Question about Neff 23 in. T4343 Electric Cooktop
Ge electric cooktop element switch need to rewire a replacement switch for 2 burner switch
  • 6 more comments
  • eadleraz Sep 14, 2010
    ge electric cooktop model jp350
    need wiring instruction for 2 burner switch
    color wire to
    P
    L1
    L2
    H1
    H2
    ge model jp350
    need wiring instructions for 2 burner switch
    COLOR WIRE TO
    P1
    L1
    L2
    H1
    H2
  • eadleraz Sep 15, 2010
    need wiring directions for a element switch that controls the dual burner on a ge electric cooktop model jp350.
    this switch has 5 posts P,L1, L2, H1, H2
    5 wires; purple, blk, red, turq, turq-blk
    i have the switch just not sure where to attach the wires, had them attached but it was blowing a fuse so I need wiring directions as to which color wire to which post.
  • eadleraz Sep 16, 2010
    model#JP350
    color wiring detail for ge elec cooktop
    element switch 5 posts
    P
    L1
    L2
    H1
    H2
    5 wires
    purple, red, black, turq and turq w/blk stripe
    need to know color to post
    No I have a new switch I need the correct wiring to posts
    Posts P, L1, L2, H1, H2
    Wires; Turq, purple, blk, red, turq w/ blk
    model of elec cooktop JP350
    cooktop model JP350
    need wiring details
    color wires; purple, turq, blk, red, turq w/blk stripe
    P
    L1
    L2
    H1
    H2
  • eadleraz Sep 20, 2010
    model jp350 5 posts P, L1, L2, H1, H2
    President:
  • 2,777 Answers
Sure thing, if you want to post the model number for the stove I can find it for you, but regardless I would recommend you call GE parts and get them to send you the correct element switch. Give them a call at 1-877-959-8688, but make sure you have the model number (found on the back of the stove, or on the manual if you have it) when you call in.
Thanks
Tim
Posted on Sep 15, 2010
  • Tim Grayson
    Tim Grayson Sep 20, 2010
    Did you attempt to contact GE for the service guide? I can't find it available online here.... you will need to contact their service department.
    Thanks
    Tim
  • 2,299 Answers
Are you looking for a new switch? I am not sure what you are asking for.
  • 1,711 Answers
Could you please give some more details on your problem isnce it is not very clear.
Posted on Sep 14, 2010
GE profile JP969 fault code F113
I took the cooktop apart I removed the terminal from the main electronic board . The left front burner has 2 white wires and 2 yellow (my case). The 2 white wires lead to the RTD sensor.With an electric meter set on OHMS check continuity between the two wires leading to the RTD sensor .If the reading is more than 1030 ohms is good if not than you need to replace the whole burner that comes as a complete unit with sensor and ribbon heating element.I found it on line for $114.00 +shipping.I wish they sold only the sensor but it would've been too cheap and not worth it for the makers . All connections to that burner are very easy put back together . Some suppliers may ask for as much as $175-$195 for the complete unit .
Apr 11, 2012 | GE 36 in. Profile JP969 Electric Cooktop
How to replace a radiant burner element wb30t10062 on a cook top not a combo, oven and cooktop
Search for my solution for a replacing the element on a JP939/JP969. That should help for similar GE models.
Sep 10, 2011 | GE 30 in. Profile JP939 Electric Cooktop
Corning cooktop burner outage
The cooktop has to be examined for failure of the element or the switch. Some of the switches & some of the elements are still around. Have the elements checked for continunity. You will have to take it out of the counter and take the unit apart to do this.
Oct 18, 2008 | Verona 34 in. CTG536S Gas Cooktop
GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Jul 13, 2008 | GE Profile JP930 Electric Cooktop
Electric cooktop burner malfunction
The outer ring of the element is most likely broken. You'll need to replace the element.
Apr 06, 2008 | Cooktops
Burner always on high
I have had this same problem on the JP350.
I have replaced the switch several times, and am now tempted to replace the heating element and the switch the next time it becomes constant (currently, it is intermittent... which has led to some burnt food).
Nov 10, 2007 | GE 30 in. JP340 Electric Cooktop
Neff 23 in. T4343 Electric Cooktop Logo
106 people viewed this question
Top Neff Cooktops Experts
Jim London
Jim London
Samyfam
Samyfam
Are you a Neff Cooktop Expert? Answer questions, earn points and help others
