Question about HP Compaq Presario V2000 Notebook
Presario v2000 my screen does not light up anymore.. i can only see when i have lights pointed directly the screen.. how do i fix it???
  • 593 Answers
Get new inverter, its under the screen trim, either on the side or between the hinges. Small PCB with 2 plugs on it, in and out. Match model number and search Ebay. direct plug in replacement. Worked for me.
Posted on May 16, 2008
Display problems
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 13, 2013 | HP Compaq Presario V2000 Notebook
The small rubber button on my compaq presario V2000 isn't working. When I open the screen of my laptop the light on the screen will switch on for just a moment, and then switch off. How can I fix it so the...
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Mar 08, 2011 | HP Compaq Presario V2000 Notebook
Battery problem with HP Compaq Presario V2000 laptop
When batteries fail, they usually lose the cells inside them, which means that the cell is no longer able to function as a holding cell for power and therefore cannot do its job anymore, when a battery fails to hold and refuses charging it is bad and needs to be recycled. The flashing is telling you to purchase a new battery. The larger the number of cells in the battery, the longer and better it will perfrom,,RE: 6 cell, 9 cell, 12 cell.
Jan 13, 2010 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 laptop stuck in hibernate or sleep mode. Power light, battery charge light and HD lights are all on, nothing on screen, no working sound of HD. I have unplugged/plugged, taken the...
Try booting into the BIOS Screen and resetting to factory defaults. If that fails suggest swapping the hard drive out and re-install the Operating System - Save your old data and migrate the data off the old drive. You can buy an external drive adapter to connect the harddrive to a USB port to migrate you data.
Good Luck!
Sep 09, 2009 | Compaq Presario 1275 Notebook
Hp V2000
This is generally caused by a bad inverter. However, this can also be caused by a loose connection. Check all the screen connections, screen, screen to inverter, and screen to motherboard. If the connections are good, then the inverter is going out.
Aug 06, 2008 | HP Compaq Presario V2000 Notebook
Compact Presario v2000 the screen is blank
Remove the power cord. Remove the battery. Hold in the power button for up to 60 seconds to discharge the laptop. Try booting it.
Apr 27, 2008 | HP Compaq Presario V2000 Notebook
Black screen```
You cant fix it Im afraid I think the screen maybe poked and died on you. To prove a point plug and external Monitor to the laptop and if all is well then Im afraid the latter I have informed you is correct. There are quite a few models of laptops out that nfortunately are built to fail so the rotten companies who make them sell another. To replace your black screen if it is damaged would be $700 and thats for the screen there is the fitting yet you might have pay the man for that and they are not cheap. I wish I could help you further or wave a wand but I cant Im sorry.
Sep 06, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
