Question about Intel S845WD1-E Motherboard
I'm trying to help an elderly friend. Recently when powering on, there are two short "rings", not beeps, then the system powers on and the monitor shows the desktop. However, no mouse or keyboard is recognized and usable: wireless, usb or plug-in. (Therefore, cannot enter Safe Mode.) Intel S845WD1-E Motherboard The computer is an older model which had been working fine with Linux 8.04 LTS for about 9 months.
  • 231 Answers
SOURCE: Motherboard Installation Problem - Intel DP35DP
Hi, the best solution I see is to log on to the makers website locate the download and support for your board and download the manual [usualy in PDF] and also a copy of your boards drivers.
I had to do exactly this with an Acer board with USB mouse & keboard sockets.
Regards mistyman
Posted on Oct 13, 2007
faheemsafdar
  • 68 Answers
SOURCE: Problem with video drivers And LAN card adapter
Well.... if you want to buy the diver CD. Just ask them " Intel D845GVSR Driver cd" if you want to download from internet then goto
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=1065&lang=eng
Posted on Mar 31, 2008
No solution, I'm afraid but I've had what could be a similar problem. Board DOA, apart from the small LED built in, and a flashing power LED (front of case), nothing. No spin ups, no fans (powered from a separate board). Have you yet worked out what caused your problem? I have a new PSU, I've swapped out the video card. My best guess, is something to do with the board arriving in a power-off or standby state that does not recognise my power supply (Tegan 500W).
Posted on May 02, 2008
SOURCE: 2 back usb port not working
all of my usb ports are not working
Posted on Nov 27, 2008
marketex
  • 371 Answers
SOURCE: Hardware Monitor not working- Intel D945GNT
Not sure what chip you are using, but your problem is one which I have had and solved by the most extreme heat dissipation methods possible...I even went to the extremity of packaging dry ice in Plastic and using an external fan to literally produce arctic temperatures inside the case.
It did attenuate or reduce the heating problem and the Intel hardware monitors took note of that, but I also notice some degradation in the extent of the graphic presentation of the on screen diagnostic display of temperature, fan speeds, etc.
So, with your new problem, since you apparently responded to the three long beeps by adding a keyboard or other peripheral, and solved it, a full statement of that problem with all specs would be appropriate, unless you can no longer read the display.
Posted on Mar 28, 2009
PC Freezes During Boot and at the BIOS Screen, EVGA P55 Classified 200
Beep Code Descriptions
1 short beep Normal POST - system is ok
2 short beeps POST Error - error code shown on screen
No beep Power supply or system board problem
Continuous beep Power supply, system board, or keyboard problem
Repeating short beeps Power supply or system board problem
1 long, 1 short beep System board problem
1 long, 2 short beeps Display adapter problem (MDA, CGA)
1 long, 3 short beeps Enhanced Graphics Adapter (EGA)
3 long beeps 3270 keyboard card
Aug 30, 2012 | Evga P55 Classified 200 (160LFE659KR)...
AMD sempron power supply
I would venture that "shows winfast on monitor" indicates the type of Video Card that your PC is using. Thereafter it should go to POST showing the motherboard, BIOS, memory count and others.
Since as you posted, after Winfast nothing follows, I can only suspect that you have a motherboard problem or at least a BIOS corruption.
Please post back the brand and model of your computer or at least what motherboard.
Good luck and kind regards.
Thank you for using FixYa.
Mar 16, 2008 | Computers & Internet
My pc is booting but no display
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
best of luck!
Mar 13, 2012 | Gigabyte 7VM333M-RZ (GA-7VM333M-RZ)...
No signal on monitor, vga tested and ok
Mar 11, 2012 | Computers & Internet
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
My monitor worked great for the period of 5 years or so...then one day it doesn't want to come on, the power light would flicker...anyway I removed the panel and looked for popped capacitors and I can't...
Bad caps can look normal but it they can have high ESR, but you should take some voltage readings first, it should have 5vdc and 12~16vdc when the monitor is plugged in but not turn on.
