Question about Asrock 775Dual-915GL Motherboard
I change the ram and since then even with the old ram it just dont want to boot up, it sounds as if the computer is starting but nothing is displayed on the screen its just black, like there is no communication with the monitor
  • 1,606 Answers
If its a ram problem then you should not get anything out of it at all. If it generates any beep codes or anything then it probably isn't the ram.
First thing to try is reseat the cards and check the ram. You may want to go back to your original ram and see if those work. If it works on the old ram then the problem is either the new stuff being the wrong type , wrong speed, or not being seated properly. Usually its just the wrong type or speed. You may find that even though it says it is the correct thing it won't work. You get that a lot with cheaper ram brands.
Trick is to go back to a working configuration and then change one thing to rule things out.
Posted on Sep 14, 2010
Display Problem with Intel 845GVSR MB : My computer running on Intel 845GVSR MB with 2.4 GHz Intel Pentium 4 Processor and 768 MB RAM and 80 GB HDD . When I start the computer nothing appears on...
Reset the CMOS setup after putting the battery. You have 768MB RAM. So check with the alternate memory module with different slots. If not helpful, check the RAM with another PC. Lastly get the BIOS updated or motherboard repaired from component level motherboard repairer. You may have damaged the motherboard by putting undue pressure while plugging the connectors.
sonsunny
Jul 08, 2011 | Intel D845GVSR Motherboard
Ive changed my ram and drive the computer beeps 6 times and nothing is displayed black screen
Hi, check for bad capacitors on the motherboard.
That is a common problem with that model.
Picture follows.
Feb 28, 2011 | Dell Optiplex GX280 (99301) Motherboard
Dell PowerEdge 1600sc server won't boot.
> black screen & flashing cursor ...
Damaged boot-record on the disk-drive???
Was it configured to try to boot from 'A:' ?
Disconnect the hard-drive & CD/DVD drives.
Put a diskette into the drive, and see if it tries to find a boot-record on the diskette.
If it tries, then it has P.O.S.T.'d correctly.
> no beep codes
When it worked, did it beep _once_ when P.O.S.T. completed?
Taking out the RAM _should_ cause some beep codes, i.e., "no RAM".
> anyone?
Replace the monitor?
Replace a dead video-card?
Or, add-in a video-card, and connect a monitor to it, leaving the original monitor connected to the original video-card. One of the two displays should show the P.O.S.T.
Jun 12, 2010 | Dell PowerEdge 1600...
Dell inspiron does not boot up
Do you see anything on screen? Dell logo? I will assume you see nothing. Not even a Dell logo.
First test your power supply with a meter to be sure it is putting out 18-19 volts. If good, remove the laptop battery and try again. The next tests should be done with the battery not connected to the laptop.
Remove the hard drive and see if it boots. If not, next remove the dvd drive from the laptop and try to boot. If no good, remove the ram, clean the contacts on the ram and the slot with a pink pencil eraser....gently, just make them shiny. Try to boot with no ram/hdd/dvd. Put the ram back in and try again. Try connecting the laptop to an external monitor.
If after all this you still cannot get a Dell logo at boot time, the mainboard is likely dead. A refurbished one (with only 90 day warranty) will probably cost you at least $250 from Dell. Please let this one go and look at a new laptop.....sorry.
Hope this helps :)
Aug 23, 2009 | Dell Inspiron 6400 Notebook
No monitor display
Remove all data cables and external cards and press RAM than try again
Jul 23, 2009 | Computers & Internet
Computer won't load past Boot and now doesn't display anything!
the memory stick going in one way into the module. If you can't close the clips try to rotate it 180 degrees.
when windows starts hit F8 key and select disable automatic start on system failure.
This will bring you a blue screen with the specified error
also you can boot from windows xp cd and at first screen select repair, this will put you in recovery console
in recovery console you can scan your hardrive for errors like this:
chkdsk c: /p /r
Jul 17, 2009 | Computers & Internet
Computer wont Boot up normaly
first romove the power cable. then remove the ram, then remove the agp or pci express if you have. Then adds this thing together. add power cable.
Start the computer.
Jan 21, 2009 | Gigabyte GA-8I848P-G Motherboard
No boot up, display, beep, or HD action
I am having the same issue. Clearing/reset the bios will get the board to boot up, but when turned off and started again the board will not boot. you will have to clear the bios again. The board seems to be rebooting itself continuously before it evens get to the POST.
Jun 28, 2008 | EliteGroup P4M800PRO-M Motherboard
No Boot
if u didn't get any thing on display even check signal cable the problem is in the monitor
or you are getting check signal cable the problem is in the mother board or Ram first change the ram even thou you are not getting display change the mother board
Apr 16, 2008 | Computers & Internet
The Computer doesn't start, and the Aux Power light is on.
remove the ram from mboard ok
then stsrt the computer if u listning beep sound power off computer and put the ram in slot nicely again start computer
if computer dont start change ur RAM
Jan 05, 2008 | Dell OptiPlex GX260 PC Desktop
Asrock 775Dual-915GL Motherboard Logo
48 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
