Question about Canon ImageRUNNER 1670F Copier
Cannot get a crisp clean copy. regradless of where the lighter or darker slide bar is set.
    Sniper:
  • 51 Answers
The developing cylinder and the blade unit of the developing assembly needs to be replaced.
Posted on Sep 20, 2010
Copy darker
go into the menu and look for copy/print settings. you should see an option to lighten or darken the copy. It should look like a ascending /descending slider. tap to the left for lighter or to the right for darker
Nov 27, 2013 | HP Officejet 5610 All-In-One InkJet...
How do I darken the print when I make a copy?
for black and white copy:
  • press the arrow key until the pointer comes to copy b & w,press OK to select the copy settings.
  • press the arrow key to scroll through the copy settings then press OK to select the options.
  • go to lighter/darker menu then press OK to confirm settings.
Jul 24, 2011 | HP Officejet J4680 InkJet Printer
Our copier is copying in light shade. how to make it darker
To adjust the default lighter/darker setting
1. On the LaserJet 3015, press MENU/ENTER.
2. Use the < or the > button to select Copy setup, and then press MENU/ENTER.
3. Use the < or the > button to select Def. Light/Dark, and then press MENU/ENTER.
4. Use the < or the > button to adjust the setting. Move the slider to the left to make all of the
copies lighter than the original, or move the slider to the right to make all of the copies
darker than the original.
5. Press MENU/ENTER to save the selection.
Page 48 of the User Guide has instructions for adjusting the light/dark setting during a copy job.
Also see the Troubleshooting section of the User Guide for other possible reasons for light/faded copies.
If your copies continue to come out too light, you may need to clean the insert a new toner cartridge or change brands of toner. I tried several "generic" toner cartridges and refills, but my prints and copies were always faded or streaky. After going back to genuine HP cartridges, I haven't had any print quality problems.
Jul 21, 2011 | HP LaserJet 3015 All-In-One Printer
Page has a dark bar along the length of the page copied and it gets darker the more copies you do
Defective toner cartridge. Try sliding out the cartridge, turn it over and slide open the cover/gate that covers the drum. The drum should be clean all the way across. If you see a toner band or anything that would be your proof. 9 times out of 10 this is going to be a bad toner cartridge.
Oct 09, 2010 | Canon PC-430 Color Copier
Canon PC6re copier makes copies that are dark on the long edges
Just fyi, a Canon PC-6e is a copier that is about ten + years old of a model... The drum unit will make the copies better.... But, you most likely need to clean the optic's. Have you tried to make the copies lighter??? If I am correct, there is a small botton on the control pannel that will turn... It will make the copies light one way and darker the other way... Good Luck
Apr 20, 2009 | Canon PC170 Copier
Copies fade in and out horizontally
One of 2 things likely...It could be as simple as your toner cartridge. Do you have another to try?? Otherwise it should be an optics problem. I've only worked on a couple of these, so i can't remember exactly, but basically you want to get the top scanner glass out. I think you have to remove one of the end panels, and perhaps the top back panel. should be fairly obvious when looking at it, the glass, should slide out the end (power should be "OFF" by the way), slide the scanner to the right and clean the mirrors, and bulb, and then clean the glass. replace and check.
Hope this helps.
Feb 05, 2009 | Canon PC-950 Black and White Copier
Copy Problem
Since you cleand the scanner and scans are fine, the other item I seen cause that problem is the power supply.
Jan 07, 2009 | Xerox WorkCentre M20i All-In-One Laser...
PRINT IS TOO LIGHT
FIRST OF ALL YOU NEED TO GO INTO THE SETTINGS TAB, THEN SELECT "HEAD SETTINGS."
oNCE YOU ARE IN THE HEAD SETTINGS, YOU WILL SEE A BLUE BAR ON THE RIGHT, THE STANDARD SETTING ON THAT IS 15.....BUT IF YOU HOLD THE MOUSE OVER IT, U CAN SLIDE THE SLIDER BAR LEFT OR RIGHT TO MAKE THE PRINT LIGHTER OR DARKER
Sep 10, 2008 | Zebra Z4M Printer
Ricoh FT7650
Maybe your glass is dirty, with alcool and a clothe clean the glass. If you can go undernit go but be carefull for the miror inside.
The Drum may need to be replace to????
Last solution:
If you have a lot of copy (100 000) and more and never get service on it....I think your Developper as to be repalce...and if your not a tech you will not be able to replace it, because you have to calibrate and ajust..... But before that call a tech to see !
Mar 27, 2008 | Office Equipment & Supplies
Canon ImageRUNNER 1670F Copier Logo
old marine
old marine
