Question about Samsung Televison & Video
The screen image is distorted with flashing green lines across the entire screen. If I unplug the TV and then plug it back it the normal screen returns temporarily
Hi ive got a samsung SP24Q2HL rear projetion tv
it appers not to recive signal and only has distorted screen with green lines it sometimes works but very unreliable
please help
thanks luke
Posted on May 16, 2008
Hi. Lately my tv is turning on but once the video signal is recognized, the screen goes green with vertical lines. Then the set turns off, turns back on, and then I may see a picture but the colors and...
This is a foreign voltage issue. It's very high voltage with minimal current. Milliamps to say the least. It is not dangerous. The only way to test for this voltage is with a foreign voltage tester that low volt techs and electricians use to identify charged or hot lines. You can dump this foreign voltage over the coax cable coming into the house as long as the coax cable has a ground block outside where it comes into the house. If the DTV and XBOX are unplugged you say that it doesn't do it, correct? What other peripherals do you have plugged i when you unplug these two? Well, if that's the case then the problem is not your TV it's either the XBOX or the DTV. I diagnose these issues for AT&T Uverse and have come across similar situations like this one. How this voltage comes across the frame is too complicated to explain in this forum. First, determine whether or not it does it with just the DTV box hooked up. Isolate the problem down to the particulars. This voltage will pass over any connection between the peripheral and the tv. this voltage will cause other small problems like voice and video not sync'd, delay on channel changing, automatic shutdown of individual peripherals, etc. Do you have any of these symptoms? I can help you, but we need to establish a question answer forum to go further. Answer these questions and try to get more troubleshooting data. Excellent narrative by the way. Let me know.
Jan 26, 2011 | Samsung LN46A550 LCD TV
1 vertical line across the screen maybe 1" tall. It appears to have the entire picture in that short little space.
tv turns its self off i unplug it plug it back in it will flash on not showing picture it u can her it flash on and right back of some times it will not flash in back of tv and i can hit power it will flash and go off every now and then it will come on show picture after being unplugged and plugged back but then shuts off
Jul 16, 2010 | Toshiba 36A50 36" TV
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
Blurry Line at Top of Screen
Unplugged the TV overnight and it seems to have gone back to normal.
Jun 25, 2008 | Panasonic PT-51G43 51 in. Rear Projection...
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
LCD screen shows weird colours
Gimbo again. Think LCD damaged will need to repair. Pics. as normal when viewed or printed.
Why has nobody commented?
How much to replace screen? Any ideas?
Feb 16, 2008 | Cameras
Pinkish screen and green blurred picture
Sounds like the image sensor is malfunctioning (common symptoms: distorted images with purple or green cast, completely dark images, flickering lines across the screen.)
Oct 26, 2007 | Kodak EasyShare C643 Digital Camera
DSC-W70
try putting it in the auto mode > green camera symbol or it may be a ccd or lense alignment problem
Sep 17, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Open Questions:
Televison & Video Logo
118 people viewed this question
Henry  Thomas
Henry Thomas
