Question about Vacuums
I have a Danby ice maker that is stuck with the full tray signal, blinking. It can not make ice in this position. Machine function in clean mode, all parts work. Can I bypass this signal?
    President:
  • 4,070 Answers
Hi! As a first course of action please unplug the unit from power source and let it sit for atleast 5mins to reset the system. Once the system is resetted, you may get rid of the signal. Hope this helps and thank you for using FixYa!
Posted on Sep 14, 2010
FoodSaver V3240: Lights flash,,,won't operate...what's wrong?
Pull out the long rubber piece on the top, clean any debris, replace firmly.
Aug 10, 2014 | FoodSaver V3240 Vertical Vacuum Sealer
Foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Jun 03, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
My DC24 will not switch from floor to carpet mode? Roller is not stuck or full of lint. Bagless is clean.
I'm sorry to hear you're having difficulties with your DC24. If the brushbar will not rotate when the brushbar switch is pressed, you may need to reset the machine.
With the cleaner facing you, you'll find a button in the red recess on the left-hand side of the cleaner head. Press this in until you hear an audible 'click' - it may help to use something like the eraser-end of a pencil to do this.
The brushbar will never rotate when you have the machine standing in the upright position, so please make sure you have it reclined into the vacuuming position before testing it after pressing the reset button.
This should resolve the issue - however, if you do need any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can help.
Best wishes,
Jack
Dyson Online Customer Support
Jan 26, 2012 | Dyson Ball DC24 Bagless Upright Vacuum
The ice tray is freezing up . what can be done to fix this problem. I have a magic chef ice maker MCIM30SST
This answer came straight from the manufacture:
Stop the ice maker, and restart when the ice blocks melt. Select the
small ice size. Also Change the water in the reservoir.
Use water between 45 -90 F.
Not sure if that will do it but that is the only fix we could find straight from the manufacture. We wish you the best.
Mar 06, 2011 | Vacuums
We have the water hooked up at the back of machine. there is a spout for the water to come in and fill the ice tray.but is does not. If we turn the water on it fills up the space under the ice basket. I...
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
With the fill tube blocked with ice the water can drip down the back wall or drip into the ice bin or just stop up. You can use a hairdryer to thaw the tube out.
Feb 18, 2011 | Vacuums
Cleaning mr coffee ecm3 how
Deliming
SUGGESTED CLEANING SCHEDULE
Type of Water Cleaning Frequency
Soft water every 80 brew cycles, Hard water every 40 brew cycles
Your espresso maker may be delimed using one quart of white household vinegar. Clean the water tank first, following steps l-5:
1. Make sure the steam control knob is in the center off position and that the plug is disconnected from the electrical outlet.
2. If the machine is cool and the pressure has been released, remove the pressure cap and pour 10 ounces of undiluted white household vinegar into the water tank.
3. Screw on the pressure cap and allow machine to sit overnight with the vinegar solution in the water tank.
4. Remove pressure cap and discard vinegar through the top opening of the espresso maker.
5. Rinse the water tank thoroughly with tap water, repeating this step twice.
To wash internal parts:
Make sure you clean the inside of the water tank first. Remove the pressure cap and pour 10 ounces of fresh white household vinegar into the water tank. Screw the pressure cap back on top of the water tank. Make sure the cap is on tight. Insert the filter holder into the brew head and place the glass decanter with lid on the drip tray. Plug the machine into the electrical outlet and turn the power switch on. An indicator light on the power switch will tell you the machine is on. Place a cup with cold water under the steam nozzle. When vinegar begins to flow into the decanter, insert the nozzle into the water and open the steam nozzle slowly by turning the steam control knob downward. After a few seconds, close the steam nozzle by turning the knob back up to center. This will clean any residue left in the nozzle from frothing milk. When all the vinegar has been pumped into the decanter and the flow has stopped, turn the power switch to the center off position and allow the machine to cool. Repeat steps 1-7 twice using only tap water to rinse any remaining traces of vinegar out of the machine.
Decanter cleaning
1. Pour warm white vinegar in the decanter and let soak for 20 minutes.
2. Discard the vinegar, Wash and rinse the decanter thoroughly using a
soft cloth. Do not use harsh abrasive cleaners.
Dec 12, 2010 | Vacuums
I am looking for a specific part for a Nostalgia Electrics RIC-100 portable ice maker and I am finding it very hard to find what I am looking for if I could get some help that would be great. The part I...
Try to google for it but if unsuccessful you may have to resort to some sort of repair that will do the trick. May not look great but if it works, then.............................
Aug 24, 2017 | Vacuums
The tray full light stays on even though the tray is empty.this prevent the foodsaver from operating.I have tried unplugging,recleaning the tray but nothing works
I had the save problem with my 3400 series.
The first time i was able to let it dry and it worked alright (48 hours).
The second time even this did not work.
If you remove the screws on the bottom of the unit. There are about 10 and pull it down, you will see the sealer assembly and a small circuit board in the middle.
Trace the wires from the drip tray, there are three of them, red white and brown, to the small white plastic JST connector on the small circuit board. Pull said connector gently to disconnect it.
The unit will function perfectly now, although it will no longer have a drip tray sensor of any sort it will function every time all the time.
All in all this took me about 10 minutes.
Thanks!
Sep 09, 2010 | Vacuums
I have full suction with the hose and when the brush is off of the vacuum. However, in the vacuuming position, there isn't enough suction to pick anything up. I checked for clogs and cleaned all the...
So I have exactly the opposite problem, it sucks in floor mode but the hand held has zero suction. My daughter and i just spent the last hour disassembling and diagnosing and found this: The way the suction tube is configured, you have two places to **** from, the floor and the hand held hose. If you look at the back of the machine, you can see the "y" where the two hoses join. just behind the beater bar there is a blast gate that closes when you stand the machine upright. This closes the blast gate and directs full sution to the hand hose. In floor mode as the handle tips back, a follower wheel and spring move the blast gate to open. THIS IS THE IMPORTANT PART...if the hose is not docked, there is a second place for the suction to go and you will get no suction at the floor. In my case, the center post where the spring mounts is broken and the blast gate flap does not close, so the hand hose gets no suction because it is like a straw with a hole in it, the air will seek the least resistance. In your case you either have not returned the hose to the docking port or your blast gate is stuck in the closed position. To check this remove the two screws and clamp that secure the lower hose to the suction manifold. Pull the hose stright an look inside to see if the blast gate is open or closed. Use the release pedal to cycle the machine between upright and floor mode and you should see the blast gate open and close. If you don't, well that's a whole other story. I'm off to see if I can find a replacement part at repairclinic.com. If not I will have to get some polyester epoxy and fix it myself.
Jan 02, 2010 | Hoover U6630-900 WindTunnel Bagless...
F6055-900 SteamVac Maxextract LS
Might just be a bad sensor, or it is coated over with dirt. If the tank lid has one of those round filters on it, make sure it isn't pushed all of the way up to the top, needs to have a 1/4 inch gap.
Jan 03, 2008 | Hoover F6055-900 SteamVac Maxextract LS...
Vacuums Logo
59 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
