Question about Zenith P60W38 60 in. Plasma HDTV
Zenith 60" Plasma - Black Void with color spikes in upper right corner....
This Zenith Plasma TV is about 3 years old. Recently, this black void appeared with color spikes in the upper right hand corner. See attached photos. Could it be from a power outage or bad connection? How can I remove this void, if even possible? Please help. Thanks.
Why is there no answer to this question?
Posted on Jan 27, 2010
I have a 6 mo old lg 60 inch plasma tv. 2- 1" greyish vertical lines running down just off left of center.
start hunting down your warrenty info before you do anything. If you try to repair own your own you will void it at this point
Mar 24, 2011 | LG 60PC1D 60 in. Plasma Television
I HAVE THREE BLACK LINES AND A YELLOW VERTICAL LINE DOWN THE CENTRE OF MY SAMSUNG 50" PLASMA TV. ONLY 10 MONTHS OLD! WHAT CAN I DO?
The TV should be still under warranty. Most of the flat panel TVs come with a one year warranty from the manufacture. I wouldn't mess with the to void the warranty.
The problem most likely is the buffer/scan boards on the bottom connected to the screen. It controls the vertical image on the screen. The other possibility is the plasma display panel is bad.
Go the warranty route first. This may get expensive to fix.
Apr 01, 2010 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
I have 3 black stripes on my Zenith 42
Turn off the TV then unplug it. Disconnect the cable connection and clean the terminals. If the stripes still exist, you have a bad TCP (tape carrier package). It is responsible in transmitting color information to the display panel from the X-Drive (A-Bus) Board. This is not an easy repair. Service of an experienced or a qualified technician is recommended.
Nov 27, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
We were watching tv and all of a sudden we heard a
I had the same problem. We replaced the Y Sustain board. It was under $200 and not at all hard to do yourself. Remove the back of the tv. Make sure you watch what screw goes where. You will see the board on the left side. The number should be on the bottom right corner of the board. Just watch how you removed the board making small notes as to what goes where. Its really not that hard and you can save 600$ or more
Jun 06, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith 60
why is there no answer for this question?
May 29, 2009 | Zenith P60W38 60 in. Plasma HDTV
Plasma tv repair question
Thin lines down center of ESA 42"plasma tv, about 1 pixel wide each, about 3/4" to either outside line
Started as 1 then 4 over 4 months
Aug 10, 2008 | Televison & Video
5-inch black horizontal line across screen
Unplug the tv wait a minute .Plug it in turn it on see if that fix the problem. these tv are computers and can go hay wire.just like a computer ,some times a reboot will fix things for a while.make sure you have a good clean source of power at the receptical and your not having power spikes or drops . Good Luck!
Jul 28, 2008 | Toshiba 42HPX95 42 in. Plasma Television
try inspecting all caps to see if anything poped out the top or leaky. if none, try replacing the zsus, ysus and upper and lower driver boards. must do all at the same time.
Apr 09, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Phillips 42in plasma lines ocross screen
Are the solid horizontal black lines or colored lines. If colored lines there is a posibility that your Y-main, and upper and lower Y-buffers are bad. If black you have a bad plasma panel.
Oct 08, 2007 | Philips 42PF9630A 42 in. Plasma Television
Screen full of moving colored lines
I would suspect bad solder connections allowing a ground to "float" It is a common problem with the model P42W24BX which I believe uses similar circuitry as your model. An experienced repair shop should be able to get you fixed up.
Dec 18, 2006 | Zenith P42W46X 42 in. Plasma EDTV
Zenith P60W38 60 in. Plasma HDTV Logo
224 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
