Question about Western Digital 500GB My Book Pro-External 500 GB Hard Drive
My external drive stopped working - it can only read sometimes and sometimes it can not access it at all. I format it and now I can not access it anymore
    Guru:
  • 1,082 Answers
If it is under warranty, get it replaced otherwise time to buy another one.
Warranty is 1-5 years depending on the model number. Check: http://support.wdc.com/warranty/policy.asp
about 1/3 the way down.
If this was helpful, I'd appreciate 4 thumbs.
Posted on Sep 14, 2010
Can't read data on WD external my book hard drive
It seems that your WD hard drive is corrupted so
you are unable to access the stored files. But there is no need to worry since
it is very easy to recover data from corrupted WD partition by using Western digital partition recovery
software. Couple of days ago, even I was stuck under similar problem I tried
this software which really helped me to retrieve all my lost data.
All the best,
Linda William
Jan 01, 2013 | Western Digital My Book Essential 1TB...
I brought a 250gb hdd for the xbox 360. The xbox 360 says that it is a unformatted storage device, the only thing i can do is formatted the hdd. but nothing happend I have formatted the thing 5 times....
Trying to format a large external USB or Firewire hard drive to the FAT32 file system? Can't do it? Only see an option for formatting the drive using the NTFS file format? Well if you answered yes any of those questions, then you're at the right place.
I was recently trying to format my 1 TB MyBook external hard drive in Windows XP to FAT32 instead of the overly forced-upon NTFS format. Why? Well because I needed to connect it to a NAS device and the NTFS permissions were causing the NAS not to be able to access the drive. Simple solution is to use FAT32, no security, no problems. Though it's sometimes useful to format a USB drive in NTFS format.
Also, formatting a drive in FAT or FAT32 will allow it to be read by other operating systems, such as Mac, Linux, and older versions of Windows such as Windows 98.
Unfortunately, Windows XP and Windows Server 2003 will only format a removable drive in FAT32 if it's less than 32GB! Hmmm...that pretty much cuts out ALL modern external hard drives!
However, Windows can format a drive that is larger than 32GB in FAT32, but you have to use the DOS command prompt. However, if you have a drive that is 1TB or larger, you may still get an error saying "The volume is too big for FAT32".
In that case, you can use a free program called SwissKnife that will allow you to format an external hard drive that is up to 2TB in size. Let's go through both methods. In case you are having problems getting your external hard drive to show up in Windows, read my article on how to change the drive letter for an external drive in Windows.
Format external drive in FAT32 using DOSOpen a command window by going to Start, then Run and typing in CMD.
Now type in the following command at the prompt:
format /FS:FAT32 X:
Replace the letter X with the letter of your external hard drive in Windows. Windows will go ahead and begin formatting the drive in FAT32!
Format external hard drive in FAT32 using SwissKnifeSwissKnife is a nifty little program that is completely free and that you can use to format many types of external drives such as USB, Firewire, PCMIA, SATA and SCSI. You can also use it to create partitions on an external hard drive and it formats faster than Windows.
So next time you want to format a hard drive in FAT32 and Windows only gives you an option for NTFS, make sure to follow one of the two method mentioned above. Enjoy!
Mar 02, 2011 | Microsoft 20GB Hard Drive for Xbox 360
Unable to access files
To access the files off the hard drive another way - remove the hard drive from the case and connect it to an USB hard drive adapter and then plug it into a working computer's USB port. If the computer see the hard drive as an external hard drive/storage device and you can open the folders and files then backup your data. This also indicated the hard drive is OK and the Western Digital case/electronics is faulty.
To use this as an external USB hard drive, put the hard drive in an USB adapter case.
Sep 09, 2010 | Western Digital 320GB MyBook External USB...
I am having an issue with my WD5000h1u-00 500 GB external drive
Read this instructions my friend
It is possible to use a Western Digital external hard drive on botha PC and a Mac. However, there are some things to keep in mind if youwant to do this. Moreover, Western Digital does not recommend doing it.
  • For both PC and Mac to be able to read the drive, it must beformatted in the FAT32 file format. In order to format to FAT32 on aMac you may need to contact Apple for support. We do have a FAT32Formatting utility for Windows that reformats WD external hard drivesto their full size, but in only one partition. The FAT32 formattingutility can be downloaded from our Downloads Library. You will find it on your WD drive's Downloads page.
