Question about Sony KV-32FS13 TV
TV Zoom mode
After installing a new cable box, the TV is now in zoom mode. Remote doesn't seem to work. Any suggestions?
  • 8,596 Answers
Change the batteries on the remote, point the remote at the Sony, and hold in the power button for 5-7 seconds. Then depress and re-press the power button - see if you can get the tv remote to respond again.
Then, always try the quick reset:
How to perform a power reset on a Sony® television.
  1. Turn off the television. IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Posted on May 16, 2008
I have a sony bravi xbr ;the picture is sooo big i can't read the subtitles . i tried ti fix it ( from the instruction manual ) but nothing work . thank you !
Hi: Check you screens format button to change screen sizes, this button may also be labeled Aspect. Seems you are in ZOOM Mode, these buttons can also be found on cable boxes remote as well try pushing them to see if screen size change. If this does'nt help then do this with the TV in off posistion. Press the Display key on your remote, Then the Five key, then the Vol up key, then press power key. This will turn set on in service mode, you will see service options do not do anything but press the number 8 on remote and hit enter. This will rest tv to factory settings. All video setups and parameters you have set in user menu will result back to factory and will need to be redone. TV should shut down on its own and come back on on channel 3.
Dec 10, 2011 | Sony BRAVIA KDL-52XBR3 Television
I have a HD Visio and I lost my TV remote, my TV is stuck on Zoom Out and I cannot play my new Nintendo WII game becasue the TV picture is to large, I went into menu and could not see anything to zoom,...
Sorry u can't fix this zoomming mode problems without the tv original remote.This tv zoomming mode function it is have it only on the tv original remote function only no where else.Try website like Remotes.com to buy the tv original remote to use.
Sep 22, 2011 | Vizio m420nv 42 in. LCD HDTV
I just bought a used Loewe TV model number ACO938PB. I can;t get the picture to fill the screen. I've changed the settings inside the TV and the 6X9 format works best, but there are still bars of black...
I had a similar problem, and I fixed it with my new Sony flat screen by going into the zoom mode and then menu on the tv remote. You can then access settings such as horizontal and vertical and change them so that your screen can adjust. The only way you can access those settings is in zoom mode.
May 24, 2011 | Loewe Televison & Video
My mitsubishi vs60607 the picture is too big for the actual screen. it's as if i set it to zoom mode but it does not have a zoom mode
Hi:
If you are using a cable box connected to the television for viewing channels, the box has a screen format button on it make sure its is not in zoom mode also. Check the box's remote for a button labeled format or Aspect or screeen.
May 17, 2011 | Mitsubishi VS-60607 TV
Lost my remote and tv is hung on zoom...anyway i can get off zoom without the remote?
Yes there is a way around zooming in and out without the television remote control. The cable box/satellite tv receiver also has an option to zoom in and out on it. BUT it usually only works when you have the hd box/receiver AND the television has to be on the right input in order to receive hd (component input or hdmi input). PLUS the cable box/satellite receiver should be set on the 1080i resolution (or 720p depending upon the resolution the television can accept). Then you can find the button on the remote that says #hd zoom (yes the # sign is on the button) or the button may be format or aspect.
Feb 08, 2011 | Philips 32PFL3504D 32 in. LCD TV
LCD tv zoomed in. can't un-zoom it. tried restoring to factory settings, nothing. tried settings couldn't find anything that led me to undo this. just bought this tv. the picture is killer. untill it...
Are you connected to a cable box with its own remote control, if so, some systems have a zoom control on the cable box remote. Check to see if it is setup to "Movie" mode or similar.
Dec 27, 2009 | Televison & Video
Wide screen mode won't go back to "normal".
Was exactly what you said. The cable box settings were in wide mode. Couldn't figure it out at all. Funny thing was too.. on my cable box remote, the button under the #9 button is the # button.. it doesn't say zoom at all.. but it totally controls the zoom.
So thanks for that.. AND thanks for saying "under the #9 on the cable remote" instead of just saying .. the zoom button.
Thanks again!!!
Dec 25, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Over size picture jvc tv model tv20n33
Hello: THis model does not come up any where,recheck model. Also if using cable box and television has HD capabality then you may be in Zoom mode. Check you remote for a format button sound like like ur in zoom mode.
Oct 22, 2009 | JVC C-13911 13" TV
Can't get out of the hd zoom mode
Your problem may be an adjustment. Try your tv's remote zoom, but it's prob your cable/sat remote. Look at bottom right side of recon, hand remote. If not try resetting tv and or box.
Apr 02, 2008 | Televison & Video
Sharp TV - 32LW92H - Zoomed in
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Nov 05, 2007 | Sharp 32F640 32" TV
Sony KV-32FS13 TV Logo
128 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
