Question about HP PSC 1350 All-In-One Thermal Printer
Scanning documents I am trying to scan my resume and letters of reccomendation to word but the scanner is not reading the signatures on the letters and so they are comming out wierd, like with bid letters, and small and &&^^$$##, this kind of stuff, whats wrong and how can I fix it>>
    President:
  • 173 Answers
Basic steps:
1. Check all connections to make sure they are all seated properly.
2. Uninstall and reinstall the software.
3. Uninstall and reinstall scanner drivers.
4. Check manufacturer's website for updated drivers
From your description I would say try steps all the following steps in order, but it sounds like the device drivers might be the problem (but always try the simple stuff first.
Posted on May 16, 2008
I need instructions on how I can sign an email document that requires my usual signature via an email attachment on the computer screen. doe's it need scanning first i'm not sure how to go ab
Of course, you need to print and scan:-
1-Print the attached document !
2-Write your usual signature on the printed paper
3-Scan the paper by any scanner
Mar 18, 2012 | Computers & Internet
Error Code 2 on a Bell & Howell Copiscan II 3338A Path-Through Scanner.
02 - Automatic feeder time out. Ten seconds have elapsed since scan command was issued and no document has been scanned.
Place documents properly in the automatic feeder and press CLEAR key. if scanning does not resume, use the workstation keyboard to request a scan.
Jun 01, 2011 | Bell & Howell Copiscan II 3338A...
Hello, I am having a problem with a newly bought HP deskjet 2050 all in one; when scanning some of the documents end up with ~1inch cut off even though they are standard letter size. Any suggestions?
Make sure you are placing the page in the scanner properly, most will indicate what corner/edge the scanner begins scanning from, you may also try checking the settings for the scanning software to make sure its set to letter, or try setting it to legal if its already set to letter.
May 29, 2011 | Office Equipment & Supplies
How do I use my x5495 to scan a resume and then to edit it with my Dell XP computer?
You'll need to scan the document with an OCR software package (Optical character recognition) that will recognize the letters themselves and transmit them to word processing application, such as Word for Windows. Most scanner packages come with some form of OCR utility, so check your installed software. You may already be set up!
Best of luck, William
Mar 03, 2011 | Lexmark Office Equipment & Supplies
Scanning to a word doc so i can edit the doc
You need to buy or download OCR software to your computer. The scanner doesn't control that, the only way to get a word document from a scan is to "read" the document with OCR software.
Feb 25, 2010 | Canon PIXMA MP780 All-In-One InkJet...
I'm having trouble scanning B&W documents with my Epson V300. The edges of the letters in the text are jagged and hard to read and there is what appears to be a crease or fold in the document when the...
You have two options for scanning text. You may explore both of them and see which is better for you. Either way, you will have to make friends with manually changing the scanning settings, because simple presets often are not suited for every case.
First is to use Grayscale mode, and a minimum resolution of 200dpi. This should give you satisfactory text quality. If you want to print the text afterwards, 300dpi would be even better. You may want to increase contrast, to get the letters more defined and eliminate most of the background toning.
Second is to use Black and White (monochrome) mode, but in this case you need to set the resolution higher, preferrably to 600dpi. Also in this case you will have to play with the Black/White threshold in order to eliminate background "dirt" appearing as black artefacts.
If you scan the documents in order to process them with OCR software, usually the OCR application will give you suggestions on how to set the scanning parameters to obtain good results.
Jan 24, 2010 | Epson Perfection V300 Film Flatbed Scanner
My Umax Astra 1220U Flatbed Scanner will scan but the image comes out with a dark "haze" so as to barely read the document. What I am scanning is on white paper with black lettering. Can you help?
It probably needs cleaning. I had a streaking problem with my UMAX 1220 and followed the instructions on this website
http://www.willshak.com/scanner/
Remember to disconnect from the electricity supply!!!
The job is not too difficult and it restored my scanner perfectly.
Mar 17, 2009 | Umax Astra 1220U Flatbed Scanner
Scanning not picture perfect. In scanning a letter - the symbol on the letterhead did not print correctly nor did the signature part. The left margin also increased by 1 character. Bert
It is possible that teh letterhead is too light that the scanner cannot see it any longer. can you try another document and see if the same problem occurs. If not then adjust the scanning settings.
Sep 16, 2008 | Computers & Internet
What's the best program to use to scan old letters?
Do you have microsoft office.
if so, There's a little used program in the  directory on your start/programs/microsoft/microsoft office tools called Microsoft office document and microsoft office scanning.
Also, what software came with the printer/scanner. there's usualy a decent one bundled with them. if possible you may be able to scan to pdf. (pdf reader free from adobe)
Markbaker, as long as the scanner is installed correctly, then, again, in office or similar programs there should be an option to insert from scanner. click on that and it should bring up the scanner software to complete scan.
Mar 08, 2008 | Dell 922 All-In-One InkJet Printer
HP PSC 1350 All-In-One Thermal Printer Logo
23 people viewed this question
Ben Johnson
