovery of bad sectors". This second option takes longer, but is worth doing if you suspect a drive problem. Once you are configured, click Start:
      If you try to check a disk that is currently in use, you will receive a message asking if you wish to schedule a scan. Accepting this will perform the scan next time you restart your PC:
      Good Luck!
Aug 17, 2012 | Computers & Internet
I cannot play my games after i reformat my computer. its say that i need an directx 8.1 or higher to play my game but i already downloaded directx 11 but is useless. nothing happens. same error message...
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
If it's a ntdll.dll error the ntdll.dll error only displays when you use a specific software program,
uninstall the program, reboot your computer, and then install the latest version again from scratch.
until you know what the problem is you cant fix it or you might try
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive this should schedule to happen
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
hope this helps
don't forget to vote
when you restart your computer then defragment your hard drive
you should not do anything while the chkdsk utility is in progress any imput may damage your computer also do not start if there is a possibility of a power failure (storm lighnining)
hope this helps
don
Feb 20, 2011 | Microsoft Windows 7 Home Premium 64BIT...
If i erase my hard drive will it remove all traces of infections on my computer and can i install windows7 instead of reinstalling vista
Hello, Yes if you reformat your hard drive, it will remove any virus software that would be on it. Windows 7 have a recommended minimum pc configuration. Make your pc is up to those configurations.
  • 1 GHz processor (32- or 64-bit)
  • 1 GB of RAM (32-bit); 2 GB of RAM (64-bit)
  • 16 GB of available disk space (32-bit); 20 GB of available disk space (64-bit)
  • DirectX 9 graphics device with WDDM 1.0 or higher driver
Hope this helps
Jan 30, 2011 | Acer EXTENSA 54205038 COMPATIBLE LAPTOP...
What is disk checklist utility
The disk checklist utility checks your disks for integrity, bad sectors, and can recover information. In order to check a disk in Windows Vista, right-click on the disk in question and choose Properties
On the Properties page, click the Tools tab and click Check Now on the error checking region to run it.
Tick Automatically fix file system error and Scan for and attempt recovery of bad sectors checkboxes and click Start.
You cannot check the disk while it is in use. You can perform a disk check the next time you restart your computer by choosing Schedule disk check.
Figure E.
Upon restart, (Figure F) the chosen disk is checked for errors and repaired if needed.
Jun 23, 2010 | Microsoft Windows Vista Ultimate Edition
When installing the computer back to its original settings. The systems will freeze when it gets to the point of checking the mouse. But in the beginning of the process the mouse is fine. I was told that...
Sounds like a virus. You might have to erase your hard drive and reinstall windows. If you have a boot disk that came with your computer, it will reinstall the entire system as it was when you bought it. You will need to save any files you want to keep first on a separate drive or burn to CD before you do it though.
Another option is to run check disk. Here is the instructions:
Manual steps to run Chkdsk loadTOCNode(2, 'moreinformation'); Notes
  • Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
  • Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
  • Chkdsk might not accurately report information in read-only mode.
Manual steps to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then Run.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N) Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
Manual steps to run Chkdsk from My Computer or Windows Explorer loadTOCNode(3, 'moreinformation');
  1. Double-click My Computer, and then right-click the hard disk that you want to check.
  2. Click Properties, and then click Tools.
  3. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  4. Use one of the following procedures:
    • To run Chkdsk in read-only mode, click Start.
    • To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer? Click Yes to schedule the disk check, and then restart your computer to start the disk check.
The following table lists the exit codes that Chkdsk reports after it has finished:
Collapse this tableExpand this table Exit code Description 0 No errors were found. 1 Errors were found and fixed. 2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified. 3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
For more information about Chkdsk, visit the following Microsoft Web sites: For more information about Chkdsk, click the following article number to view the article in the Microsoft Knowledge Base: 314835 (http://support.microsoft.com/kb/314835/ ) An explanation of the new /C and /I switches that are available to use with Chkdsk.exe For help with common system maintenance tasks in Windows Vista, visit the following Microsoft Web page: Fix problems with common system maintenance tasks (http://support.microsoft.com/gp/system_maintenance_for_windows)
Dec 07, 2009 | Gateway Computers & Internet
Continues rebooting
OK it is going to be difficult to solve this one with so many different errors. Given that this is windows Vista it is probably a bad driver. Possibly the graphics card driver. Also vista is quite punishing on hard disks so we'll start there.
First off take a backup of all your documents photos videos etc. because the check disk can cause havoc if it finds a lot of errors and can take down windows altogether. Also you must be prepared to re-install windows so make sure you have a recovery method (recovery CD's or a hidden partition on the Hard Disk) If the hard disk is truly borked though it might take the hidden partition with it. Proceed with caution and make sure you can get the PC back up and running if the worst happens.
First run a check disk. In My Computer, right click on the c drive, click on properties - tools - check drive for errors, then restart your computer and let the chkdsk run.
Post back here with the outcome.
Sep 10, 2008 | Microsoft Windows Vista Home Premium with...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
