Question about Car Audio & Video
I changed the battery on my 94 mitsu 3000gt sl and now I need code for the radio, what do I do?
  • 30 Answers
Check the ownes manual. the codes are usually set by the user..the dealer may have a mastre reset code also
Posted on Sep 15, 2010
TENGO UN MITSU 94 3000GT V6 Y NECESITO PONERLO A TIEMPO, COMO PUEDO HACERLO?
es facil si es soch pero se es doch es un poco mas complicado este es mi e-mail correhastaconlasombra@live.com ahi pudes conseguir imagenes y te puedo explicar como ponerlo en tiempo
Jan 23, 2011 | 1994 Mitsubishi 3000GT
I need a radio manual so I can program my 94 satturn sl model car. I bought it used and no way to program the radio, no instructions.
You will need to go to the Saturn Dealer to obtain the code, the Radio Code Is VIN# specific. Check your Owner's Manual, sometimes it is printed inside of there, or the previous owner may have written it down.
Aug 12, 2010 | 1994 Saturn Sl
1994 mitsubishi 3000gt/sl has infinity stereo. have security code and still cant get the radio to come on. can you help? all it says is oFF now
I just figured everything out and it's pretty easy. First though, if you're seeing "off", from what I understand it's because you put in a code that wasn't right. You only have 3 chances before it shuts you out. Leave it alone for about an hour and try again. All you need to do now is write down your vin # (mine was on the car inside the drivers side door) then pop off the cover of your radio with a flat head screw driver. After that, there are 4 phillips head screws holding the radio in, remove those and the radio will lift right out. Don't pull too hard because you could unhook some wires. On the top of the radio you'll find a sticker with the serial number and the model number. Write those down. Go the the Mitsubishi website and hit either "help or mobile", sorry, I forgot which one. That'll take you to a list of problems, etc.. Click on radio code and fill out the short form that will ask for the serial #, the model # and the vin #. The code will be sent to your email, mine came immediately. Then just follow the very easy steps. It really is easy plus you won't have to call the dealership. It took me about half an hour. Good luck! I hope this helps.
Jun 20, 2010 | 1994 Mitsubishi 3000GT
Battery dies in one week. Alternator or short? '94 Mitsu. 3000GT
Battery drain is a Classic sign of a bad Alternator voltage regulator. Typically internal to the Alternator. Assuming that your are not driving the vehicle for a week and it then drains the battery. If not, then possibly a bad alternator anyhow. I believe that 13.6 volts is the correct charging voltage from an alternator.
Feb 27, 2010 | 1994 Mitsubishi 3000GT
Fork engaging slave cylinder from tranny. (91 3000GT, mitsu)
Called a clutch fork Holds the thrust bearing right? and goes through the clutch (Bell) housing Got to be careful here or Is it the rod that goes directly into the slave cylinder? Either way as long as the rest of the cars ok it's worth keeping If it's the clutch fork you going to have to remove gearbox (Not the end of the world) Part won't be that expensive
Oct 22, 2009 | 1991 Mitsubishi 3000GT
Where is the thermostat on a 3000gt
The mechanical water thermostat on the 3000gt is right under the metal water cap just to the left of the engine and next to the spark plug wires. The cap will have a warning about not opening if the car is hot as the water is pressurize and can spray out. If you want to replace the thermostat I recomend you use a genuine Mitsu thermostat. I beleive all years, base,SL and VR4 are the same but have a look at mentor mitsubishi http://www.trademotion.com/partlocator/index.cfm?siteid=213934&year=1993 for the right part and useful images. They also have a good discount price. Select your year, then make and model and look under COOLING SYSTEM->COOLING SYSTEM->THERMOSTAT.
Another useful place to look for 300gt information is 3si.org and stealth316.com
Replacing the thermostat you will lose some coolant so be prepared to catch it and top it back up afterwards. You will also need the rubber gasket that goes around the thermostat if your's is old.
Jun 15, 2009 | 1994 Mitsubishi 3000GT
Car Audio & Video Logo
54 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
