Mitsubishi VS-45607 45" Rear Projection Television Logo
Posted on Sep 14, 2010
Television wont turn on. noticed timer light was lite, then television would not come on, with remote or manually.
  • Anonymous Sep 30, 2012
    Where is the reset button?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Nov 27, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
495
Points
Does the green LED light flash on/off forever? Did you try the reset button?
The television wont turn on manually. there is no longer any remote control. The timer light stays on.
wish ko lang gusto ko sanang mkuha address nyo kc gusto ko pong mg sent ng letter asap thnk
Hl-s4266w Powers on for about 15 seconds then turns off. Was told it is a timer that needs to be turned off by using factory remote - I have lost the remote! now what?
Not sure about the timer. Our 55" samsung broke last week and it was shutting on/off no picture just turn on music recycling off/on. The blue light was lite on TV and red light to the right was blinking. The TV repair guy replace the Power Supply board b/c of swollen capacitors, was under warranty. The board runs about 70 bucks though. Took him all of 5 mins after unscrewing the back cover of TV. The board is at the bottom center after cover is removed. Hope this helps
1helpful
Red lamp lite on and how to reset lamp hour meter?
turn your tv on. on the tv it self press and hold the " - " like your turing it down. then on your remote press and hold the number " 0 " for five seconds. it should say the the meter has been reset to zero.
Tv wont turn on
disconnect the tv from the wall first for a few minutes,like 15 or 20 and then plug it back,lets see what happen
good luck
[email protected]
Timer light is flashing but tv wont turn on!
When the timer light stoped flashing the remote control would not turn on the TV. The next time the light quit flashing I held the power button in on the TV for about 5 seconds and it came on and has had no problems since then with the remote or the local TV power button.
Greg Allen
2helpful
Akai problem
You have a bad power supply. Just replace it and you should be good to go. The green light may come on the black box, but the supply is putting out a low amp value.
2answers
Picture went off still had sound then i turned off at panel now only red timer/standy stays lit sony 61" projection
First plug in again and look at led light, the amount it blinks tells what is wrong. Then if it stays lite it tells something also. You can try Display-channel 5-volume +- Power(service mode). Then Channel 8-enter(test reset). If this doesn't work then you will have to replace somethings like F601, R607, Q601, IC601, R612, VDR601.
2answers
Timer continuously on.....tv won't turn on
I had a simliar problem and just left teh set plugged in overnight and the next afternoon I noticed that teh remote red LED was not on anymore and tehn when I used the remote the set turned on!
3helpful
2answers
Jvc av-32fa44 television
My JVC AV-32FA44 wont turn on. the on timer light blinks. When i unplug it and plug it back in i get beeping (i stoped counting at 50 beeps) then it stops and the light just blinks.
Timer circuit will not let the set come on.
Remove the power from the wall and plug it back in after 15 minutes,this will reset the microprocessor and it might get back to normal,let Us know how it goes and if you need more information.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
