Question about SkyGolf SkyCaddie Handheld GPS Unit
My skycaddie won't sync to my computer. It goes through the connection process and then the computer screen says "no skycaddie detected".
4 Suggested Answers
  • 3230 Answers
SOURCE: cant past personal info page of skycaddie sync.
Well first of all try to reset your GPS receiver, just go into the main menu/settings and then select the reset option..... (note. resetting the GPS will erase all the data from your GPS and set all the settings to the factory default). after resetting the GPS again try to sync. it. please post some comment if further you have the same problem.....
Good Luck!!
Thanks
Posted on Dec 15, 2009
SOURCE: skycaddie has shut down in the process of downloading upgrade
trying to resgister sky caddiecan,t get to activate
Posted on Apr 02, 2010
SOURCE: my skycaddie froze in transferring
perform a soft reset. hold power and joystick for 8 seconds. it will turn off. now turn on. if boots up correctly, then ok. if not, then perform hard reset. push the information button (i) and flag button at same time. while both buttons are pressed turn on power. you should be in recovery mode. if so, re-sync.
Posted on Aug 21, 2010
Register my sky caddie
To register your sky-caddie
connect to a WI-Fi network, then highlight the "Wireless" icon on the Main Menu and select it by pressing the Right Key beneath "OK".
Upon syncing, u will see a code on your device, write it down
Open a web browser on your computer and go to
http://www.skygolf.com/register
Enter the Registration Code in the code field on your computer and click Start Activation.
Follow the on-screen instructions to complete the registration process and select a membership plan.
When you have completed the process on your computer, simply select "Sync" using the Right Key on the Skycaddie. The "Sync" option appears on the same device screen as your Registration Code.
May 06, 2015 | GPS
Not syncing with an i mac OS X yosemite
This is as a result of the firewall blocking your device from connecting to you computer
To solve this you will have to add caddiesync as an exception on your firewall
To do so,do the following
From System Preferences, select Security > Firewall
If your Firewall is set to ON, select "Advanced"
You will see a list of incoming connections you are allowing. Select plus (+) to add Caddie-sync
From the list, select "CaddieSync for Mac"
You should see CaddieSync for Mac in the list of incoming connections. Make sure it says "Accept Incoming Connections" beside that item.
Apr 22, 2015 | SkyCaddie GPS
My device will not turn on nor will it sync
This is a problem sometimes with software and with devices that have been exposed to magnetic waves. Try removing all batteries from your device. Replace the battery (ies) turn on your computer and bring up the latest software for skycaddie. Plug the device into your computer and then turn on your GPS device. Your computer should discover your device and either reinstall the needed software or inform you of what the issues are and what you should do about it. If all else fails, send the skycaddie GPS device back to the manufacture so they can "fix" your issue with software.
Best regards
Jun 03, 2014 | SkyGolf SkyCaddie SGX GPS Receiver
How do I download golf courses to my sg5.
To download courses:
  1. Launch CaddieSync and sync your SkyCaddie.
  2. Select COURSES from the upper navigation bar of the CaddieSync desktop.
  3. Select the Favorites link next to Course Search.
  4. Check the box at the left of each course you want to download to your SkyCaddie.
  5. If you want to remove a downloaded course, uncheck the course in this step.
  6. Click the Download to My SkyCaddie >> button above the Favorites list.
  7. Checked courses will be downloaded to your SkyCaddie.
  8. Unchecked courses will be removed from your SkyCaddie.
  9. Click the Disconnect button in the lower navigation bar and close CaddieSync.
If you experience problems downloading courses:
  1. Turn off the SkyCaddie and disconnect the USB cable.
  2. Close the CaddieSync application.
  3. Reconnect the USB cable from the computer to your SkyCaddie.
  4. Launch CaddieSync.
  5. Click the Sync button in the lower navigation bar to resync the SkyCaddie.
Sep 01, 2011 | SkyGolf SkyCaddie SG5 Accessory Bundle Sky...
How do I renew a subscibtuion to Sky caddie?
