Question about Blueant X5i Bluetooth Headset
I just got a blue ant headset x5i. When I try to connect it to my blackberry curve nothing happens. The headset just blinks that its on
5 Suggested Answers
  • 54 Answers
SOURCE: can not figure out the password to connect to my
0000
1234
1111
Those are the defaults try them.
Posted on Dec 09, 2009
  • 155 Answers
SOURCE: i have a new blackberry 9630 and a blue ant
You need to put it into discovery mode before you tell your phone to look for it. You probably hold down the main button until it stays solid lit to do that.
Posted on Mar 26, 2010
  • 49 Answers
SOURCE: I just got a Blueant v1 when connected I cannot
Go to this page, it will answer any question concerning the blueant .. including pairing to your phone .. activating your blueant etc http://www.blueant.com.au/index.phpalso gives you step by step instructions on codes, pairing etc
Posted on Apr 09, 2010
  • 214 Answers
I would delete all existing pairing profiles from your blackberry, once that is done do a hard reset by removing the battery from your phone while it is powered on. When it boots back up, reset the V1 by pressing the vol -/+ and MFB all at the exact same time. Ensure the buttons are NOT held simply clicked all at once like a mouse to a computer. When you get a consistent rapid flash the device has been reset and will go automatically into pair mode. Then re-search in your bluetooth menu, select the V1 when it shows up and enter the pin code 0000 if prompted.
Rylan
Posted on Dec 16, 2010
I cannot pair my blackberry curve 3G with my Wireless Nokia headset BH-503! It was working until I paired it with another nokia 2700 and after trying to pair it with my blackberry curve 3G again, it...
It is paired with the Nokia 2700.
From the manual (Click here to get it) page 11;
To clear the pairing and volume settings, switch off the headset and press and hold the multifunction key and press the volume up key until the indicator light alternates red, green and blue three times.
Feb 05, 2011 | Nokia BH-503 Bluetooth Headset
IM TRYING TO CONNECT MY JWIN BLUE TOOTH TO MY BLACKBERRY CURVE 8530 AND IT WILL NOT LET ME CONNECT. IT SAYS THAT NO BLUE TOOTH IS FOUND. HOW CAN I PUT MY BLUE TOOTH IN PAIRING MODE AND THEN CONNECT IT TO...
When the bluetooth is off press it's button and keep it presed until the led is lighting red. Then the bluetooth is in pairing mode. Relase the botton and start the search for devices on your blackberry and use pin 0000 to connect. Good luck.
Jan 27, 2011 | Jwin BLUETOOTH HEADSET Wireless Headset
Does a supertooth 11 work with a blackberry curve?
being that it is a bluetooth device and the blackberry curve has bluetooth capability then yes they in theory will both work flawlessly with one another.
If you need further assistance please feel free to follow up with a comment and i will be here to assist you. If this assisted you please feel free to rate this comment. thanks and have a great day.
Aug 19, 2010 | Blueant Blue Ant 091193 Supertooth II...
How do I pair to a Blueant X5i? I can't seem to find a manual online. Thanks!
The X5i is no longer listed on the website so here you go. With the power off hold the "power" + "Vol Up" button for 4 seconds until the status light flashes red/blue alternately. Type in the code 0000 within 1 minute and you should be paired!
Apr 17, 2010 | Blueant X5i Bluetooth Headset
Blue Tooth Connection instructions for a MT Max 4X Headset
Go to http://demos.blackberry.com/8300/na/us/gen/ >
Select "Menu" on the top left > Select "Start Using Your Device" > Select "Connect with Bluetooth Enabled Device"
Hope this helps :)
Oct 02, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry Curve 8330 can not find my bluetooth headset
Turn the 360 off.
Then turn Bluetooth off, then back on the Curve.
Then turn the 360 back on, input the code when asked to due so.
Jul 23, 2009 | RIM BlackBerry Curve 8310 Smartphone
BlueAnt pairing with iphone...help
Just got off the phone with Apple and Blue Ant tech support.
If everything is workon g on both devices you probably need a memory dump on your headset.
1. Power off both devises
2. Power on iphone
3. Power on blue Ant - not in pairing mode - you should see 1 blue blinking light on MFB
4. Make sure iphone bluetooth is on and searching for devices
5. On Blue Ant, hold both volume buttons and MFB at the same time until you get a fast blinking blue light.
6. Check iphone it should now recognize device.
7. When Blue Ant shows up on phone press it so it completes the pairing priocess
Jun 24, 2009 | Blueant Z9 Wireless Headset
Could anybody suggest a bluetooth for blackberry 8330 for listening to media?
(The Blue Ant V1)
http://shop.crackberry.com/blueant-v1-voice-controlled-bluetooth-headset/9A32A4147.htm
-Inexpensive
-Top Quality
-Good reviews
Check it out! Thank you.
Mar 16, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Plantronics Voyager 510 & Blackberry Curve
 Plantronics Support Phone Number: 1-800-544-4660
Do not use the power button to sync.
To sync device, Press + button (volume) and Silver button (on boom) at simultaneously. LED Light will blink RED & BLUE.  Device ID should appear on your screen.
Jan 14, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Blueant X5i Bluetooth Headset Logo
21 people viewed this question
Top Blueant Radio Communications Experts
Josh Whitehead
Josh Whitehead
Michael Vincent Cruz
shuyumeng
shuyumeng
Are you a Blueant Radio Communication Expert? Answer questions, earn points and help others
