Question about Whirlpool MH1150XMQ Microwave Oven
I have a whirlpool microwave MH1150XMQ (2004) I was replacing the lightbulb and it broke and shorted out. After replacing it... it no longer works. I checked the voltage at the socket and it reads 1.7 volts in all the positions (OFF, ON, Nightlight). I also removed the front panel to see if there was a fuse that might have blown but unable to find one. It there a fix without replacing the circuit board? Thanks Jack
MicrowaveSvc
  • 9085 Answers
SOURCE: high voltage surge
We regularly repair these GE / Samsung boards from customers nationwide with just such problems for $32.50. If it's too bad off, we can get this board (# WB27X10466 remanufactured) for $145. A new board runs about $180. We would need the full model number with suffix.
Posted on Nov 01, 2006
MicrowaveSvc
  • 9085 Answers
SOURCE: 1994 Whirlpool Microwave Mod MH7115XBQ-2
You can find exploded view diagrams and order parts here: http://tinyurl.com/gv383 The most likely causes are: diagram 5, ref. 5 fuse diagram 7, ref. 2 thermistor diagram 2, ref. 5 control board If it's a problem with the control board, we repair them nationwide for $32.50. We also have important safety and disassembly information we recommend: http://tinyurl.com/yzjozk
Posted on Feb 04, 2007
catriver
  • 878 Answers
SOURCE: Microwvae won't work
Techy, that's where I would start. There is an internal fuse. Sometimes there up front where we can get at them and somestimes we have to drop the whole oven and remove the wrapper. Unplug the microwave and remove the upper grill by removing the two screws holding it on. It will pull off forward. The control panel has 1 screw on top, remove it and lift up and tilt out. See if you can see the fuse cradle and fuse. 20 amp, part number 4358704. The diagram I have shows it more toward the back but these diagrams can be wrong. If you don't see the fuse behind the control panel you probably will have to drop the oven and remove the wrapper. Catriver..post back.
Posted on Mar 25, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: Whirlpool GH518XP
Hattiemay
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 30, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Microwave won't come on after circuit tripped
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Once you remove the control panel assembly, the fuse is located in a holder behind that area toward the top. The tech sheet shows part locations.
But you'll almost certainly need to have the control board repaired.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
Posted on Nov 24, 2008
I have a mh1150xm microwave and changed the cooktop lightbulb. Still no light. A tech came and said that need to change whole control board. Is this true. Everything is working fine exept the light
I take it you did replace with a bulb designed to withstand heat.check the filament of bulb first these sometimes get damaged in transit.if the microwave is coming on then it won't be the fuse.if the bulb looks okay(you can check using another) finally inspect the door latch and the bulb housing and wiring to it.Sometimes door latch hole can get debris into the mechanism.cost of panel via engineer can cost quite abit..is it still in warranty? Price compare the estimation against buying new replacement.
Feb 09, 2015 | Whirlpool MH1150XMQ Microwave Oven
How do I remove/replace the plastic seal on the inside door of a MH1150XMQ-1?
The clear plastic cover is glued on. It can be removed with a heat gun to soften the glue. Then clean with Goof Off or WD40 and alcohol before installing the new one.
Eric
Jul 23, 2010 | Whirlpool MH1150XMQ Microwave Oven
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Heard a pop microwave lost power oven still works checked microwave fuse and its blown ???????????
If it was not in use when this happened check the door switches. If it was in use the HV diode or Capacitor could have shorted or a door switch as well. Eric
Aug 04, 2009 | Whirlpool MH1150XMQ Microwave Oven
Exact same problem - Needlenose slipped and spark in the socket
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You have a short in one of the door safety switches
There function is prevent the oven to work whit the door open
some are normally close and some normally open when one of then don’t work properly causes a short and blow the main fuse check the all and replace the faulty one but be careful and don’t test the microwave
Whit the cover removed.
Note:
if you have a blown fuse buy several emplacement fuses because my take several trays to fix the problem and you will need more than one fuse.
Jun 08, 2009 | Whirlpool MH1150XMQ Microwave Oven
Microwave external underside light no longer works
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
The lights fan can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation, too.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
prototech@usa.net
May 20, 2009 | Whirlpool MH1150XMQ Microwave Oven
My Whirlpool over the range microwave works but
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
xz
May 08, 2009 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool MH1150XMQ 1000 Watts Microwave--NO HEAT
About 95% of the time it is the magnatron. If the microwave is under 5 years old that part is often covered under warranty. I would check your manual. If not the p/n is 8206335 and it's about $80 and fairly easy to install. I just looked and the magnatron is covered.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0523111.pdf
Labor to replace it would be about $125
Mar 04, 2009 | Whirlpool MH1150XMQ Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
76 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
