Question about SWR WorkingPro 15 200 Watt 1x15" Bass Combo Amp
My swr workiongpro 15 suddenly has a very noticable hiss even when the amp is muted, and when I play the high end is more prominent than it was before.
  • tomgunvordah Sep 15, 2010
    i appreciate the input. let me clarify a few things i maybe failed to mention before.
    All of my EQ settings have not changed in the slightest. The hiss is VERY noticable.
    it happens when i play, but also when the amp is muted, the pickups on my bass are off. there is not signal being sent to the amp.
    A week ago when the amp was muted or my pickups on my bass were off there was no sound coming from the amp. now there is lots. It only sat in my bassment doing nothing in that time
  • SWR Master
  • 5,603 Answers
If you are having the treble/high turned up there will be hiss. This is due to the statistical noise in electronics, including semiconductors. It is a matter of degree. The hiss should be 30 Db below your program level or so.
It is very common for one to change settings and suddenly start to notice hiss or hum at certain settings.
IF YOU CAN, go to a music store and COMPARE the amp to yours at the same setting with NOTHING plugged in. (cables and guitars can generate hiss or other noise themselves).
There is very little in your amp that would have changed to suddenly start generating hiss, so FIRST compare. This will minimize the chance of spending money at a shop to be told it is normal.
Posted on Sep 14, 2010
My Roland FP8 plays very quietly through its own speakers, through an external amp & speaker and through the earphones. There is a hissing/crackling/static sound too from the speakers. Anyone
A number if things can be wrong with it, from the audil preamp to the the audio amplifier. Even as simple as a bad volume control. Does the actual noise change patterns when you move the volume?
Jan 03, 2015 | Roland Music
I turn my fx off but can still here it and the od sound is lower than the fdx button when i push it in to turn it on
2 things 1: there is no off button for the built in digital effects, you just turn the level down to minimum, the fdx button you speak of is actually fdd (frequency dependant damping) this is supposed to mimic how a tube amp sounds
2: when you press the od switch the amp goes into hi gain mode and will hiss with no input, the point is if you plug a guitar in and play it the volume of the guitar is way above the hiss and you don't hear it
so in conclusion having bought and sold many mg series amplifiers the on you have is perfectly ok
Mar 10, 2012 | Marshall Mg15dfx 15-Watt Combo Guitar...
I've had the Tonebone Plexitube since January of this year, but have only played through it a couple of times. I recently took it out to really experiment with it and get to know the pedal. Right away...
It sounds like somehow the pre-gain is very high while the volume or post-gain is very low. Try turning the volume high on the effects unit and the gain low, and don't have the amp volume too low either.
May 18, 2011 | Radial Tonebone Plexitube Effects Guitar
I have a Peavey 8600 amplifier. It sounds great but when only operating vocals, in order to get the highs of your voice just right, the speakers put off a large amount of white noise. While singing, you...
There is not enough info here to provide a complete answer, but let me give you some background:
There will always be some hiss. This is due to general amplification where a small amount of noise is amplified along with the general signal. In most cases, the signal is strong enough to overpower any noise that is present (vocals in your example). This noise should not be that noticable in normal cases. If there is an automatic gain control in the line, this could account for it as with "silent" times, the gain will automatically be increased potentially to the degree where the noise is noticable.
Barring that scenerio, if the input signal is too low, the overall gain necessary to produce reasonable volume at the speakers will also be such that the noise is noticable. In order to track this down, please provide details about the current setup including:
1) Microphone make and model being used
2) Input being used on the mixer
3) Gain level being used for the mic channel
4) Gain level being used at the master level.
Dan
Jan 07, 2011 | Peavey Xr 8600 8 Channel Powered Mixer
I have an SWR workingpro 2x10c combo solid state amp. When running a signal into the standard input with all pots set at 12 o clock, the signal sounds very distorted. I have tried a basic troubleshoot,...
You haven't told us what "signal" you ran in... Make sure ALL interconnected equipment is powered from the same receptacle. All audio lines should use balanced interconnects where possible using XLR or TRS cables. Cross connect another amps preamp into the effect loop input to check the power amp portion.
Dec 15, 2010 | SWR WorkingPro 15 Amp Combo Bass
What kind of el34 for my jtm610 marshall to obtain more bite and SUSTAIN.I play a gibson Les Paul Standard. DAVY
It is UNLIKELY you will notice any difference trying different brands of tubes.
The sound will be most affected by the audio output transformer and especially speakers. The transformers in many of these have too little iron in them resulting in saturation. You can spend a lot of money on new tubes and any apparent change you notice will probably be psychological rather than actual.
The design of vacuum tube amps will often result in a softer high ends... If you want more than that, go to the solid state amps. Sustain is affected by the overall gain which is mostly in the preamp and reverb functions AND a large part on the quality of strings on your guitar...
May 31, 2010 | Marshall 15 Watt Guitar Amp
My new mg50fx has a ton of hiss when i turn it on. anything i can do?
Make sure the master volume is turned up and the inout gain is down some.
All of the electronic devices suffer from the statistical noise within the amplifying components. Keeping the inour gain down some tends to limit the gain where the hiss is most sensitive, that is the high gain in the "front end" or preamp section.
A "ton" is not a MEANINGFUL measure of the loudness of the hiss.
A meaningful measurement would be the Db relative to the normal program material.
Test with no devices plugged into it as the preamps in guitars can create hiss too. The hiss should be barely perceptable at 5 feet from the amp.
May 04, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
How can i get rid of the hiss and popping from my amp
A relatively quiet "hiss" is normal and is due to the statistical properties in electronics. If the level is noticeable during normal program play, then it needs to be dealt with.
First thing is to verify the noise is still there with NOTHING plugged into the input jacks. Many times the noise comes from bad cables and guitars that have noisy on-board electronics, so we must check this out by unplugging all inputs.
MAKE SURE any other devices connected to this that require connections to the power input ALL are plugged into the same receptacle.
Nov 25, 2009 | Marshall MG100HDFX 100-Watt Amplifier Head
SWR WorkingPro 15 200 Watt 1x15" Bass Combo Amp Logo
176 people viewed this question
Top SWR Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a SWR Music Expert? Answer questions, earn points and help others
