Question about Plantronics Discovery 975 (8164001 P) Bluetooth Headset
Press and hold power button on my 975 and nothing happens it shows charging when in case and red led flashes when plugged into charger but when I try to power up it doesnt
    Problem Solver:
  • 7 Answers
I just encountered the same issue, it does nothing.
Posted on Nov 01, 2010
  • spoeki Mar 07, 2011
    my one also didn't work also when I press and hold power button on my 975 and nothing happens it shows charging when in case and red led flashes when plugged into charger but when I try to power up it doesnt
    where is a solution for this problem??
I had the same problem. It seems to sometimes occur if I turn off Bluetooth on my phone before turning off the Plantronics device. To recover, I let the device completely discharge, and then recharge and it's back to normal. To prevent this from recurring, always turn off the Plantronics device first.
Posted on Mar 05, 2013
My kindle is frozen at pause screen
had this the other day with a kindel. check the charger is working or change to another usb and leave on for 10min, then press the power button. if this does not work you will need to prise off the screen cover and undo the 10 torx screws and use a something like a kitchen knife not sharp and prise the top of gently as there is 4 clips holding down the board and screen, when its out remove the battery its a push the pins in on the sides and pull away. leave it unplugged for a few seconds then plug back in, now while its out plug the charger in, it will have an amber led show at the charging port area you will see it blink about a minute after charger is plugged in, now press the power button and it should turn on now (button is in the same place as the case ) leave it on charge out of casing and when charged and the led is green replace in case remove power lead and put the power connection on the board in first to the case and push down on the corners you will hear it click, then screw the case back down. (remember when the screen cover is off put it to one side and make sure nothing gets onto the sticky side) when all back together with the screws put the screen cover back on. and you are done.
Aug 12, 2017 | Tablets & eReaders
We lost the charger for a few weeks when we found it now the nabi won't charge.
Try reseting it by holding down the power button (while unpluged,first) for 5-10 seconds. Then plug in charger.
Jan 08, 2015 | Nabi 2
My sony xperia T will not charge
Success story. Disclaimer I haven't notice any damage or
loss of data, However I take no responsibility for any damage or loss of data
that may occur.
My girlfriend has a xperia T and did let it go flat, since
then it didn't appear to charge or switched on.
I had tried allsorts suggested on various websites such as
plugging charger in and out a few times, leaving in charger for 24 hr, plugging
into laptop, and trying to power up with power button and volume up. Red light
sometimes lighting up or flashing but not staying lit.
After playing around with all of the above methods, I
noticed if I kept my finger on power while plugging into the charger or laptop
the red led stayed on until I let go. So I tied an elastic band around the
phone on the power button, then I plugged in the charger, unplugging it,
plugging in again with volume up pressed until I had the red led lit. Not sure
of which combination I did but just when the led was lit (not flashing). I left
it for a few hours while it was plugged in with the elastic band keeping
pressure on the power button. Came back to it and found the phone on and
battery at 100%.
Hope this helps some of you
Mar 29, 2013 | Cell Phones
My laptop was plugged in and lit up showing it was charging but when I pressed power button nothing happened. I unplugged from charger and no lights at all and pressed button and nothing happened. Is
plug where Check for loose power where power cord connects.
A computer repair shop can replace the power on/off button and he power plug input jack if required. Make sure the laptop power charger has the correct voltage for the computer if it is universal power supply/charger.
Feb 08, 2013 | Toshiba Satelite 4000CDS Laptop AC Power...
Vostro 1400 won't turn on
I doubt there is battery problem, have you tried switching on laptop without battery and connecting through the laptop charger? most probable your battery is not taking the charge. so suggest you to disconnect the battery and try using laptop with charger then you'll find the problem.
Aug 06, 2012 | Dell Vostro 1400 Laptop Computer (Intel...
I'm borrowing a Jet 3 Ultra from the local Am. Legion for my Mom to use. They know nothing about it except they were told it had a new battery. I plug it in and all the LED's light up with the...
The batteries need charging and when you plug in the charger and the power is on the lights wil flash indicating that the charger is plugged in. Now look at the rear of the chair near where the charger cord plugs into the chair and you should see a voltmeter. With the charger plugged in the voltmeter will indicate about 5-6 amps and after charging overnight the voltmeter should be reading 0 amps. If when you plug in the charger cord and the voltmeter indicates 0 amps then I would suspect that the charger is not working or that the fuse is blown in the charger circuit. The only way to see if the batteries charge would be to borrow or find an offboard charger that will plug into the charger port located under the front of the joystick and after charging for 10-12 hours see if the battery level lights show full charge Hope this helps
Jun 25, 2011 | Pride Used Mobility Jet 3 Power Wheel...
My compaq presario 2200 wont boot up...when i press the on/off switch without the a/c charger (battery alone), the amber led flashes twice....if i plug the charger in with the battery, the led blinks once...
If the computer is not turning on, there is a big chance of hardware failure and normally there is no easy fix for this rather than a motherboard replacement.
May 03, 2011 | HP Compaq Presario 2200 Notebook
Hi i have put power supply in anbd powered up my power supp;y shows green light but when i press power on butoon on my e1705 nothing happens no lights flash nothing totally dead
Hi
Please can you try the followinf
1) remove wall charger
2) Remove battery
3) Press and hold power button down for apporx 30 seconds
4) Plug in wall charger
5) Power on laptop
6) If successful plug in battery
Regards
Shauqat
Apr 19, 2010 | Dell Inspiron E1705 Notebook
Motorola S9 headset won't charge batteries
This might work if you aren't using the ORIGINAL charger. I had this problem when my cat chewed through the original Motorola charger. I figured my Blackberry charger would work fine, but it didn't. I then discovered that my Blackberry charger was 700mAH and the broken charger was only 550mAH. When I found another charger with the proper power it charged. I also found that it worked when plugging it into my computer with a standard mini USB. I hope this helps.
Jun 03, 2009 | Motorola Mobility S9 Headphones
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Plantronics Discovery 975 (8164001 P) Bluetooth Headset Logo
731 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
