Question about Dell E173FP 17" LCD Monitor
Hi, I had the flashing green light. I replaced a couple of components on the power board and now I have the top half of the screen on but the buttom half turns on but has lines and a bunch of colors and still no picture.
  • 11,361 Answers
Please check to see if the T-CON ribbon cable is properly attached.
Did the transistors (C5706/5707) short out? Cold soldeer joints.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Replacement board: http://www.lcdrepair.us
Did it look normal before the monitor went out?
Posted on Sep 15, 2010
  • 3 more comments
  • Ahmose Avin
    Ahmose Avin Sep 15, 2010
    yes I replaced the 4 5707 transistors, 2 other transistors and a soldered on fuse I believe. It came as a kit. The monitior was fine before. Not sure if it was something I did when I took it apart or if the board was worse off then I thought. I have the top have working fine, its just the bottom half thats acting up now. please help.
  • Bud Martin
    Bud Martin Sep 15, 2010
    Try reseating the T-CON connector located on the back of the LCD panel (there is a ribbon cable between the logic board and the LCD panel).
  • Ahmose Avin
    ok so I did what you said and still the same. I get a picture on the top half and the bottom half is full of lines and colors. I smell a scent coming from the power supply board. Can this be the panel itself or is it just a bad board. please help. I was smelling this before I changed the components out and still smell it. The monitor worked fine before it went out
  • Bud Martin
    Yes, it can be a LCD panel problem, it can be co-incident the the problem happens after you repaired the backlight inverter circuits section which has nothing to do with the lines you see on the screen. Send me pictures of the board and the screen if you want so I can actually see what ith looks like, budmrtn@aol.com
  • Ahmose Avin
    ok I just sent you some pictures on whats going on.
POLAROID P40LCD12 SCREEN AT BOTTOM COMES ON BLUE FADES THEN GOES GREEN ABOUT 5 INCHES LOST ON BOTTOM TV WORKS OK BUT THE SCREENS STARTS BLUE ABOUT 5 INCHES FROM BOTTOM THAT FADES AND TOP HALF PIC OK BUT...
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2017 | Polaroid Televison & Video
LG49Uf7600 has half screen green and goes on and off in loop. All capacitors are good. Guessing it's tcon but will tcon also fix on and off issue ? I am getting sound and lg logo on half screen.
Apr 27, 2017 | LG Televison & Video
Model 20LS5R. Why is top half of screen black and bottom half white?
http://electro-medical.blogspot.com/
Mar 05, 2016 | LG Televison & Video
Picture and sound goes in and out
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 10, 2017 | Sony KDF-E55A20 55 in. LCD Television
My RCA L42WD22 flat screen will not power on after being turned off for an hour. When I tried to power it on the green light comes on, and I have a flash of a picture, then a black/blank screen & a...
Take the tv apart.The tv power supply board,that the board,have power a/c cord plug into it.That the power supply board,check component parts like capacitors,see if it leaking gases,these capacitors are dead.Capacitors they'll alway bulges up on it tops or puff up on it tops.Have tools like soldering iron and solders?Know basic electronic and soldering?Replaced these dead capacitors will get power to ur tv back.Or tries websites like Shopjkimmy.com to buy a whole refurbish power supply board for the replacement.
Jun 15, 2011 | RCA L42WD22 42 in. LCD Television
Power light is flashing green. i hold the power button it turns red. i press it again it turns yellowish then solid gree the screen comes on the 3 second later screen goes blank and flashing green power
Sharp tv are famous for this problems.Take ur tv aparts,where the a/c power cord go into it.That ur tv power supply board,check for all those dead leakage capacitors parts that bulges up on it top or puff up on it top.Than it ur power supply board,replaced those dead leakages capicitors or replaced the whole power supply board.No leakage capcitors on the power supply board.Than it 100% the Tuner board it dead,this board is where the coalax broacast tv signal cable go into it.This board can't not be repair only replaced,because it alway some ICS it the problems it dead on this Tuner board.Tries websties like Shopjimmy.com,Ebay.com to buy either or both refurbishes the power supply board or the Tuner board.
May 26, 2010 | Sharp LC32D47UT 32 in TV
I have a 2005 Mitsubishi HD1080 big screen that today, when I turned it on, the power light comes on, flashes but the overall screen never come on. Turned & unplugged the power for awhile to see if...
Hello:
There is a problem within the digital board assembly. This is the metal can like unit to the left side of the unit when looking inside it with the back off. The power management is inside this unit. There are 7 1000uf 16 volt capacitors on this small power supply that needs to be replaced. The pwr board is the first you see after opening the Digital unit. Replaced the capacitors with 680uf 16v capacitors instead of 1000uf. After replacing the capacitors looking thru the holes in the digital assembly there will be a green flashing LED, Watch this light for a moment, should stop flashing and stay steadily green if all is normal. Also the power light will still flash for at least 60seconds then go off. Turn on power and happy viewing...Cost to repair this should range around $200-250.00 dollars.
Thk Please leave message...
Oct 07, 2009 | Televison & Video
Flashing bottom screen (Nintendo DS Lite)
You need to check the top screen ribbon is fully inserted into to place on the board. A green light and flash of the screen within a second means ribbon not connecting right
Jun 05, 2009 | Nintendo DS Lite
Red line across top half of screen
My maxent 42" has green and red flashing pixels all across the screen, what is the problem?
Thanks
Aug 30, 2007 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Dell E173FP 17" LCD Monitor Logo
89 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
