Question about Philips Magnavox 9P6034C 60" Rear Projection Television
I own a Philips Magnavox 55P8288A Projection television. The picture is dull (dark) and a friend suggested I get a new bulb. Also, the remote no lionger functions, so I bought one of those, too. Now I cannot find instructions on how to install the bulb. The generic "instructions" I found do not apply -- taking off the front panel reveals only the speakers and a solid piece of fiberboard. Where, please, can I find instructions??? Thank you. ~ Michael in Phoenix
  • 1694 Answers
SOURCE: Philips 55PP9401 55 in. Rear Projection
First, repair convergence problem = replace both convergence
IC's ....STK392-110 sub to upgrade STK394-160E....I use
Hitachi part # CZ 01341.......next, look for discolored resistor
near IC's.....replace with exact value......last = activate
Auto-Intellisense.....................T.
Posted on Nov 26, 2007
  • 3 Answers
SOURCE: philips magnavox tv motherboard
part warehouse out of dallas 1 800 321 6993 give model No. they have a research dept. 48Hr call back
Posted on Dec 11, 2007
Slinteriors
  • 8617 Answers
SOURCE: Bad Picture on a Projection TV Magnavox 55P8288A magnavox
Change the coolant inside the CRT this will restore the color and clarity to 100% on your set.
Posted on May 25, 2008
johnnydiode
  • 647 Answers
SOURCE: Philips 55P8288A tv has a dull color and a red
This sounds Like the the coolant for your piture tube has become cloudy and needs replacement (usually blue or green tube - thats why the image seems ovrely red).It's a big job (labour wise) since completee dissassembly is required ($200-300). It can be done youreself - check out TVrepairkits.com to get the coolant and instructions.
You can confirm that this is the problem by dissassembling the unit to the point where you can view the face of the CRT's (red green and blue) directly.
Posted on Nov 28, 2009
Ecollier2012
  • 3459 Answers
SOURCE: bad dull color on a
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Posted on Apr 18, 2011
Hello, My picture has gotten very dim and dark. I was told my bulbs need cleaning. How can I do this by myself or do I have to hire someone to do this for me. Thank you, Debbie
Its more likely that the CRT coolant needs replacement. Thats vert famous for that model. The CRT coolant gets messed up and the CRTs cant project the image properly so it gets a dull picture and the color tints are wrong.
Sep 01, 2011 | Philips Magnavox 51MP392H Rear Projection...
Philips 55P8288A tv has a dull color and a red hue.
Nov 28, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Projection television picture trouble
picture tubes are fine. just need to change out coolant
Oct 26, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture on 47' philips magnavox is dull looking. Is there a light inside that needs to be replaced?The picture is dark looking.
If it does not have a tube, then it will have bulb(s) & IC's or STK's. Everything depends on what type, lcd plamsa, projection
Oct 22, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox 55P8288A Picture is cloudy
You can purchase a factory one from www.remotes.com. and for you manual you can download it here just click on get manual http://www.retrevo.com/s/Philips-50ML8105D-TVs-review-manual/id/277ag615/t/1-2/
I sure do hope this helps you and thanks for using fixya.com
May 24, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Coloring going out on big screen
the tubes go for around 300 each and you have 3 of them, But you dont need new tubes. Change the CRT coolant and you will see your color will come back and so wont the clarity.
May 30, 2008 | Philips Magnavox 51MP392H Rear Projection...
May 25, 2008 | Philips Magnavox 51MP392H Rear Projection...
Magnavox Projection
What is model number? A magnavox 51MP392 is a CRT rear projection type and doesn't use a bulb (unless he was refering to the CRT's as bulb). And they are prohibitively expensive.
Jan 02, 2008 | Philips Magnavox 51MP392H Rear Projection...
51 projection tv dark colors
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 20, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
157 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
