Question about Miele KF1801VI Bottom Freezer French Door Refrigerator
My fridge makes wa wa wa noise constantly. And it goes up and down in sound. We selected this fridge for all the good qualities it professes and more importantly for its "quiet" feature. It is not quiet!
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
My smeg fridge is making a constant cricket sound noise constantly
first check for a cricket
if no cricket is found, it's likely one of your 2 fans. one will be down by the compressor and the other is inside the freezer compartment.
May 22, 2012 | Refrigerators
I have a 2004 trailblazer and there is a bad wa wa wa wa wa wa sound comming from the front i checkt the wheelbaring and its good but on the right side up where the half shaft meets the differentaiit is...
The green grease is out of the CVJoint on the drive axle
That is not good,nor is a lot of heat from possibly the
front differential
Check the differential for fluid and a clear vent hose
Apr 06, 2011 | 2002 Chevrolet TrailBlazer
Droid (2 GB) Cell Phone: droid constantly makes noise - the droid sound, ho...
From the home screen, go to Settings> Sound & display> Notification ringtone> then you can select "Silent" if you don't want any "Droid" noises when you get text messages, etc., or you can select a different notification sound.
Hope that helps!
May 05, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
Bosch fridge freezer not sure of the settings
The sound is possibly refrigerant moving through the capilliary tubing nothing to worry about.
Mar 03, 2009 | Bosch KGU32124 Bottom Freezer Refrigerator
Evo8
May be you should make sure all the oil levels are good and especially the tranfer oil and check the drive shaft's center bearing as well.
Feb 04, 2009 | 2006 Mitsubishi Lancer Evolution
GE Stainless Steel side by side freezer noise
sputering and gurgling is a common complaint with lots of models. it is the surculation of the refrigerant thew the evapurator tubing behind the rear wall. make shure the units condensor underneathe the fridge is clean and clear of dust. it can cause the head preasure from the compressor to increase witch can cause excesive sound in circulation. hope this helps you
Oct 19, 2008 | GE GSH25JSTSS Stainless Steel Side by Side...
Miele KF1801VI Bottom Freezer French Door Refrigerator Logo
23 people viewed this question
Top Miele Refrigerators Experts
mike cooper
Daniel Phillips
Daniel Phillips
freddyfox
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
