Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Hi again Bnewberry, thanks
I did run across something called a BEARING - HINGE. It's a pretty cheap little plastic cone like shaped piece that apparently slips into the lower door hole or over the bolt thingy that goes into or on the L bracket?
Is this the culprit?
Only other missing thing is a lower washer , i think.
If I get the right one, is it likely to make noise go away?
thanks so much, I am really looking forward to your reply or opinion.
thanks, thanks, and more thanks.
  • 93 Answers
240328203 is one bearing you need, 240457701 is the other.
They work together on the Bottom side of the door
1. To hold the door in an open position
2. To close the door when it is partially open.
240457701 screws to the hinge its called a Plate-Door closer
240328203 screws to the door its called a Bearing-HInge(Black)
Let me know how you make out. Hope this helps
Posted on May 17, 2008
  • Bill Newberry
    Bill Newberry May 17, 2008
    Sounds like you might be missing 240457701
    Once you get the right parts in the right place your noise will go away.
    Thanks Again,
Have a grinding noise in front right side of tire have changed rotor and break pads and still makes noise
maybe axle or bearing . is the brake shield bent hitting anything? is their any sign of something rubbing inside or rim can you see any marks
Dec 26, 2010 | 1994 Geo Prizm
How do you replace the left hand side door hinge?
remove machine remove side panel on affected side the door can be lifted away from hinge bearing allowing you to fit new one it probably only needs plastic bearing as hinges are very tough and dont break unless someone falls on top of door!
May 26, 2010 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Cutlass Supreme new front wheel bearing repeatedly goes out
You may have pulled the inner tri-pod joint out of the cv shaft and that will make noise. Is the bearing really bad? Does it turn freely?
Jun 23, 2009 | 1995 Oldsmobile Cutlass Supreme
I have a 1998 Mercury Villager, and have repeatedly replaced the hinge to the sliding doors glass window. Could you tell em the correct name of this part, as I need to call around to find this part. This...
These hinges seldom fail. Must be something wrong with the lock or other hinge. It's called "Body Side Door Hinge" go here for villager help. see files and photos. ebay has parts cheap. so does See page with asterisk for lowest price. New parts
Jun 10, 2009 | 1998 Mercury Villager
Sienna sliding door hinge replacement
I have exactly this problem on my 2004 toyota sienna. Just started happening and the door now rubs the edge of the rear quarter panel as the door opens and closes. Any help on how to replace the middle hinge would be appreciated.
Apr 09, 2009 | 2006 Toyota Sienna
GE TFS28PB Lower Hinge on Fridge door defective.
you have to get cam closure part # wr2x9246 and door stopper wr2x9247
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a '97 Buick Park Avenue Ultra front left growling noise
sounds like a wheel bearing if you don`t hear a clicking it is a bearing
Feb 23, 2009 | 1999 Buick Park Avenue
Side side door noise(fridge side door)
you need the lower hinge and cam kit. remeve the top hinge then lift the door off the hinge and replace the hinge and the cam on the door.
Dec 19, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Sep 12, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Fridgidaire side by side door popping follow up : will this work?
duuuuude, i have the same problem with my kitchenaid. please help if you get any anwers!
Leroy in Dallas, TX
May 21, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
313 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
