SOURCE: Gas range top burners hard to light...
Gas burners use propane or natural gas...refer to the manual to see what it takes and sometimes you have a switch to select the proper gas. you can call a gas man to confirm this and correctly tell you whats going on. but he will propably make a trip. good luck
SOURCE: Whirlpool electric range top burners
Probably have to replace the infinite switches. These are the controls you turn for the burners.
SOURCE: Whirlpool electric stove
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
SOURCE: Kenmore Electric Stove - Gourmet Edition
Hello! I have this stove in black where something went bad inside last week (made like a crunching sound). It still runs but seems to only be getting 110 electricity. Clock and lights work and the large oven stays warm. Everything was working fine until this happened. Could be an inexpensive fix- I willing to sell it for repair or parts if you are interested. The griddle alone sells for $170.00 through Sears. Cynthia
SOURCE: One of the burner does not work on my electric Kenmore stove.
the eazy answer is its the burner.i only say that because on most service calls with your complaint it dose indeed end up being the burner.but before i come to that conclusion i do check the out put of that burners switch.if has 220 volt output then its the burner,even tho if you look at the wiring diagram it will show a limiter before it gets to the burner but that part is built in to the switch and is not replacable on its own.so then use volt meter take a look at your wiring diagram .look on that diagram and decide which wires are leaving the questioned switch that controls your bad burner .place your probes on those wires again if reads 220 volts replace the burner. i hope this helps .God bless ,tom
