Question about HP Compaq Evo n610c Notebook
Compaq evo N610c problem charge Circuit Failure
  • 2,567 Answers
First of all, you need to make sure your power adapter is providing enough power to both run the laptop & charge the battery. A very good way to do this is to compare your laptop voltage & ampere requirements (written on a sticker on the bottom of the laptop) with the voltage & ampere ratings of the power adapter. Voltages should be the same, or the power adapter's voltage about up to 0.5 volts more than the laptop's voltage rating. Amperage of the power adapter should be at least equal to or greater than the laptop's rating. It should never be less than the laptop's rating, or else the power adapter will be providing insufficient amperes to charge the battery. Of course, the power adapter's nominal amperage might be ok, but it degraded on usage. You can verify this by testing using a good or new power adapter.
If the battery did not charge using the new power adapter, take the battery off the laptop, & using a dry tooth brush, scrub in between the fins of the battery connector on the motherboard & on the battery it self, then put the battery back into the laptop & try again.
If this still did not resolve the problem, then the battery itself could be bad. Try it on another laptop, or try a good or new battery in your laptop.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 18, 2010
Compac Evo N610c - 2Mhz - 1 GB ram - Windows XP SP2 Blinking charging light went out and computer won't start up again. Checked power suplly (18,57v dc) Replaced with another power supply, replaced the...
Your computer has an open circuit on the system board. If you have data on the machine you can remove the hard drive and connect it to a PC, Sorry I can't think of a more elegant solution. I hope I'm wrong.
Mar 11, 2011 | HP Compaq Evo n610c Notebook
I AM LOOKING FOR A LAPTOP BATTERY FOR MY COMPAQ EVO N610C A GOOD LOW PRICE.HI-CAPACITY LI-ION (4400MAH 8 CELLS) FOR COMPAQ EVO N610C
don't waste money on buying second or used.
buy original from near HP store or order online. check HP center near
Oct 12, 2010 | HP Compaq Evo n610c Notebook
Evo N610c wont boot up
hi!
9/10 it can be hard drive failure it means replacing the hard drive:)
regards craig
Feb 15, 2009 | HP Compaq Evo n610c Notebook
LOSSING CD DRIVER COMPAQ EVO N610C
The problem with your system is that the Battery you are using is Faulty is either the current voltage spoilt it or may be is an old age battery
What you will have to do is to get another Battery that you will first of all Charge it well before usage ok. nice
Sep 23, 2008 | Compaq Evo N610C Notebook
Battery installer
My compaq evo n610c have the following problem: "103 circuit charge failure" and use power AC only.
best regards
Sep 19, 2008 | Compaq Evo N610C Notebook
COMPAQ N610C DISTORTED DISPLAY?
Sounds like video failure. If your video is integrated as most laptops are, it will require a motherboard replacement.
Jun 27, 2008 | Compaq Evo N610C Notebook
HP Compaq Evo n610c Notebook Logo
245 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
