Question about Sony WEGA KE-42TS2 42 in. HD-Ready Plasma Television
Sony WEGA KE -42tS2
When powered on, the power comes on for a second, then powers off, powers back on, off etc. until the TV is unplugged
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: Thin Black lines going down my screen, sony Wega Ke-42TS2
These sets are common for bad connections on the ribbon cables connecting the screen to the drive printed circuit board. Or the drive circuit could have a bad drive scan IC. I doubt that but possible. Your going to need to call an AUTHORIZED sony repair servicer to trouble shoot this for you cause any other shop may not have a clue of this problem. Good Luck
Posted on Aug 09, 2006
SOURCE: Sony Plasma Wega KE-37XS920 No VideoSignal
If you still have your receipt for repair...take it back for repair again.
This time, you should have some kind of warranty on the last repair, so you should have to pay minimal (if anything) to get it fixed again.
If it is the logic board, insist that you are given the faulty one....that way you can see that it has been done and you can then dispose of it at your leisure, "knowing" you have not beem conned into paying for services not given.
Hope this helps
Posted on Oct 17, 2007
  • 4234 Answers
SOURCE: SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Posted on Mar 19, 2009
welcomejee
  • 10594 Answers
SOURCE: TV powers off after 10 seconds of powering on....
Thats great, Please rate solution.
Posted on May 19, 2009
SOURCE: sony ke-42ts2u. When you hit the power button,
i have same problem did u find the fault
Posted on Sep 23, 2009
Sony KE-42TS2U. Nothing happens when the TV is
Seems some thing wrong with power input plug or may be with power board in side the tv. first confirm with different power socket.
Oct 07, 2013 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Sony wega KE-42M1 .power lead ok . no power at tv. (no standby or power light showing at on switch). house power went off , when it came on tv wouldn't work
This confirms that the main power supply which is the SMPS is faulty.
The fuse could have failed and must be checked, if the fuse fails the SMPS is confirmed to be faulty due to the power outage.
please check the links below for tips and support:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
http://en.wikipedia.org/wiki/Switched-mode_power_supply
Sep 21, 2011 | Sony WEGA KE-42M1 42 in. HD-Ready Plasma...
Sony 42 inch plasma tv standby light just flashes tv
You might have a bad B board. What's worse is that the power switch is connected to the Q board which works in conjunction with the B board. Replace B board, You can send your B board for repair to a company called modus link pts. They are the largest part supplier of after market parts and repair.
Feb 24, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
For some reason, the component video input on my Sony Wega KE-42TS2U plasma HDTV will not work. Component video is on video 3. All other inputs work fine (coaxial, standard RCA inputs, and the digital...
Yes you need a new Q board most likely, if you audio fails after a while and your other inputs do as well then for sure you need a new Q board. It may be B board but I highly doubt. Atleast with my experiences with the KE-42TS2U.
Feb 21, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
No sound on Sony KE-42TS2
You need a new Q board, All audio processing and switching is handled by the Q board. You can get a Q board from this site http://www.moduslinkptstvboards.com/A1401920A-P8168.aspx
Dec 21, 2009 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Tv comes on and goes right back off
IT GAVE OUT A LOUD BANG AND NOW I HAVE NO PICTURE OR... Mosfet Transistor blow out.  Transistor K3316 or replace the Power unit supply. This problem was caused by a low power voltage. SONY SONY KE-42TS2U
Apr 01, 2009 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
FLAT PANEL TV
Hello, there is a possibility that the power supply is broken. Replacement of the complete power supply board Part number: 146872116 will cure the problem. Best regards, Arpi
Mar 22, 2007 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Aug 08, 2006 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Sony WEGA KE-42TS2 42 in. HD-Ready Plasma Television Logo
49 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
