AC repairman said the evap coil had a leak so i had him put in a new one. he charged $425.00 does this sound reasonable
    Scholar:
  • 120 Answers
total cost? or just for the coil.
If its total cost it's very reasonable and I would say a fair deal. If that's just for the coil thats at leaset 100% markup
Posted on Sep 14, 2010
  • 144 Answers
Yes that sounds very good you have to add freon its not cheap much less the problems you have with repairing coils he is a honest guy and you need to keep him around its hard to find honesty
Not cooling room and every 45 seconds it makes a hum noise
window unit ac !! not a fridge . the hum you hear is the ac compressor trying to come on , but due to loss of gas charge it shuts right off again , this will require a professional ac repairman to fix this , 1st he needs to find leak then repair leak then add back lost gas charge , watch cost of all these services vs cost of entire new unit , it could get expensive
Jun 24, 2015 | Refrigerators
2003 Ford expedition AC question they want to replace the condensor, compressor, evaporator coil and condensor coil. how reasonable does that sound?
you have a leak and if you can hear it or smell it its a good one, most likely its a connecting leak where ever the components connect to each other. with an internal seal leak, such as compressor or evaporator, your freon will last about a month,with a external connection leak, your freon last a couple days
May 24, 2013 | Cars & Trucks
Ac line freezing up from outside to house
AC lines freeze on the outside of the house when the insulation for the copper tubing is damaged or missing. if this is not the case in your situation, there may be a small refrigerant leak in the tubing.
Hope this helped you and thanks for choosing FixYa.
Aug 24, 2011 | Heating & Cooling
I am having window 1.5 ton ac not blowing cold air .
Hello, could be dirty filter, dirty evap coil, or a low refrigerant charge due to a leak
May 11, 2011 | LG LS-L1210CL Mini Split Air Conditioner
My 99 saturn sl drains the battery and the heater fan and ac won't work. I got a new battery and it drained it and won't take a charge again. can anyone help? chuck
Sounds like 2 probloms there is a bad alternator so the battery is not being charged, and the fuse for the heater/ac fan is bad
Jul 12, 2010 | 1999 Saturn SL
Ac does not put out very much cool air nor volume. Coolant has been charged.
The problem isn't with the ac , it's with the blower fan - apparently it only works on the lowest speed. Check the fan button and the wiring from it to the fan.
Jun 26, 2010 | 2000 Toyota Celica
How much should I expect to pay to replace a leaking coil model number is CD5AXW030017?
Well first off - 99% of coils (evap/condenser) can be 'repaired.'
In which case - you're probably looking at a repair bill of between $100 -$200 depending on factors such as type of unit, i.e. window unit or central unit, easiness of repairing the leak, whether or not your refrigerant can be saved i.e. by pumping the unit down before repairing it - and average AC - labor rates in your area.
If you do require a 'coil change-out' - then the same factors apply - although I'd rather buy a 'new' window unit than pay for a coil to be replaced - because the cost will be close to the cost of a new AC.
If a central unit - you're looking at around $500-$700 to replace one of the coils.
good luck!
Jun 23, 2010 | Heating & Cooling
I have a 2000 Dodge Intrepid that smells funny when I turn on the AC. I have looked it up and the forums say to change the Cabin Air Filter. I can't find where the filter is?!
You do not have a cabin filter....Two things......you need to check (freon preasure) you may have a freon leak from the AC evap coil behind the instrrment panel,the smell is AC freon pag oil from the AC system, it smells funny. Or you may have mildew build up on your evap coil there is a spray to disinfect the coil.Check auto zone or pep boys....Good luck my friend
Sep 20, 2009 | 2000 Dodge Intrepid
Refrigeration
Your pressure sound pretty good. I would check the thermostat and the relay on the compressor. If you are getting no frost on your coil, that is usually a tall-tall sign of a bad compressor then it would be better to just replace the unit.
Apr 22, 2009 | Frigidaire FRT21H8 Top Freezer...
After running awhile ac blows warm and theres no water in evap tray.
Hi, Sounds like you have a leak in the lines somewhere and it is low on refrigerant (Freon). If the evaporator spends very much time below 32deg it will freeze up and you will feel very little air coming from the vents. The evaporator will have ice covering at least part of it depending on how much refrigerant is has in it. No refrigerant, there will be no ice or water. If the unit is properly charged, the larger of the two refrigerant lines at the condensing unit will sweat all the way back to the compressor but the compressor should be fairly dry. Restricted air flow will also cause one to freeze so check your air filter. If the ac tech thinks that the evap temp was ok at 22 deg, find another ac tech. 22 deg evap means its either too low on Freon, refrigerant filter drier is stopped up, a blockage in the refrigerant lines, too little air flow across evap coil or it could be that the evap and cond are sized wrong. The evap temp has to be above 32 deg. If it has Freon in it, you can use soap bubbles to check for leaks at the solder joints. Turn the unit off first for pressures to equalize. Let me know. kstfas
Oct 22, 2006 | GE AJCQ08ACB Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