You need the CaddieSync software installed on a PC.
  • If you have not already done so, you can download the software HERE.
  • Connect your SkyCaddy to the PC.
  • You can renew your membership on the Account Overview page in CaddieSync.
    If your membership has expired:
  • Turn on your SkyCaddie and connect it to your computer.
  • Launch CaddieSync. If No SkyCaddie Synced appears in the lower navigation bar, click the Sync button.
    To ensure your courses are updated and downloaded to your SkyCaddie, click the COURSES tab at the top of the CaddieSync screen and select Favorites. You can manage your courses on this page or download courses to update your SkyCaddie.
  • Click the ACCOUNT tab in the upper navigation bar.
  • Login with your username and password. If you do not recall your password, click Forgot your username or password?.
  • On the Account Overview page, click link the Renew link under Actions at the lower right of the CaddieSync window.
If your membership has not expired, you can use the same procedure to renew.
When you renew your membership within 90 days of expiration, you retain your current expiration date as your activation anniversary. You do not risk losing your membership by renewing early.
Dec 27, 2010 | SkyCaddie SG2.5 GPS Receiver
SG4 will not sync. display has UPDATE PROGRAM
Ran into this problem last night. Was trying to update software on Skycaddie. According to computer, everything finished. However, my skycaddie was displaying UPDATE PROGRAM VER 00.13 (B) Ready to Begin. Tried to reload last application as stated in earlier post. PC could not fine skycaddie.
Gave up and called customer service this morning. Only took a few minutes to get a live rep on the phone. He e-mailed me a link to execute that allowed him access to my computer. He tried to reload the last application as well, same result. He then ran an update program via a website, program found my skycaddie and was successfully updated. Whole process took less than five minutes.
I was fearing having to send my unit in for repair.
Dec 19, 2009 | SkyGolf SkyCaddie SG4 GPS Receiver
Locked on Update screen...will not function at all
Contacted SkyGolf directly and they were very helpful. It was a simple software reset accomplished in two steps:
On the TOOLS pulldown menu, select RELOAD, then select RELOAD LAST APPLICATION, which in my case was the latest firmware update (ver 2.2). They (SkyGolf Tech Support) also accesses your computer remotely via a HS Internet Connection and can do the entire process for you.
It then reset the last update program, which had stalled (causing the lock-up) and then all I had to do was reinstall the latest update, disconnect the Skycaddie and do a GPS RESET outside where it can capture the satellites, then do another SYNC to get it back where it was before the problem began.
I was very thankful that it did not require sending the unit in for repair or replacement.
Additionally, the newest firmware update adds SCORING capabilities to the SG4, which I think is cool.
May 04, 2009 | SkyGolf SkyCaddie SG4 GPS Receiver
How do you reset the username and password on a Skycaddie SG5?
What are you trying to login into lol the title just says " How do you reset the username and password on a.."
Im going to guess a computer? boot into safe mode (press f7 on start up) and then log in to the admin user account (no pass) from their u have access to pc from their run CMD by going start then run then type cmd and hit ok once that opens create an admin acount by doing this
net user /add useraccountname mypassword
net localgroup administrators useraccountname /add
net share concfg*C:\/grant:useraccountname,full
net user useraccountname *
ofcourse replace useraccountname with waht ever username you want and the same with password hope this helped
Feb 17, 2009 | SkyGolf SkyCaddie SG5 Car GPS Receiver
Adding a new course
You must be sure the SkyCaddie is turned on and connected to your computer. You should then launch the SkyCaddie desktop software that you should already have loaded onto your computer. The two should automatically connect and should take you to your golf course listing on the device. From this list, you can add or remove golf courses to your device by either clicking on the ADD button or the REMOVE button on the list, whichever process you want to perform.
Jan 21, 2008 | SkyGolf SkyCaddie Handheld GPS Unit
SkyGolf SkyCaddie Handheld GPS Unit Logo
211 people viewed this question
Top SkyGolf GPS Experts
Steve
Steve
Are you a SkyGolf GPS Expert? Answer questions, earn points and help others
