Question about Kenmore 75135 Thru-Wall/Window Air Conditioner
The compressor will not turn on. The fan works.
Why isnt my frigidaire side by side refrigerator cooling and compressor is working?
you need to put a set of gages on the unit and check the Freon amount
Jun 12, 2014 | Frigidaire Refrigerators
We turned on our 1.5 hp air con Fujita on the heat setting, the compressor would run but the fan would not work. The compressor became noisier so we turned it off. On the cool cycle the compressor ran and...
the compressor got noisier be cause the head preasure was going up putting a strain on the compressor check all your wires from the fan motor and make shure they are all hooked up and than check the capacitor for the fan it may be bad usualy it will leak fluid or be swollen when bad. but not allways if you can turn the fan by hand is prob. not bad its prob. another prob causing it not to turn
Sep 30, 2010 | Heating & Cooling
Jump air compressor ac works replace relays same issue HONDA
the compressor may be low on freopn but, the fan problem is most likely the fan motor as it is the low temp fan and will run more often than both fans...to test see if you can switch the fan plugin to the other fan watch carefully that it does not get too hot as the second fan is a safety fan that works as high temp or when using the A\C
Jul 13, 2010 | 1997 Honda Accord
Compressor or fan not working
If compressor and all fans not working and unit has power.Check defrost timer maybe bad or sticks turn defrost timer knob if unit starts timer is bad.Timer only turns in one direction.
May 16, 2010 | Freezers
Compressor/Fan not working, one click noise
change the relay and clickson connecting directly to the compressor
Oct 18, 2009 | Whirlpool ED5FHEXMQ Side by Side...
Slow compressor fan
You need to remove the fan and test it somewhere different. The compressor is in need of the condenser fan. Everything will overheat without that fan working. You should also test the power at that pin plug. Let me know what you find. Sea Breeze
Jul 22, 2009 | GE Energy Star SDL20KCSBS Bottom Freezer...
Home AC Compressor starts asynchronously with cooling fan
Check outside unit capacitor and the contactor.. I work on Goodman unit sounds like a cap or contactor
Jun 07, 2009 | Goodman CKL24AR24 Air Conditioner
A/C compressor fan won't turn on by itself.
there is a problem with your fan i'm sure. change the bossing of your fan it will work good.
May 20, 2009 | LG LB8000ER Air Conditioner
Compressor and Compressor Fan Not Working
Rotate the dial on the defrost thermostat, a big click is when it goes into defrost, a little more and it should turn the compressor back on. By overload protector, do you mean the one under the compressor cover?
May 03, 2009 | Refrigerators
Kenmore 75135 Thru-Wall/Window Air Conditioner Logo
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
