Question about Teac R2 Clock Radio
My battery does not hold a charge for more than four or five minutes. Where can I purchase a replacement. Regards, J. Coleman.
How to change the battery for my 4345 coleman lanterne
There are two adapters for that lantern; one for the house and one for 12volt. You simply connect one of the adapters and it will power the lamp and also charge it. Those two adapters came with the lamp; if you don't have them you can contact Coleman to purchase replacements.
Jul 29, 2014 | Coleman 8D Family Size LED Lantern -...
I have a portable DVD player,Yukai 700 I have charged the battery several times , but it only lasts five minutes in its dead. Once I charged it for three hours done for seven hours in the last time 24...
This means that the battery is unable to hold a charge any longer. THe only option in this case is to replace the rechargeable battery for your Yukai 700. A battery has a charge life meaning you can only charge it for a set number of times. It seems that it has already exceeded that.
Aug 14, 2008 | Mustek Televison & Video
I just purchased these phones and they will not keep a charge
1-888-331-3383
Mon-Fri 7:00AM-7:00PM CST
(Corded/Cordless Phone email)
Jul 13, 2014 | Motorola Mobility DECT 6.0 Cordless Phone...
Battery won t hold charge
If your battery does not hold charge, and you don't want to buy a replacement, then there is not much can do other than to keep using your laptop with the charger. All batteries have a time life span.
Jun 19, 2013 | Acer Computers & Internet
I have a TI84 plus texas instruments i have removed both the batteries in order to reset the unit but it still has not resetted the unit. All I am getting all zeros on the screen
First try removing all four AAA batteries and the small lithium backup battery (above the four AAA batteries). Leave all batteries out for five minutes, then replace them and try to start the calculator. If this doesn't work...
Replace all but 1 AAA battery. Press and hold the "CLEAR" button on the calculator. While holding the "CLEAR" button down, replace the missing AAA battery. While still holding the "CLEAR" button, turn the calculator on. The display should read "RAM Cleared". Release the "CLEAR" button and press again to remove the message.
If that doesn't work, remove 1 AAA battery again. Repeat the preceding instructions with the "DEL" key: With the battery removed, press and hold the "DEL" key. With the "DEL" key held down, replace the battery and turn the calculator on. The screen should say "Waiting... Please install calculator software now." Release the "DEL" key. Download this program onto your computer (from Texas Instruments). Connect the calculator to the computer using the USB cable provided with purchase. Run the TI OSDownloader program and follow the on-screen instructions to re-install the calculator's operating system.
Apr 30, 2011 | Texas Instruments TI-84 Plus Calculator
Coleman Spotlight PML8000 lasts only a few minutes when charged
your battery is gone. chk with coleman for replacement
Dec 13, 2009 | Cars & Trucks
We Dont Kno!!!
Check your mains adapter plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop power it up then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. I suggest you get a quote first.
Oct 02, 2009 | Dell Inspiron 6400 Notebook
Dead battery?
The battery is a commonly available 6 volt 4.5 ah sealed lead battery. Interstate has them and many other suppliers. I think same battery used some security systems...
Jul 05, 2009 | Coleman Hot Water On Demand
DELL XPS 1210 i purchased a replacement battery not recognised
If the battery is not detected in the BIOS (F2 at boot) and doesn't show as charging, then return the battery and get a replacement.
If neither the original battery or the new replacement battery are not detected in the bios a problem with the motherboard may exist. If still under warranty, contact Dell Support for a repair, if not, then you may be investing in a new motherboard
Jan 29, 2009 | Dell Inspiron 1501 Notebook
Teac R2 Clock Radio Logo
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