Post pictures of the caps also, many people told me the caps look OK until I see the pictures and they turn out to be bad. You need cap meter taht can read capacitance and ESR.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 07, 2011 | KDS K717s 17" LCD Monitor
My bios speaker will beep on startup but nothing more. What avenue should I approach to get past this part of startup?
First you need to know which BIOS you have and how many beeps it is producing... these beeps are the POST - Power On Self Test. They tell us if there are problems such as missing keyboard, video card not working, memory faults etc...
Then you need to go to the appropriate BIOS site and see what the number of beeps mean.
If it is a single beep - it means all is well...
As you are not getting anything more you should check to see if the Hard Drive (HD) light flashes - if so - the HD is probably operating ok and loading your system but there is either a problem with your monitor or video card... borrow another monitor and see if that helps...
But it all depends on the number of beeps you get and what kind - long and short beeps (like morse code).
If this helped you at all please vote!
Oct 06, 2009 | Asrock M266A Motherboard
Intel d845,one long 2 short beeps video problems
hi im josh in cebu phils.may i help you? friend try to use this solutions of mine surely it will help you.
Your PC uses beeps to communicate with you when something is wrong with the video setup. Check the settings on your video card to make sure that they're correct for your system. Also check any switches on the motherboard to make sure that they're set up correctly for your type of video card. (You should consult your system's instruction manual for details on this procedure.) Check to make sure that your video card is seated properly in its slot; you may even want to try inserting the card in another slot. If none of these suggestions works, try a new video card, or have your system examined by a professional.
In a pre-Windows 98, system, if you have two video cards installed at the same time, they can sometimes interfere with each other and cause neither to work properly. Try removing one of the cards; if this results in the remaining card working, you need to reconfigure one or both of the cards to better work together. (With Windows 98 and later you can install two video cards to run multiple monitors simultaneously
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} THE COMPUTERS SEEMS TO BE WORKING, BUT THE SCREEN IS BLANK.
- Check the monitor if turned on.
- Check all the LED power on the monitor, if it has one.
- Adjust brightness and contrast controls all the way to the maximum.
- Check the video cable from the monitor to the computer to be sure if it is properly connected.
- Check the power cable. If it is connected properly at both ends.
- Try different monitor on your computer. If it does not work, the display card is likely at fault. Replace the display card.
Try your monitor on a different computer. If it does not work, replace the monitor or have it repaired by a trained technician. Just try friend it will help you Good luck.
Mar 05, 2009 | Intel D845EPI (INTELKD845EPILPAK10)...
My ECS 915 G-A elite group motherboard doesnot display anymore on the monitor..
have you tried to isolate what the cause of the problem? first check the video card if is properly inserted into the slot, and check the memory, and cable from CPU to monitor if it is connected properly. then boot your system. And try to observe this beep error code this might help you locate where the problem is.
short beep System is OK
1 long, 3 short beeps Display adapter problem (EGA)
thnk you.
Nov 29, 2008 | Computers & Internet
M2a-vm mother board
Hi auriaskate,
Currently you are using the onboard PCI video adapter. This graphics adapter uses you're system memory to function.
If there is a problem with you're system memory the beeps can lead one to think there is a problem with the onboard video.
You can not remove the onboard adapter so there may be a problem with you're system memory. (I doupt you're memory is bad) but on the other hand it might not be fully installed correctely. Power off the PC & unplug the power cord from the PC.
Please remove you're system memory & firmly reseat it.
Plug the power cord back in. Start the PC & listen for any beeps except the 1 normal beep known as P.O.S.T = Power on self test. Any beeps after that there is a problem with a device connected to the board.
You're Asus M2A-VM uses an Award bios. Click on the link below to see what Award beeps mean.
http://www.bioscentral.com/beepcodes/awardbeep.htm
Try the memory reseat & check. Let me know if this helped.
Mike
May 03, 2008 | ASUS M2A-VM (0610839149438) Motherboard
Intel S845WD1-E Motherboard Logo
32 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
