Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
My laptop is indicating Limited or no connectivity
    Sergeant:
    Champion:
  • 256 Answers
Limited or no connectivity means that you are not getting an Ip address from the router
-try changing the cables
-try changing the port where you are connected
-check the LAN port lights if it's blinking
-are all the computers getting the same error? if yes, it is the routers DHCP server that is bad, if no, focus on that PC that is not getting an IP
-check if DHCP client is started
-do IP config
(if it is 169.254.x.x) it means that it has the auto configuration IP from windows
set static IP within ragnge or your router in the PC
Posted on Sep 14, 2010
My Dell laptop will only connect to public WiFi with limited connectivity
Follow the following steps to resolve Wifi issues on your Laptop. Open Control Panel - Select Network and Sharing Center - Manage Wireless Networks - Highlight your Wifi Network - Right Click and Remove. Reset the TCP/IP stack of the windows system with limited connection status.
My laptop is showing limited Internet access over my home WiFi - Quora
https://www.quora.com/My-laptop-is-showing-limited-Internet-access-over-my-home-W...
Nov 13, 2016 | Dell Computers & Internet
Hp pavillion laptop allows me to log on. Then as it loads up screen flashes and a blue circular disc appears by the curso. It says limited wifi. No problem with the WiFI connecting my phone to it.
Does your phone use the Wifi antenna from your laptop? or the receiver? or the software? When your laptop indicates it has a problem with the Wifi connection, it has. What is causing this should be looked after in the laptop, like did you setup the connection correct? Is the setting still correct? or did something change the settings or even reset the settings?
Just check everything about the wireless connection in the laptop to see if you can get it working again. If it was never working before, just setup the connection.
Apr 17, 2015 | HP Computers & Internet
Limited or no connection
Limited connectivity
If you get a 'Limited connectivity" on you LAN connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the router.
To fix this problem, right click on the LAN icon on the Task bar and then click Repair.
This will force the router to issue a IP address to the LAN card on the laptop.
Feb 11, 2013 | Computers & Internet
Trying to connect to my wireless router belkin n150 with my laptop compaq presario 2500 have a yellow triangle saying limited or no connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Jan 01, 2013 | Computers & Internet
Limited connection
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
May 03, 2012 | Dell Latitude D610 Laptop Computer -...
Connected with limited connectivity
Go to your local area connection from Control panel>Network and internet connection>Network connection.There choose the property of your local area connection.
In property,uncheck the option Notify me when this connection has limited or no connectivity.And choose OK button.Now you have done.Now disable and enable local area connection from network connection.You will seenotification saying acquiring network address and connected.The error of limited area connectivity will never disturb you again.
Resource : http://www.ehowportal.com/fix-limited-connectivity-laptops-wireless/
Apr 26, 2012 | Computers & Internet
Limited or no Wireless connection
It appears that the TCP/IP got disabled or removed.
Check the TCP/IP settinge of the wireless adapter, it should be the same as the network adapter.
Feb 09, 2009 | IBM ThinkPad T41 Notebook
IPV6 connection says limited when it should say local?
You are extremely unlikely to be using ipv6 - A 2008 study by Google indicated that penetration was still less than one percent of Internet-enabled hosts in any country. The leaders were Russia (0.76%), France (0.65%), Ukraine (0.64%), Norway (0.49%), and the United States (0.45%).
So unless you have a private network to connect you to all these other IPV6 users, you are using IPV4 like the rest of us...
Jul 03, 2008 | Toshiba Satellite P105-S6207 Laptop
Wirless Network keeps failing
It is possible that you need to further fine tune your WEP configuration. To verify if it's the security lock, try running the laptop and the router without the WEP security (disabled) and determine if you still get the "Limited connection or no connectivity".
If yes, you have just eliminated that area and could consider other possibilities, otherwise you then have to concentrate on the WEP security.
Hope this be of initial help/idea. Pls post back on any developments (or lack thereof) or should you need additional information.
Good luck and kind regards.
Feb 10, 2008 | Belkin (F5D7050) 802.11a/g/b Wireless...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
