Question about Dryers
Hey there i got a broken belt from old kenmore dryer model i dont see what model is it but i found a piece of paper with a part no. i dont know i u can gimme a good awnser also i find the paten number
  • Dryers Master
  • 3,287 Answers
You're really going to need the model number of the dryer to determine if the piece of paper has the part number for the belt that your dryer needs. If you find the model number info - you can go to Sears Parts Direct to check for a replacement (or go to the store).
You may get some help by bringing the belt to a Sears or Kmart store to compare to other belts that they have in stock. The length of the belt isn't super critical as the tension-er pulley can make up for small differences between your old belt and one that is "close".
I hope this helps!
Posted on Sep 14, 2010
Kenmore Heavy Duty dryer model # 86873100
The drum belt is lopped through a idler wheel that has a power cut off switch that cuts the power when the belt breaks.
So I don't know why the dryer would heat up if the belt is broken?
Is the top of the dryer very hot. Check the dryer vent tube is not clogged.
Feb 22, 2014 | Frigidaire Kenmore Washer Tub to Pump Hose...
Will not dry clothes
How old is the dryer? The ceramic ignitor piece may have partially broken off. It gets very brittle over the years. Look for a broken piece laying below where it sits. If you replace it, do not touch the ceramic part of the ignitor or it will not work right. Sometimes it's just as simple as a corroded wire connection. I once worked on a 25 year old Kenmore gas dryer that would not ignite. With the power cord unplugged, I disconnected and reconnected all the wire terminals inside and tried it again it worked perfectly like it was new.
May 14, 2010 | Kenmore 73952 Gas Dryer
Drum does not rotate!
Good day,
Yes, it sounds like a broken belt.
To replace it, remove the lint filter on top, and remove the 2 screws under it.
With a narrow screw driver, pop one side of the li, then the other.
Now rotate the lid up but do not go above vertical.
There are 2 screws holding the front panel on at the top.
Remove the 2 screws, and then unplug the door switch wires. and the support clip for them.
With the front tilted an inch or 2 lift the front panel up and off.
Here is an excellent tutorial.
http://www.wikihow.com/Replace-a-Dryer-Belt-on-Whirlpool-Models
The belt can be purchased at any appliance parts house.
IMPORTANT> On some of the newer models the belt tensioner was nothing more than a piece of spring metal.
It will be found on the bottom right side of the dryer floor.
If that's the style, it's a known deficient part, and must be replaced with the old version with has a wheel.
A good counterman will know all about it. Take the old one with you.
Dec 14, 2009 | Whirlpool LGR5636L Gas Dryer
Trying to replace the dryer belt on a Kenmore Dryer
Good day,
That is a known defective part. Go to any appliance parts house and get the model with a wheel on it. The counter men will know what you need. Yes, it's made by Whirpool.
Directions below.
Dec 05, 2009 | Kenmore Dryers
Kenmore Automatic Dryer wont tumble. Model series 77410110.
Usually this means the belt is broken,the belt may have just been old and worn out and it was time to replace it,or perhaps the wheels locked up or the idler and caused the belt to break. Look around for stiff wheels, bad bearings, glides and idlers. Its a good idea to oil the rollers with some temp resistant oil such as zoom oil. Dont use WD40 as this stuff is highly flammable and may cause a fire
Sep 11, 2009 | Dryers
Pulley came off dont know how it goes back on
Go to repairclinic.com and click on the "Repair Help" link at the top of the page. On the next page, there will be a link for "Dryer Belt Diagrams under the "Special Features" section. Scroll down to Kenmore. Since you didn't post a model number, you will have to look at diagrams H, B, or K. If you are confused, please let me know. I hope this helps you.
Apr 07, 2009 | Kenmore 62622 Electric Dryer
Belt replacement
Take the belt with you to an appliance store and they will match it up. Much like a fan belt on a car. You won't necessarily need the model if you have the belt. Next, it sounds like your assembly is broken. If this assembly looks to be in pieces, you may need a new one.
Feb 03, 2009 | Kenmore 73952 Gas Dryer
Broken belt
remove top first, then front just a few screws,then put belt around the drum and pulley and reassemble,bye.eire
Dec 03, 2007 | Kenmore 63942 Dryer
Dryers Logo
48 people viewed this question
Top Dryers Experts
