Question about Radio Shack 3 in 1 Universal Remote
How to auto program radio shack Cat.No 15-302 to my rcv t.v
  • 20 Answers
SOURCE: i lost my code list
Go to http://www.radioshack.com/product/index.jsp?productId=3964905#tabsetBasic
You can get the manuals and a code list.
Posted on Nov 11, 2010
  • 4 Answers
SOURCE: trying to program my Radio Shack 15-2147 remote to my emerson tv
I need the Sony TV code for 3-in-one remote
Posted on Dec 14, 2008
  • 7 Answers
SOURCE: I misplaced my booklet with
Hi what exactly is it you need to do. Reprogram your remotes?
Posted on Sep 21, 2010
Axiam-PC
  • 15 Answers
SOURCE: I have the radion shack hdtv remote. Cat no
Download the manual and codes from here
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/radio_shack/15135-manual.zip&area=other
Here is how to set the code...
1. Turn TV on
2. Press TV button on remote
3. Hold P button on remote until LED blinks twice
4. Enter the first 5 digit code for Magnavox TV's
5. Press Power button - TV should turn off. If TV doesn't turn off repeat steps 2-5 with the next 5 digit code, until either TV goes off or run out of codes.
6. If out of codes use searching for code method below...
TV codes for Magnavox
10047, 11454, 10054, 10154, 10000, 10250, 10051, 10180, 10060, 10030, 10171, 10092, 10706, 11913, 11904, 11755, 10019, 11365, 11254, 10802, 10386, 10282, 10020, 10187, 10186, 10024, 10179, 10096
Searching for code
1. Turn on TV.
3. Press and hold P button until LED blinks twice
4. Enter code 991 on remote - LED blinks twice
5. Press 1 - Device key blinks twice
6. Press Power button once
7. Press and release CH+ key until TV turns off.
At this point in the manual, the manual is only correct depending on what type of TV you have.
In the manual if you press the Power on button the TV should turn itself back on, the fail to state that not all TV's turn on by the power button, the majority now are triggered to turn on, on channel change, however you can't use channel change here to check it as you'll go to the next code... here is my solution...
8. Turn TV back on either using original TV remote, or buttons on front (most TV's if you change channels they come back out of standby mode, very few now turn on by pressing the power button).
9. Press Power button on remote - TV should turn itself off again.
10. Press P button on remote to lock in that code.
If the device does not turn off press CH- to go back through the codes, press and release P button when TV turns off.
Finding code
If you used the search function you might want to know what code it's using. To do this follow these instructions...
1. Press TV button
2. Press and hold P until LED blinks twice
3. Enter 990 and LED blinks twice
4. Press 1 and count number of times LED blinks this is the first digit of your code (e.g. 1 blink = 1, 2 blinks = 2, etc).
5. Repeat step 4 pressing buttons 2 - 5 for the other digits (e.g. for the second digit press 2 count number of blinks.. etc)
At this point the manual doesn't tell you how to get out of this mode, I presume pressing any other button on the remote other than 1-5 will take you out of this mode, either that or leaving the remote alone for 5 minutes.
Posted on Nov 08, 2009
jyackle5
  • 8197 Answers
SOURCE: i have a u. remote
This link will take you strait to your manual
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/1502142_PM_EN.pdf
Posted on Apr 24, 2011
Need Radio Shack weather radio Cat. No 12-521 manual
Step 1:
CHECK OP (Check Operation) means your radio has not received any type of
SAME alert signal (include test or demo signals) for about 10 days.
Make sure the antenna is fully extended and the stored location is correct. See
"Programming Locations and SAME Codes" on page 9 for more information.
Step 2:
Here is a link to the manual
http://www.radioshack.com/graphics/uc/rsk/Support/ProductManuals/1200521_PM_EN.pdf
Dec 06, 2012 | Radio Communications
Need a Owner's Manual for Radio Shack TAD-3822 (Cat. #433822)
here is a link to the page where you can get your owners manual
http://support.radioshack.com/productinfo/DocumentResults.asp?sku_id=43-3822&Name=Search%20Results&Reuse=N
Aug 30, 2009 | Radio Shack 3822 Digital Answering Machine
Computer Interface
Rat Shack say they will load your scanner at no charge . The program is called Scan Cat I think .You can get the program on the net .Every Rat Shack has the program on the store computers . The 94 is not a bad scanner .Hope this helps .
Apr 19, 2008 | Radio Shack Pro-94 Scanner
VAN AUTO HOOK UP KD-HDR1
This radio can not use a common ground. If your speakers are all grounded together you will blow up the amp IC in the radio. The negative speaker wires run at about 6 or 7 volts and so do the positive speaker wires.
Trust me, run new speaker wires, do not common ground any of these speakers
If this was helpful a good rating would be appreciated.
Mar 08, 2008 | JVC KD-HDR1 CD Player
Magdy
Hi there... It will be one of these codes.
Philips 1454, 0054, 0690, 1961
you can download the whole manual at
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=radioshack&dv=universalremote&md=1521473in1easytouse&kw=&st=&ar=&dt=&so=&pg=3&file=others/radio_shack/152147-manual.zip
Good luck. A fixya rating will make me feel good!!
Jan 16, 2008 | Radio Shack (15-2147) Remote Control
Radio Shack 3 in 1 Universal Remote Logo
1,937 people viewed this question
Top Radio Shack Televison & Video Experts
Computer Repairing
Computer Repairing
xxxxxx xxx
Are you a Radio Shack Televison and Video Expert? Answer questions, earn points and help others
