Question about Samsung HCN4727W 47" Rear Projection Television
Samsung HCN4727W When I hit the power button the red light flashes several times but it will not turn on......I hear a click like the power wants to come on but no chime and no picture on the screen . What can be the problem?
  • 1 more comment
  • jdtimi May 19, 2008
    Are the STK chips soldiered to the board or socketed? How do I locate the board?
  • BOB BRUNSWICK Jun 10, 2008
    i HAVE THE SAME PROBLEM, BUT HOW DO I GO ABOUT FIXING THIS
  • jdtimi Jul 11, 2008
    Had the same behavior on tv. Replaced Convergence board. TV worked for
    a few hours then reverted to old behavior. Put old Convergence board
    back in, now tv is working again, for a couple days so far??? Worried
    initial problem will return. Any ideas?
OK, finally found a 'replacement' part number since the original board isn't available. Replaced with BP95-00142P. Obtained from PartStore.com. Plugged in new part. Worked for an evening. Went to turn on next day and back to original problem! There must be a part feeding the convergence amp that is flakey and blowing the amp! Any more ideas?? Otherwise, just threw away $100 trying the easy fix. :^(
Posted on Jul 10, 2008
    Was running TV this morning to exercise it. While I wasn't looking, it
    shut itself off. Power button and remote had no response. Unplugged
    from wall, replugged. TV back up and working normally. There must be
    something overheating or going out.
WHAT IS THE PROCEDURE FOR REPAIRING THE CONVERGENCE BOARD?
Posted on Jun 10, 2008
  • 1 more comment
  • BOB BRUNSWICK Jun 12, 2008
    Do you have any pictures of the STK chip and their location?
    fOUND THE BOARD, LOOKS EASY TO REPLACE AND COST IS NOT BAD:$77.00! WILL GIVE THIS A TRY, BUT IF IT DOESN'T WORK WILL MOST SUPPLIERS ACCEPT RETURN?
  • BOB BRUNSWICK Jun 29, 2008
    I've removed and replaced the convergence board with the STK's and the same problem still persists, no sound or picture, just the red flashing light.
    I've also removed and inspected both side the boards and found no evidence of any leakage.
Convergence board shot. Cheap to fix yourself, board has two STK chips on it and is easy to get to.
Posted on May 17, 2008
I have a 56' that wont show picture
Power board is bad.. I had the same issue.
Apr 13, 2010 | Samsung HL-S5679W 56" HDTV
My samsung hcn4727w blinks red when i turn it on
either the lamp, ballast or power supply need to be replaced.
Nov 11, 2009 | Samsung HCN4727W 47" Rear Projection...
My tv when i turn it on i get a flashing red light
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Samsung HCN4727W 47" Rear Projection...
Samsung HCN4727W 47 in.
I mean that your unit is need of resolder or reheating of the solder joint of the parts.Supply section,horizontal section,vertical section and microprocessor IC.Improper distribution of current flow ,due to a loose contact or crack solder, that's your tv automatically signalling by flashing,that is the main cause of flashing . Find a tv technician to do works for you,,in order to avoid high voltage shock....
Jun 29, 2008 | Samsung HCN4727W 47" Rear Projection...
Samsung
have the power supply checked
Jun 16, 2008 | Samsung HCN4727W 47" Rear Projection...
No Picture
see if STK392-110 or similar are good. 2 big chip with cooler
Jan 11, 2008 | Samsung HCN4727W 47" Rear Projection...
Won't turn on...
It's possible that the convergence IC's may be bad in this set along with a few resistors. A TV repair shop should be able to fix the set for you.
Dec 19, 2006 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4727W 47" Rear Projection Television Logo
219 people viewed this question
cce772000
Level 1 Expert
