Question about HP Pavilion dv4000 Notebook
How do I replace the LCD CCFL BACKLIGHT LAMP in my HP Pavilion 4340?
pontelemon
  • 531 Answers
SOURCE: HP Pavilion dv1227US notebook PC Backlight Power Inverter
Take 2 bottom screws from LCD bezel. Pull front bezel off gently. Small board in the middle right under the LCD.
Enjoy.
Posted on Mar 19, 2009
  • 8 Answers
SOURCE: dv4000 hp pavilion dark screen
Have you replace the lcd inverter? if it works on external monitor, given the screen is new, then it leaves the inverter. Usually in the case of dark screen, it should be the first thing to check/replace.
Posted on Apr 08, 2009
  • 130 Answers
SOURCE: I dont know how to replace my HP Pavilion DV100t
Usually you need to take of the panel above the keyboard, it often snaps off, though sometimes there are screws on the bottom of the computer and you have to take off the keyboard too. then you can unscrew the hinges. Depending on what you have to replace you might need to take off the faceplate for the screen by pulling off the little rubber things and unscrewing the screws hidden beneath. If you need any more help just post back.
Posted on Jun 12, 2009
  • 253 Answers
SOURCE: I have an HP pavilion dv1000 and the backlight
reset ur settings power saving mode....
Posted on Jun 24, 2009
Geekman
  • 32281 Answers
SOURCE: no backlight on hp pavilion dv8000 17" monitor
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Posted on May 11, 2012
Laptop powers up but no video
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Dec 08, 2009 | HP Pavilion dv5000t Notebook
Need a new screen how much will it cost
This is a web site were you can buy the screen.
http://www.blisscomputers.net/hp-pavilion-g60-235dx-laptop-lcd-screen-16-wxga-glossy.aspx
Price:
$79.99 Make: HP Manufacturer Part No: G60-235DX Screen Size: 16 Inches Pixels: 1366 x 768
Good Luck!
Dec 03, 2009 | HP G60-235DX Notebook
HP compack laptop diplay brocken
If the LCD screen is cracked then the LCD screen needs to be replaced.
If the screen has a backlight problem then the fault could be a faulty inverter that supplies high voltage to the CCFL lamp, or the CCFL lamp is faulty. These items are cheaper to replace than the whole LCD screen.
For service, parts and DIY info check out LCD Parts WEB site - click in this link to their WEB site :-
www.lcdparts.net
Oct 27, 2009 | HP Pavilion dv6000z Notebook
NC2400 screen flicker
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out, this is the most likely case.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site :-
www.lcdparts.net
Sep 29, 2009 | HP Pavilion zd8000 Notebook
Monitor flickers goes out then comes back
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 10, 2009 | HP Pavilion dv5-1125nr Notebook
Display problem
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 10, 2009 | HP Hewlett Packard Pavilion dv9750us PC...
Black screen
Jun 10, 2009 | HP Pavilion dv2000t Notebook
Hp dv2210us power goes on but just black screen, not booting up
You could have a defective screen - a defective inverter or a CCFL lamp, follow this to determine the fault.
To determine if you have a LCD screen problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Apr 19, 2009 | HP Pavilion dv2210 Notebook
My laptop screen is flickering
You most likely have a defective inverter that supplies high voltage to CCFL backlight. It is unlikely a faulty CCFL lamp because your laptop is approx 1yr. old.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the inverter or backlight.
Apr 08, 2009 | Microsoft HP Pavilion DV6276US Notebook PC
HP Pavilion dv9500 lcd screen issues. Turns pink after warms up.
Defective CCFL backlight may has the following symptom:
Mar 29, 2009 | HP Computers & Internet
HP Pavilion dv4000 Notebook Logo
262 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