  • Critical: Do not attempt toconnect any external drive to multiple computers, simultaneously; letalone to both a Mac and PC. This could quickly damage the drive'spartition and corrupt the data on the drive.
  • Sometimes, PC's won't read Mac FAT32 formatted drives, andMac's won't read PC FAT32 formatted drives. You may have to re-formatthe drive trying both the PC and Mac until you get a format that works.
  • Most WD external hard drives come pre-formatted with one large FAT32 partition, which is accessible by Windows 2000, XP, and Vista, and Mac OS 10.4 and 10.5.
  • Windows 2000, XP and Vista can only create FAT32 partitions that are 32 GB's or smaller.
  • Mac 10.4 and 10.5 can create FAT32 partitions the full size of the drive.
  • There is a 4 GB file size limit on the FAT32 file format. Thisis a file system limitation that affects both Mac's and PC's, and thereis no way around it.
  • Finally, you need to understand that if you are using the samedrive back and forth between a Mac and PC, there is always the chanceof files being corrupted. Mac's and PC's are different platforms, andtheir file systems function differently. Please keep backups of allyour files before you start sharing between Mac and PC computers.
Note: Once the data iscorrupted, that drive may no longer be recognized by one or both of thecomputers. Or, the drive may be recognized, and the data may bevisible, but you won't be able to open any files. At that point, youwill need to re-partition and reformat the drive in order for it to berestored and usable by both computers again. In the process, you willlose all the data on the drive. For that reason, you need to keep abackup of the files you are transferring between computers.At the bottom of the page, you will find links for partitioning and formatting in Windows XP and Vista, and Mac 10.4 and 10.5.
Jan 12, 2010 | Western Digital My Book Premium ES...
Drive is detected by computer but when tried to access it, computer freezes up and cannot access external hard drive
First attempt to format it. If that doesn't works, restart your computer and acces the BIOS SETUP menu, and check if the drive is well read by the BIOS. If that doesn't work, then you may have to call the warranty.
Nov 20, 2009 | Western Digital External USB 2.0 80 GB...
My External USB 250hard drive shows error Drive is not accessible
You most likely need to delete the partition on your external hard drive, then create a new one and format it again. You will lose the data on your external hard drive.
1. Go to the Control Panel, click on Administrative Tools, click on Computer Management, then Disk Management. (You will need Administrators rights to carry out the following tasks)
2. On the lower Right Panel select the External drive, this will be displayed as Disk 1, Right click on this drive (MAKE SURE YOU DON"T SELECT THE C: DRIVE which will be displayed as Disk 0)
and then Delete the partition.
3. This drive should then be Unallocated, Right Click on this drive and create a New Partition.
4. Then select Primary partition.
5. Check that the maxium disk size matches close to 240000(MB) you about 10+MB in the formating process
6. Click Assign the following drive letter (let the computer select this.
7. Chick Format the partition with the following settings
File System = NTFS
Allocatin unir size = Default
Volume label = "name of your choice eg. BACHUP DATA"
DON'T TICK Perform a quick format & Enable file & folder compression
8. Click Finish
Nov 27, 2008 | Western Digital 250GB MyBook External USB...
I o magic external dvd burner wont work
most likey it is incompatlable with vista ? did you check the specks lala linda
Aug 14, 2008 | Computers & Internet
No Write permission when attaching Simpletech external drive to Mac OS 10
simple just format it for PC first then it should work for both
if you format it for MAC first it will not work on the PC
simple
PC are horrible for accessing files
mac's are more user friendly
Jul 02, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 1TB external HD
Is it formatted and partitioned?
right click on MyComputer>click manage> click disk management > see if it shows up on the bottom right of the window that opens up. If it does> right click > click format. Then you should be able to drag and drop it.
Also, did it come with software. It may require that the software be installed.
Please remember to rate Techs who assist you for free :)
Good luck, Joe
May 31, 2008 | SimpleTech 1TB External USB 2.0 Hard Drive...
Open Questions:
See all Western Digital 500GB My Book Pro-External 500 GB Questions
Western Digital 500GB My Book Pro-External 500 GB Hard Drive Logo
47 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
