Question about SanDisk Sansa e250 MP3 Player
Troubles, "finalizing" I have a Sandisk Sansa m240. I just downloaded music last night and checked it right after. It worked fine all the songs I downleaded. THen today I turn it on and it shows a screen that says "finalizing" with a time bar that says 0 at the left and -2:55 at the right. It shows no progress at all. Please help me, Rob
  • 8,596 Answers
Finalizing is normal, unless it gets stuck for over 30 minutes
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
I cant find place to add music files to my player, SanDisk Sansa m240... I go to my computer open the files and find no music library
use windows media player... open WMP connect your player it should recognize it... use this to sync music to your sansa...you highlight the songs in WMP right click ... go to add music .. select sync .. once you get the songs into a sync list ... you just sync the sansa...
Oct 16, 2009 | SanDisk Sansa m240 MP3 Player
How do you delete songs off of a sandisk sansa m240 music player
In My computer right click on the mp3 player and select format..then it will delete all songs..
Feb 27, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m240 player
I dont know if the mac is the same as windows, but plug it in. Go to my computer. You should see Sansa m240, or F:\, or a personalized name (right click and click rename). Copy the songs you want and paste them in the player. It should pull up a message that says copying. When it's done, you can unplug it and listen to your music
Dec 07, 2008 | SanDisk Sansa m240 MP3 Player
Formatting sandisk sansa m240
how to download songs and delete the songs
Jul 05, 2008 | SanDisk Sansa m240 MP3 Player
Downloading
Will not work with iTunes, but will work with just about any other music service. Use Windows Media Player to transfer songs to player.
May 26, 2008 | SanDisk Sansa m240 MP3 Player
My Sansa m240 does not play music, it freezes.
Try going into your USB Settings on your device and ensure the unit is set to msc
Jan 09, 2008 | SanDisk Sansa m240 MP3 Player
Sansa m240 and itunes
Probably not, try going to where the songs are all stored [My Music] select all the songs and open with the Sansa converter-to transfer music or use Windows Media Player.
Otherwise open My Computer then SansaM240 folder and drag the songs into Music.
Dec 25, 2007 | SanDisk Sansa m240 MP3 Player
Adding music.
open up windows media player and select copy to disk or device then drag you r songs to the right side of the screen and then on the left select the bar and find sandisk sansa m240 and then click the copy button
Aug 02, 2007 | SanDisk Sansa m240 MP3 Player
Sandisk miro 1 gb ho to put songs on
You can burn songs off of a cd or download them. If you have Windows Media Player, make sure you have songs on your library. Highlight the songs you want, go to "sync", and they will be on your device. If you DONT hae windows media, just burn the songs on a file, and drag and drop them in the music folder of your sansa m240
Apr 02, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
51 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
