Question about Nikon Cameras
Lens error shows in view finder and the lens won't open. How to clean the sensor?
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 14, 2010
My view finder on my sony dslr A100 wont show what i am looking at though the view finder
The A100 uses sensors near where you place your eye. Make sure the rubber eye cup is clean, and does not block these sensors.
as a test put your finger on them while holding camera away from face ( located just below eye cup) then you will see the view finder light up. If not problem is the sensors.
Jul 29, 2014 | Sony Alpha DSLR-A100 Digital Camera
Can't see through the view finder. Camera is on and Lens is automatically attempting to focus. I cannot see through the view finder and the camera will not take the shot.
Take off lens. Is mirror up or down? If mirror is stuck up motor or shutter failure. Is the shutter open (can you see the image sensor?). Was the camera impacted?
Oct 18, 2013 | Nikon D70s Digital Camera
When the camera is in take a picture mode, the view finder is black. When viewing pictures pictures previously taken, they are show on the view finder. Why is it black in this mode?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 06, 2010 | Canon PowerShot S2 IS Digital Camera
My lcd and view finder are unable to show subject
The problem you are having is called a "stuck iris" Inside the lens are two thin plastic sheets that slide over one another that limit the amount of light that comes into the lens. In some Sony camcorders, the motor or "actuator" that drives the iris, or moves the two sheets which are the iris opened and closed. The actuators sometimes leak oil onto the plastic sheets causing them to stick, so the light coming into the lens is stuck at one level. Some technicians will recommend lens replacement (expensive) but many times the iris assembly can be removed from the lens and cleaned. Try to find a service shop that will clean the iris rather than replacing the lens.
Nov 11, 2008 | Sony Handycam CCD-TRV98 Camcorder
Dust inside my d200
The view finder and focusing screen are separate from the CCD sensor. The mirror reflects the image to the view finder until you take a picture. Then the mirror goes up, the shutter opens to expose the CCD to capture the image.
If you have a lot of dust, you should look into a cleaning kit, or have it professionally cleaned. This will show up on your images as white and/or black specks.
Jun 29, 2008 | Nikon D200 Body Only Digital Camera
ERROR 99
Error 99 is a generic error in that the camera does not know what the exact error is. The usual fix for this error is ......
Turn the camera off and remove the battery.
Remove the lens and clean the electrical contacts on the rear of the lens with a soft dry cloth.
Refit the lens and the battery and switch back on. Hopefully all will be well again.
Jun 28, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Problem with Canon EOS D60 Digital Camera
You need to clean the gold contacts with a soft pencil eraser. Remove the lens, and clean the contacts on it. Then hold the camera so the lens opening is pointing down and clean the contacts on the camera. Ensure no debris gets into the camera body and none is left behind on the lens.
Put it all back together and you should be good to go.
Apr 04, 2008 | Canon PowerShot EOS D60 Digital Camera
Digital Canon Rebel DS6041 - Auto focus does not working
allow to dry for an extended period. leave lens off, put in dust free area.
it may 'come back' after a few days of being open.
moisture can cause malfunctions. is sensor clean a liquid? or air?
air can be driven by a propellant which can cause problems.
try removing battery if it does not come back, or maybe before.
good luck, otherwise, time for service'
mark
Dec 15, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Lens cover not open and blank screen
the problem of your camera is the ccd image sensor...better go to the sony service center for replacing the image sensor..i know it is free for replacing that sensor cause that is one of the model that sony recall produc and the cover not open error message is a poor contact of the lens cover switch...
Sep 09, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Cameras Logo
12 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
