Need a PLT3400 ignitor is there a cross reference part to another manufacturer for this part?
Need installation diagram for driver belt for FC420
How can you cross reference a Toro belt? A:Use a V-belt conversion chart to cross-reference a Toro belt. The Belt Cross Reference Guide at CrossBelts.com links original manufacturer
Sep 28, 2016 | Garden
I need to find replacement parts for a Magic Chef propane furnace model EG6E80. How can I cross reference them with other brands?
good luck, what parts do u need, most of them can be re placed with other furnace name brands, like ignitor, blower motor, gas valve, pressure switch, ignitor board, transformer, ventor motor, they have replacement for all those parts, remember most companies use the same parts
Dec 16, 2015 | Heating & Cooling
How do i identify the 3rd party
I am guessing you are referring to actual manufacture of a hardware item in your pc. You would need the serial number of the device to cross reference it on google be the best way.
Sep 03, 2014 | Sony Computers & Internet
What size capacitor do i need for a 2.5 ton compressor
Each brand of unit uses different sized capacitors I need a model and serial number of your unit to actually cross reference that part. You could also call the manufacturer of you unit and find out.
Aug 26, 2014 | Heating & Cooling
NPS40 blower and ignitor always on - did i cross wires
i would suggest you call the manufacturer and ask for tech help asap
ask for them to send you the wiring diagram, it also should be on one of the covers or lid for the back of the unit. OR
http://homeappliance.manualsonline.com/manuals/mfg/napoleon_fireplaces/nps40_1.html?p=30
Jun 07, 2017 | Napoleon Auburn Pellet Stove Heater
Dell 3010cn is of course a Lexmark in crappy Dell shell. But which Lexmark printer is it exactly ?
The 3010CN is Manufactured by Dell, Inc. so no affiliation with Lexmark. I know this because 1, I am in the printer service business and I have a cross reference for just about every printer made. The 3010CN has no cross reference therefor it is Made by Dell. Second the CNET review of this printer states that the Manufacturer is Dell.
Aug 25, 2010 | Dell 3010cn Laser Printer
How do I access a spark ignitor on a Viking gas
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by a 'tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and would cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range. Of course you need to ensure it is the correct one for your stove. The ignitor you remove should have a manufacturer part number on it. No calibration required on mine - a sealed electronic unit. Probably about 10 wires that need to be R&R'ed - they are on with reuseable fasteners.
Jan 18, 2010 | Stoves 600SiDOm Gas Kitchen Range
Just wondering
You can cross the wires without any problems. As long as the ignitor makes a complete circuit it does not matter.
Mar 05, 2009 | Dayton Electric Heater
Heating & Cooling Logo
177 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
