Question about Panasonic KX-T7730 Corded Phone
How do i block local calls, mobile, as well as int'l calls from kxt7730, im using kxt824.i have 8 digtal extensions. i need to open from 101ext to allow local and mobile. thanks
  • Panasonic Master
  • 2,460 Answers
When you get out the Features Manual, look and review Toll Restriction (TRS). You set the Class of Service on a phone to something other than 1 and then build tables 2-5 to restrict or allow certain digits. The Programming Manual (notably 302-305 and 306 being the exceptions) contains the data, the FM the instructions.
Carl
Posted on Sep 14, 2010
Forward to mobile
your mobile is not an extension to a land line .call your local phone company and ask them about call forwarding . it usually costs you more money
Feb 22, 2016 | Panasonic KX-T7630 Corded Phone
Tip
Blocking of outgoing calls from extension phones
Dear sir<br /> <br /> I need to block the outgoing calls to mobile / land phone locally from the extension phones.Please advise the technical details to block it.<br /> Tel phone model panasonic KX-T7636.
on Mar 27, 2011 | Lands Phones
Where is the location to replace overhead lights fuse in 2003 oldsmobile aurora
Rear fuse box. INT LP 10 amp . there is also INT LP relay in the same rear fuse box .
Fuse Block - Rear
Under the rear seat, on the left side of the floor pan
The INT LP fuse in the fuse block - rear supplies battery positive voltage to the normally open switch contacts of the INT LP relay. The INT LP fuse also supplies battery positive voltage to the INT LP relay control circuit. The fuse block - rear also supplies battery positive voltage to the relay control circuit for the front courtesy lamp. The door modules communicate on a simple bus interface (SBI). When you open any door, the switch contacts of the door open switch close. When a door open signal circuit is grounded, that door module sends a message to the drivers door module (DDM) in order to indicate that a door is open. The DDM sends a class 2 message to the rear integration module (RIM) in order to indicate which door is open. The RIM activates the INT LP relay in order to provide battery positive voltage to the interior courtesy lamps. When any front door is opened, the RIM will energize the FRT CTSY lamp relay grounding the I/Pcourtsey lamps at G302. Depending on which doors are opened, front or rear, the proper interior courtesy lamps illuminate. The RIM provides a pulse width modulated ground to all interior courtesy lamps for the interior lights theater dimming feature. Some of the courtesy lamps are also used as reading lamps, each reading lamp may be manually turned on or off using it's own respective switch
Sep 24, 2015 | Oldsmobile Cars & Trucks
CO problems
Check your Phone if connected to Jack 01 to do programming below:
on KX-T7730 phone Press Program *# (enter Password) default is 1234
Press 400 SP-Phone(CO NO.? will be displayed) Press *(Mixed or Connect will be displayed), Press AUTO ANS/MUTE untill (NOT Connect will be displayed) Press AUTO/STORE. Press HOLD(SYS PGM will be displayed) Press 400 (CO Connection will be displayed) Press SP- Phone(CO NO.?) Press SP-Phone (Not Connect will be displayed) Press AUTO ANS/Mute until (Connect will be displayed)Press AUTO/STORE PRESS PROGRAM to return to NORMAL Display.
For the incoming Calls PRESS Program *#1234 (ENter Sys PGM will be displayed) PRESS 408(Day IN CO will be displayed) Press SP Phone (CO No? will be displayed) Press SP Phone (CO1:#01:DISABLED if this is displayed PRESS AUTO ANS/MUte the Enabled will be displayed) Press AUTO/STORE. Press Program to return to normal display. In this Manner All Calls will ring to extension which is connected to Jack 01. you dont need to press the button anytime there is an incoming call.
Dec 04, 2013 | Panasonic KX-T7730 Corded Phone
I wana get a uninor puk code
Hi
PUK code is called as PERSONNAL UNBLOCKING KEY.
Your phone will ask for PUK code when you entered the PIN code wrongly several times depending upon the mobile make. The mobile asks for PUK code so that unauthorized persons do not use your mobile for wrong cause.
To get PUK code please contact your service provider through phone or go directly to their office. They will provide you the PUK code for your mobile. The PUK code for mobile phone.so that you can open your phone. When you planning to call your service provider you cannot use your mobile as it is fully locked. Please use some other mobile with same network to call your service provider.
While you get the PUK code ,the service provider customer care officer will ask for your personal details to check whether the mobile belongs to you only. If they are satisfied with your answers they will provide with the PUK code
DONOT enter the PUK code several times wrongly,It will block your sim card permanently.
This PUK code is FREE. You no need to pay any sum to get the PUK code
Thank You.
Jul 24, 2012 | Cell Phones
How to open a dbk file
by changing the .dbk extension to .zip exe.. then open in outlook express
May 23, 2010 | Sony Ericsson K530i Cellular Phone
I have an LG 290c Tracfone and when I try to access the browser I get a message which says "you do not have access this site tfdevice.home" . Tracfone tech support can't resolve the problem. Please help.
im haveing same problem only thing i fiured out is terms of service says you can not be in an anolog area you must be in a digtal are however i know my area is digtal the tower is less than a quarter mile from my house and others on us cellular have digtal im sorry i cant help and i need help with same isue
Jan 25, 2010 | Cell Phones
I have an 824 and i am using the kxt7730. when I answer a call, the caller doesnt hear me for the first 2 seconds then i have to repeat my self. we dont have a DISA or Voice mail or Auto Attendant. i have...
Dialing 790 on the intercom resets the extension. If you move your phone to another port on the system does it work? If it does, do that and swap directory numbers in programming.
Jun 26, 2009 | Panasonic KX-T7730 Corded Phone
I want to block certain phone #'s from calling my palm 755 . How do i do it.
Sadly, you can not block numbers directly on your cell phone.
Depending on your service carrier, you may be able to dial an extension to block the number on their network. I suggest contacting your carrier's customer service for this extension, or visiting their FAQ on their website.
If you are currently using T-Mobile, it is not possible.
Apr 14, 2009 | Palm Treo 755p Smartphone
Lost password kxt7730
Hi i am trying to change the name of a extension in my kxt7730 but it asking me the code i already use *#1234 and **1234 but it didnt work, i will like to know if its a way to reset it thank you
Dec 10, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7730 Corded Phone Logo
156 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
