Question about Pride Mobility Products Jazzy 1170 XL Plus
I work at a homeless clinic. We had a Jazzy 1170 donated and we charged the battery for about 7 hours. When we tried it out it moved very slowly. Nothing was registering on the amp meter on the back. and the battery looks to be charged Any suggestions?
  • Anonymous Mar 29, 2014
    1170 xl batterys have a charge but when try to plug in the charger does not seem to work
  • 692 Answers
Yes you probably need new batteries. If you have access to a digital voltmeter set it to 200 volts DC and plug the leads into the charger port located under the front of the joystick. Plug it into the 2 outter holes. Without the charger plugged in you are reading the battery voltage it should read 24- 27 volts. Now plug in the on-board charger and the voltage should go up to 27-30 volts. If you don't get at least 24 volts w/o the charger plugged in then the batteries are bad. If you don't read 27-30 volts with the charger plugged in then the charger is bad and unfortunately both might need to be replaced. Hope this helps
Posted on Sep 15, 2010
Jazzy stopped one day. Plugged in charger and it will still not move. Replaced batteries and it will move a couple feet then stop.
shouldnt even move with charger plugged in sounds like a controller problem or joystick have a tech fro dealer check the error log they can tell u what is wrong from that
Oct 11, 2013 | Pride Mobility Products Jazzy 1170 XL Plus
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Jun 04, 2012 | Pride Jazzy Select 6 Indoor Power...
I just replaced the batteries in my Jazzy 1170 PLUS. Now my speed control lights blink constantly and the chair is totally unresponsive.I have double checked to be sure the freewheel levers are totally...
According to my 1170 manual the flashing lights are error codes. 1 red = low batt., 2 red = left motor disconnected, 3 red = Left motor wiring fault, 4 yellow = Right motor disconnected, 5 yellow = right motor wiring fault, 6 yellow = Inhibit active, 7 yellow =possible joystick fault, 8 green = possible controller fault, 9 green = Solenoid brake fault, 10 green = high batt. voltage
Feb 13, 2011 | Pride Mobility Products Jazzy 1170 XL Plus
Jazzy 1113 will not operate!
The click you hear when you activiate the joystick is the electric solenoid on the automatic brakes going on, and then off when you push then release the joystick. This is normal. If it isn't moving, check to see if the free-wheel levers are in gear or in neutral. If you can push the chair, you are in neutral and activating the joystick will just release the brake and run the motors. Turn the two levers to the drive position and then it should take you where you want to go.
You can go to Pride Mobility's website to download an owners manual for your chair here
http://www.pridemobility.com/jazzy/1113ats.asp
Good luck.
Jul 05, 2009 | Pride Mobility Products Jazzy 1170 XL Plus
Pride Mobility Products Jazzy 1170 XL Plus Logo
130 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
