Question about Sony Cyber-shot DSC-W130 Digital Camera
Plz i have sony dsc w130 and her proplem stop to take picture and in screen have message .... turn the power off and try again but i restart he repeat this message
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 14, 2010
Wheres reset button on sony cybershot dsc w130???
I'm glad to provide the information about the Camera. The Camera does not have a RESET button to press manually to reset it.
If you wish to reset the Camera, you can use the Initialize option from the Menu item to perform it if the Camera is allowing it.
Please perform a power resetting if the Camera is not turning ON or you're unable to access the Menu items. Please follow the below steps to perform a power resetting
  • Remove the battery from Camera.
  • Press and hold the Power button for more than 15 seconds.
  • Reinsert the battery
  • Turn ON the Camera.
Thanks for understanding. Please let me know if you require further assistance.
Sep 12, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
Yes.turn power off and on again on the screen
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
Jul 29, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
Turn the power off and on again
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
May 19, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
Problem with the Sony Cyber-shot DSC-W130 Digital Camera I am facing a problem in my SONY Cyber-Shot DSC-W130.When i m pressing the power button, then the lance continually up & down . After some...
it is just because there is something which is moved from within. . may be due to a fall or a hit. . so that thing is obstructing ur lens and the lens cant close. . so u will have to get it opened by an authorized service man and it will be done. . no other option. .
Mar 31, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
My sony DSC-W130 had an E:91:01.. how will i repair it?
Follow the procedures given below to have a perfect fix for your problem.
  • Press Menu button.
  • Toggle across from REC Mode to setup
  • Toggle down thrice from camera to setup 1
  • Toggle across into sub menu
  • Toggle down from four times to Initialize
  • Toggle across again to the sub-menu
  • Toggle up from cancel to OK
  • Press center button to accept the OK choice
  • Screen changes and so press okay again
  • It should restart the camera
  • Opening on the 'Clock Set' screen
Toggle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function. If it is still not working dont worry follow the steps again two or three more times, As this is related to a software error message and not a hardware malfunction. If it is working then don't forget to set your Clock.
Oct 19, 2010 | Sony Cyber-shot DSC-W130 Digital Camera
Hi, I have the Sony Cyber Shot DSC-W130 digital camera - whilst away on holiday a message appears when I turn on the camera "turn power off and on again". I have done so many times but it still comes up...
Hi. Yes. turn it on and go to the menu. find reset and reset the camera. this will return it to factory settings.
if you can't get into the menu or if the steps above do not solve the problem do what is called a hard reset. Remove the battery, leave it out for 5 minutes and then reinstall it. J.
Aug 07, 2010 | Sony Cyber-shot DSC-W100 Digital Camera
Sony dscw130 lens wont come out
This seems to happen when something (water, sand, dust) gets trapped in the lens mechanism. Has the camera been somewhere filthy before?
The recommended methods include taping on the bottom of the camera, rapping it on a table, and pressing hard on the lens. If the lens moves when you turn the camera on, try keeping your hand on it so that it's forced back into the camera body. A can of compressed air squirted around the lens is also a possible fix... but be super careful with that stuff, a good hard blow of breath might be safer.
I'm not recommending that you do crazy stuff to your camera, but if you're careful you may be able to get it working again without having to get it serviced.
Jul 06, 2009 | Sony Cyber-shot DSC-W130 Digital Camera
The lens on my Sony W130 goes in and out.
I will forward a link to a page where you can get more information about this issue.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=C91134
If the issue still persists then service of the Camera is recommended.
Jun 14, 2009 | Sony Cyber-shot DSC-W130 Digital Camera
My sony cybershot dsc-w130 doesn't seem to be charging.
DSC-W130 camera battery doesn't charge via USB.
It has individual battery charger which plugged in AC.
You can see battery charger in user manual.
Dec 12, 2008 | Sony Cyber-shot DSC-W130 Digital Camera
Sony Cyber-shot DSC-W130 Digital Camera Logo
93 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
