Question about Hotpoint Dryers
Making noise as if something is stuck in the drum/motor
  • Hotpoint Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 15, 2010
Dryer makes screeching noise
many culprits, bad bearings, loose belt, bad drum glides, bad roller pullies, bad tensioner near motor? even may have something stuck in between drum and hub?
Sep 27, 2014 | Maytag Dryers
Haier dryer makes ticking noise
The ticking noise could be either a piece of the belt hitting as it spins around, it could be something stuck in the drum that is hitting it as it turns too, or it could be the electric motor making the noise. Either way it sounds like you may need to tear it apart to see what's going on.
Jul 18, 2014 | Haier HLP140E Electric Portable Dryer
Amana Dryer LEA30AW
usually the humming sound is coming from the motor,try this,open the door,turn the drum with one hand and hold the door switch in with your other hand and have someone else push the start button at the same time,this might help the motor turn on but if it does you need a new motor,if you can't turn the drum you could have something stuck in the blower wheel or something jammed in the motor like a broken belt but like i said a humming sound is usually the motor.
Feb 22, 2012 | Amana Dryers
When the dryer is running it makes squeaking noises. what is the problem. what can be done to fix it.
There could be something stuck between the inner and outer drums, or (more likely) the main drum bearing has worn out. A third possibility is that one of the motor or idler pulleys is making the noise, but in my experience this isn't extremely likely. The best approach would be to remove the rear panel (don't forget to unplug first) and turn a few things by hand to see if you can identify where the noise is coming from. Remove the back panel of the drum to clear anything stuck between the inner and the outer. If you find that the drum bearing is worn, you should be able to undo the bracket holding it and purchase a replacement from an engineering supplies store or specialised bearing retailer.
Jun 27, 2011 | Dryers
Remove the drum on a top loaded washing machine
odds on something being between the tub and basket is very small.  noise probably coming from brake/clutch or transmission just to name a few possibilities...
Jul 24, 2010 | Whirlpool Washing Machines
When I press the start button on my Kenmore dyer it make a noise but won't start
if it's a humming or like a buzzing noise it's coming from the motor.try spinning the drum by hand,if it moves freely it could be the motor,if the drum is hard to move you could have something like a sock stuck in the blower wheel or something is jamming up the machine and the motor can't move.also just yesterday i found the belt broke and was rapped around the motor so you'll have to get in there and take a look.good luck,let me know what you find
Jun 27, 2010 | Kenmore 63942 Dryer
Indesit WIXL 143 washing machine noise
there maybe a coin or something stuck between the two drums, when the machine spins fast it lifts the item up, unplug the appliance and remove the botton drum hose to see if you can get it out.
Apr 05, 2010 | Washing Machines
Motor problems on whirlpool duet
Any motor can go anytime, grinding sounds like some thing stuck in drum putting stress on the motor it may well be its just the belt thats gone here you need to check further/ Make sure drum runs on own with no noise pull mains plug 1st disconnect m otor belt/ dru m should be smooth if not something could be stuck here ie Sock.....
Nov 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Motor not spinning (was making too much of craking noise before) it seems that the motor has jammed
Could be the motor or something stuck in the drum, Remove the belt and note if motor is ok on own.....If all is well then motor okay, If no turn then could be motor or brushes....
Oct 02, 2009 | Washing Machines
Thumping noise in atlantis dryer after drying heavy mattress pad
Have you husband do a visual inspection of the drum and literally feel it to see if anything is caught or stuck on the drum. The motor also may have something caught in it as well. This would be the motor that turns the drum.
Dec 15, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
37 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
