Question about Microsoft Xbox 360 Console
How to estimate fractions - Microsoft Xbox 360 Console
  • 219 Answers
Not quite a video game question but let me see if I can help.
We'll start off with simple ones and progress from there.
Half = 1/2 = .5
Say you have 22.5, this number will be 22 1/2, if you want this as just a fracton you will multiply the denominator to the whole number and then add the numerator to get the whole fraction; 45/2
Quarters = 1/4 & 3/4 = .25 & 75
Think of it this way: you can have 4 quarters that equal a dollar. Each quarter represents 1 out of 4 (1/4) parts of the dollar. To reduce, think about having a 50 cent piece; yes it is technically a quarter but it's also half, so 1/4 and 3/4 would be most appropriate.
When estimating fractions, think about its closest quarter.
Take .88 for example:
The 2 quarters .88 falls between are 3/4 (75 cents) and 4/4 (1 Dollar). This is where you think of place holders. You know 88 is 13 away from 75, and 12 away from 100 (1 Dollar); therefore you can say its pretty much inbetween them.
This is the important part that will help you:
You know now that there are 4 quarters to a dollar; when you need to meet between the quarters, you will use 8ths = half a quarter. So... between 0/4 and 1/4 there are 2 8ths: 1/8, 2/8 (2/8=1/4) continue up until you've reached the lower number your trying to get between, in this example its .75. There are 6 8ths before .75, so you are left with 2 left because 8/8 = 1. You dont want to go to 1 so in this instance you'll add another 8th. You're now up to 7/8.
This example works out very well because 7/8 is exactly .875, round this 5 up and you get .88 which is closely equal to 7/8.
The way to go about estimating from here is to keep cutting the denominator in half until you find something that's close to your given number. Remember your quarters and even knowing your 8ths will help you out in the long run.
Also, if anything is just a single decimal (i.e. in .9, .7) put this number over 10 and you have the fraction, just remember to reduce if both the top and bottom numbers are even numbers.
All I ask is for the very helpful rating since you've just asked me to remember things from school 15 years ago.
Respectfully,
Don
Posted on Sep 15, 2010
How to solve franctions
Multiplying Fractions:
  1. Make sure you're working with two fractions.
  2. Multiply numerator x numerator, then multiply denominator x denominator.
Dividing Fractions:
  2. Flip the second fraction upside down.
  3. Change the division sign into a multiplication sign.
  4. Multiply top x top and bottom x bottom.
Converting Mixed Numbers into Improper Fractions:
  1. Convert mixed numbers into improper fractions.
  2. Take the whole (non-fraction) number and multiply it by the denominator.
  3. Add that answer to the numerator.
  4. Put that amount over the original denominator and you will have an improper fraction.
Method for Adding and Subtracting Fractions:
  1. Find the lowest common denominator (bottom number). For both adding and subtracting fractions, you'll start with the same process.
  2. Multiply fractions to match the lowest common denominator.
  3. Add or subtract the two numerators (top number) but NOT the denominators.
Mar 07, 2017 | Homework
When I try and turn it on the green light appears for a fraction of a second but nothing appears. What should I do?
consider if not a expert here to have a technician look at the set and get an estimate.
Oct 31, 2012 | Televison & Video
I have a el-531x how do i cauculate fractions with it
Use the key marked [a b/c]
  • To enter a mixed fraction, enter integral part, press [a b/c], enter the numerator pf fraction part, press [a b/c], then enter the denominator of the fraction and press =.
  • To enter a fraction or an improper fraction, enter numerator, press [a b/c], then the denominator and =
  • If the displayed result is a mixed number , use [2nd][a b/c] to convert it in a fraction (improper fraction).
May 22, 2012 | Sharp EL-531VB Calculator
How to claculate the remainder of a fraction using CASIO fx-991ES?
Use the fraction conversion features of the calculator.
Near (above) the [S<>D] key that toggles display between fraction/radicals and decimals, there is a marking that reads [a b/c <=>d/c]. Accessed through the [SHIFT] key, this key converts from improper fractions [a b/c] to improper fractions [d/c].
Enter your fraction with the fraction key (the one below the CALC key) and press enter. If the numerator is less then the denominator (proper fraction) the remainder is just the numerator. If the numerator is greater than the denominator the display will show an improper fraction (d/c) or a mixed number [a b/c]. Here a is the integer part and b/c is the fraction part.
So, if you have [a b/c] type display the remainder is b.
If the result is displayed as an improper fraction, use [SHIFT][S<>D] to convert the improper fraction (d/c) to a b/c.
Dec 08, 2011 | Casio FX991ES Scientific Calculator
I CANT GET MYCALCULATOR TO DO FRACTIONS CAN YOU HOPE ME
To configure the calculator to do fractions, set the Input/Output mode to MathIO.
Press [SHIFT][MODE] to open (SetUp) then select [1:MathIO].
After you set it to MathIO, pressing the fraction key will display a fraction template where you can enter numerator and denominator as you would by hand (horizontal fraction bar). Also, the calculator will display results as fractions and radicals whenever possible.
To perform arithmetic operations on fractions use the regular operation keys (x, +, -, /). The calculator will perform the operations and display the results as fractions (whenever possible).
Aug 15, 2011 | Casio fx-300ES Calculator
I believe I have a convergence problem...red and green shadows on images and print. What does it take to correct...estimated cost? Is it something I could do myself?
You need to purchase the convergence repair kit.Are you handy?
It comes with instructions.
A TV repairman will charge about $300-$400.
The kit is a fraction of the cost
Jun 06, 2011 | Pioneer SD-P50A5-K 50" Rear Projection...
How to convert fractions into equivalent fractions
find the least common denominator between the original fraction into the new fraction.
example, 1/2 to 2/4 to 4/8 to 8/16.
May 19, 2010 | Cycling
Leaking proportioning valve, and master cylinder
a salvage yard part would be fine,and would be a fraction of the estimate given you by Pep Boys. that estimate is really high,btw. kia is a good vehicle when properly maintained. if finances are an issue,i recommend using sme Lucas products that are additives,they wont fix your problem peranetly but can definately hold you over a month or two.
May 01, 2010 | 2001 Kia Sephia
How do you change decimals to fractions on a casio
If you enter an improper fraction or a mixed fraction with the the [a b/c] key it will be displayed as a fraction. This result being displayed you can press the [F-D] key to convert the fraction to decimal. If you do nothing else and you press the [F-D] key again, the original fraction will be restored.
However, it seems that you cannot enter an arbitrary decimal number and convert it to a fraction. The [F-D] key seems to work one way : from a fraction to a decimal number. You will only recover a fraction if the original number was a fraction.
Jan 19, 2010 | Casio FX-9750GPlus Calculator
2003 Nissan Maxima. Passenger power window problem
Same problem on passenger door 92,000 miles. Dealer said he can reset the regulator inside the door by pressing button. I am looking for more information on this problem too. He estimates 1/2 hr (~$50) to do work.
Apr 22, 2009 | 2003 Nissan Maxima
Microsoft Xbox 360 Console Logo
194 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
